| FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak | |
+331997riv Geo.Tyler IFallsRon charlieRobinson Mattwa 98riv denim LARRY70GS Z-type ghpcnm 2000ws6transam Jelorian Eldo robotennis61 DarkVader albertj playa Abaddon manofmany mr riviera ibmoses L67 3.8 Riviera Rickw BMD xxsupergman25xx deekster_caddy iggyy racinfan Sag AA Mr.Riviera ender467 37 posters |
xxsupergman25xx Aficionado
Name : Scotty Age : 37 Location : Pittsburgh, PA Joined : 2007-03-03 Post Count : 1251 Merit : 13
| Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Sun May 24, 2009 2:39 pm | |
| how bad is it to drive with a bad tensioner or pulley for a little bit? will it cause a lot of damage? | |
| Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Sun May 24, 2009 2:58 pm | |
| Depends on the problem. If it's the tensioner itself, it could be fine for thousands of miles. If it's actually a pulley making the noise, you have about 100 miles before it frags. I've had it happen to me before. If you catch it soon enough, could save you the price of a serpentine belt.
Sounding more like an idler or tensioner pulley. I like BMD's idea - take the belt off and spin the pulleys one at a time. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Sun May 24, 2009 4:37 pm | |
| like I've said before.... I can't do car work at where im at.. and I have no freakin clue how to take it off and put it back on lol | |
| Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Sun May 24, 2009 4:52 pm | |
| Ask a mechanic to look at it for you then. He'll probably have a stethescope to use. Still cheaper than getting stranded when the tensioner blows up. | |
| Subject: Chirp Chirp Chirp Chirp- How much is a....? Fri May 29, 2009 7:34 pm | |
| so im pretty sure its a tensioner or pulley thats makin the noise... how much do these cost? where can u get them? can u help me diagnose it? help me put them on..they look difficult.? how long does it take?
thanks boysss | |
| Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Fri May 29, 2009 7:50 pm | |
| Look in the "Write-Ups" section for changing belts and pulleys. | |
| Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Fri May 29, 2009 8:13 pm | |
| - xxsupergman25xx wrote:
- so im pretty sure its a tensioner or pulley thats makin the noise...
thanks boysss I CANT DO IT MYSELF..a write up will do me no good. lol | |
| Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Fri May 29, 2009 8:25 pm | |
thanks boysss
I CANT DO IT MYSELF..a write up will do me no good. lol Then bring it to shop and get a diagnosis and an estimate!!!!! | |
| Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Fri May 29, 2009 8:47 pm | |
| -tensioner cost between $50-60. -idlers will run 15-20. -get them from rockatuo if you know what the problem is, otherwise you can get them at a higher price at the local auto stores. -diagnosing belt chirp over the internet is like trying to determine if soup is hot enough from across the street. -idlers are easy to put on, tensioners can be more difficult, especially the rear one. -doesnt take long if you know what you are doing. shop will likely charge 1hr labor to diagnose and fix. ($80) ...or wait till the local meet and i'll fix it for a nominal fee + parts _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Fri May 29, 2009 8:52 pm | |
thanks boysss
I CANT DO IT MYSELF..a write up will do me no good. lol maybe a writeup can help you to do it yourself, that's what they are for... | |
3.8 Riviera Amateur
Name : Tyre Location : La Joined : 2009-05-26 Post Count : 44 Merit : 1
| Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Fri May 29, 2009 9:35 pm | |
| I also have the same chirping sound under my hood. I also need to find out how much these things are going to cost. The two main things I need to replace are the gaskets and a new belt, maybe the tensioner or pulley. If this works for you, let me know. Here are a couple of good links: Link Link Link | |
| Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Fri May 29, 2009 9:43 pm | |
| thank you..thats the exact type of link i was lookin for...see..my prob is im unemployed...and i just dropped 600 on fixin my tranny. that really hurt...theres some guys from FLA im meetin up with ont he 6th...hopefully they can help me do it.. place wants at least 30 mins to diagnose, plus parts, plus the actual fixing it..if i could at least get it diagnoased by one of those guys id be happy..if we could actually fix id be ecstatic. 3.8--im very ummm...i guess the word is dumb when it comes to this stuff and i have little confidence when it comes to fixin cars. | |
| Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Fri May 29, 2009 9:51 pm | |
| regardless if the pulley makes noise or not, replacing an original pulley is a very wise idea with the mileage of most of our riv's. countless members on here will tell you it's not a good day when the idler shrapnel's, tearing up the belts. and the other pulleys usually follow suit shortly after, so replacing all of them at once is good insurance.
