 FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak
FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak - Page 3 Empty
PostSubject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak   FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak - Page 3 EmptyMon Jul 20, 2009 12:43 pm
It's a warning that it's about to fail. Consider yourself lucky that you are getting warning noises and it didn't just grenade on you during a long trip.
Replace them all as soon as possible.
PostSubject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak   FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak - Page 3 EmptyMon Jul 20, 2009 1:00 pm
mines the SC coupler. from my understanding from Matt...theres no threat if it goes. he checked my idlers and pulleys.
PostSubject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak   FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak - Page 3 EmptyMon Jul 20, 2009 1:03 pm
Oh, well that's a different story then.
From what I've read on here you can safely let the coupler go for a while before changing it out.
PostSubject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak   FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak - Page 3 EmptyMon Jul 20, 2009 1:20 pm
yes, last time Scotty had his car at my house i (we) checked the belts tensioner and pulleys. the only think i noticed was a worn out s/c coupler. it has quite a bit of play in it, but i dont see it failing any time soon.
now, that's not to say you still wont have a idler sieze up, sometmes you dont get a warning.
FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak - Page 3 Dsc_0110
PostSubject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak   FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak - Page 3 EmptyMon Jul 20, 2009 1:21 pm
In my case, it's the tensioner itself that is chirping, not the tensioner pulley. I changed the coupler and the tensioner kept on chirping. I can take a ratchet and move the tensioner with the engine running and make the noise go away. I believe it's because the spring is wearing out, but it's not going to break off or anything. Mine's been chirping for almost a year now, off and on. I need to replace the tensioner because I've had SC come off a couple times under sharp throttle blips (only once while driving).
EDIT: replaced the tensioner (kept same belt and idler/tensioner pulleys); after 5 months, chirping noise is gone for good.
PostSubject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak   FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak - Page 3 EmptyMon Jul 20, 2009 1:23 pm
mine did that too Aaron. i bought a new tensioner for rockauto and it stopped making the noise for about 6 months. now it chirps again, but only when the car is cold. guess i should have opted for the acdelco replacement one bonk
mr riviera
mr riviera
PostSubject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak   FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak - Page 3 EmptyFri Aug 07, 2009 8:54 pm
Id say if you hear chirping its belt noise ...
spray a few drops of something ... i used armour all on the inside of the belt , if it goes away ... bingo .
It wouldny hurt to replace the pulleys i bet though either @100k +
manofmany
PostSubject: Alternator pulley bearings? Video inside   FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak - Page 3 EmptyTue Aug 17, 2010 9:45 am
Does this sound like the bearings are short in the alternator? It's been chirping for about 400 miles or so but has gotten a little nosier lately. I'm sure it's not the idler because it was changed fairly recently and is no longer the cheap plastic pulley.
If it is, is it possible to just have the pulley/fan or bearing swapped out? I really don't want to shell out the money for the entire alternator if I don't have to.
PostSubject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak   FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak - Page 3 EmptyTue Aug 17, 2010 9:59 am
I couldn't tell from the video. With engine running, try carefully reducing tension to the SC and accessory belt tensioners, using a ratchet. I had a similar chirp - it was the tensioner making the noise.
manofmany
PostSubject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak   FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak - Page 3 EmptyTue Aug 17, 2010 10:04 am
Won't the bolt be turning with it running?
PostSubject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak   FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak - Page 3 EmptyTue Aug 17, 2010 10:08 am
No.
If a tensioner pulley bolt is turning, THAT'S where the problem is!
PostSubject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak   FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak - Page 3 EmptyTue Aug 17, 2010 10:17 am
It's damn near impossible for the tensioner bolt to turn. It's reverse threaded so that it can't turn with the engine running. If it were to turn with the engine running, a catastrophic belt failure will quickly follow.
PostSubject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak   FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak - Page 3 EmptyTue Aug 17, 2010 10:28 am
Relieve belt tension by turning the bolt counter-clockwise. It only takes a little movement to reveal the problem. Be careful.
manofmany
PostSubject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak   FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak - Page 3 EmptyTue Aug 17, 2010 10:57 am
Just relieved tension and noise went away. It did not come back upon releasing the tensioner, but once I revved the engine the noise returned.
FWIW, the tensioner does not move smoothly.
PostSubject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak   FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak - Page 3 EmptyTue Aug 17, 2010 11:06 am
Which tensioner was it? SC or accessory belt?
A write-up for SC tensioner is here: Link. Accessory side will be a little more involved, but similar to swap.
manofmany
PostSubject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak   FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak - Page 3 EmptyTue Aug 17, 2010 11:21 am
It's the accessory side. I guess since the noise subsided that rules out the alternator.
One quick question, will I need to loosen/remove the ac compressor to swap it out? Just a quick question without looking at the pulley/belt guide.
PostSubject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak   FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak - Page 3 EmptyTue Aug 17, 2010 11:29 am
It doesn't rule out the alternator 100%, but the tensioner moving roughly does suggest it is making the noise, not the alternator. Spin the alternator without the belt, and wobble the pulley to see if any slop. If it's smooth, alternator should be okay.
Check all other accessory and idler pullies as well.
My SC tensioner started chirping around ~160k miles. It lasted a long time before I changed it. It's annoying more than it is dangerous, so you have some time to fix it. Mine always made more nosie in colder, damp weather.
PostSubject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak   FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak - Page 3 EmptyTue Aug 17, 2010 12:17 pm
Remove the belt (with engine off) and spin the alternator and other pullies by hand. You should be able to tell which ones are rough.
The accesory belt does go around the A/C comp, but you should not need to remove it. Loosening the belt tensioner removes tension on the entire belt path including the A/C.
manofmany
PostSubject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak   FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak - Page 3 EmptyWed Aug 18, 2010 9:36 am
Thanks guys!
It got noticeably louder this morning, to the point where I am going to change it immediately. I'm going to pull the belt off to verify the alternator.
playa
playa
PostSubject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak   FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak - Page 3 EmptyWed Aug 18, 2010 9:40 am
Not sure why you never used a stethascope or an old trick, a screw driver with your ear to the handle. Both ways you can pinpoint where the noise is coming from. suspect
PostSubject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak   FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak - Page 3 EmptyWed Aug 18, 2010 10:11 am
I have always shied away from the screwdriver trick. One slip, it gets caught in the belt, and you have a serious problem, or worse. But a true stethoscope, or piece of vacuum hose, these make more sense, imo.
manofmany
PostSubject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak   FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak - Page 3 EmptyWed Aug 18, 2010 10:25 am
I actually did use a piece of broomstick and did not hear any noise through it when placed against the alternator pulley.
manofmany
PostSubject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak   FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak - Page 3 EmptyWed Aug 18, 2010 11:21 am
I removed the belt and the alternator pulley is not exactly sloppy, but does give off an audible chirp-chirp-chirp noise when spun.
PostSubject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak   FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak - Page 3 EmptyWed Aug 18, 2010 11:29 am
I'd say either do some more listening w/engine running, or replace one or both of the parts. Tensioner is about $60, alternator is around $200.
Merit : 153
PostSubject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak   FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak - Page 3 EmptyWed Aug 18, 2010 11:41 am
if hte tensioner "dances" when the engine is running, the damper is weak and it should be replaced (replacing the pulley on it won't help). If not, and the pulley is binding or squeaking, you could get more life out of the tensioner by replacing it's pulley.
As for the alternator, you could get one from a junkyard that does not squeak without much problem for more like $25 to $40. GM used this alternator on a bunch of cars. If you are gonna get a "new" one get a good remanufactured one, not necessarily a new one. The reman ones will have more robust OE cases and rotors, the rebuilder can put the money into bearings and commutator brushes. I am happy with the Delco reman I got some years ago. Some have complained lately about Delco reman alternators so I'd tell them look at Cardone.
Page 3 of 8Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
» My belt falls off!
» Belts rubbing to much! HELP!
» Sens Chirp believes Cammalleri on Murray's radar.
» Sens Chirp: Vermette to DAL for Benn?
» Easy Belt Length Calculation: Pulley Swap Only