normally a chirping sound that goes away/get louder with change in rpm and temp is symptomatic of a worn out tensioner. a worn idler bearing makes a more metallic sound.
best thing to do is remove the s/c belt and see if the chirping/noise goes away. then you know which of the sets of idler/tensioners it is. next step is to remove the belt and feel each of the pulleys for rough rotation and/or noise. same as you would check the bearing on a roller blade or skateboard wheel.
HTH's, but i'd be more than happy to take a look at it if you can hold off till the 6th. if you can diagnose it yourself and get the parts ready i'll show you how to replace them on the 6th instead. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Fri May 29, 2009 9:58 pm | |
| thanks matt..whats HTH? i really dont drive much..so i can hold off...i barely put on 30-50 miles a week. id rather have that replaced then do the FWI. i could prolly manage that without much help. but i will do my best to try and diagnose it myself...
do u need tools to take the belt on and off a pulley/tensioner?or can u just slide it on and off? | |
| Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Fri May 29, 2009 10:11 pm | |
| HTH = hope that helps.
you will need a 15mm socket and ratchet to take off the belts if they are like the 96+ motors. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Fri May 29, 2009 10:29 pm | |
| 95 s/c. everythin runs on one belt. | |
L67 Aficionado
| Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Sat May 30, 2009 10:51 am | |
| I removed the belts when i changed my coupler and figured out my alternator is whats squeaking...So I would advise playing around with the pulleys and spinning them to see which is bad. | |
| Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Sat May 30, 2009 12:38 pm | |
| An alternator that is failing mechanically can be diagnosed by touch. If it is hotter than the parts around it, it needs replaced. When my alternator failed, it made a low-pitched whine very much like the supercharger. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
L67 Aficionado
| Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Sat May 30, 2009 5:24 pm | |
| Well I'm not sure if mine really needs to be replaced, but I'm pretty sure the noise is coming from a worn bearing so it is probably wise to do so anyway. It still functions but the noise is quite embarrassing. | |
| Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Sat May 30, 2009 5:46 pm | |
| - L67 wrote:
- Well I'm not sure if mine really needs to be replaced, but I'm pretty sure the noise is coming from a worn bearing so it is probably wise to do so anyway. It still functions but the noise is quite embarrassing.
i think we might be havin the same problem...yes..that noise is definetly embarrasing! that noise can brings a persons morale down quite a bit. like u cant take care of a car. | |
ibmoses Aficionado
| Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Sat May 30, 2009 8:16 pm | |
| You can also diagnose tensioner pulley's by feel to see if they are very hot...
Bert | |
| Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Sat May 30, 2009 8:23 pm | |
| - Quote :
- i think we might be havin the same problem...yes..that noise is definetly embarrasing! that noise can brings a persons morale down quite a bit. like u cant take care of a car.
Whatever you do, don't replace anything until you know for sure what's the problem. Diagnose first. Nothing's worse for morale than replacing perfectly good parts! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Mon Jul 20, 2009 12:38 am | |
| the noise from the SC might be the Coupler. from my understanding...they tend to break down. my coupler is bad..makes a bird chirping noise. | |
| Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Mon Jul 20, 2009 2:16 am | |
| Mine makes the bird chirp, too. It comes and goes - have narrowed it down to the tensioner, not the coupler, which sounds more like marbles in a coffee can. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Mon Jul 20, 2009 11:14 am | |
- Mine makes the bird chirp, too. It comes and goes
why does the noise come and go? ive noticed that too..sometimes ill start the car hear nothing...other times ill start it and its faint...some its super loud. sometimes the noise will change while driving. | |
| Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak | |
