 non functioning instrument cluster
pearlwhite91
Name : Kris Carpenter
PostSubject: non functioning instrument cluster   Mon May 25, 2009 12:50 am
HELP! my '91 instrument cluster doesn't register at all! sometimes i get the warning lights but no display. I have checked the connections to the cluster and all appears well. Any thought on where to go now? Computer? Any feedback would be appreciated!
Merit : 125
PostSubject: Re: non functioning instrument cluster   Mon May 25, 2009 1:22 am
where to go now = dealer diagnostics. The parts counter or the body shop should have sources to point you to for a remanufactured or repaired instrument cluster.
PostSubject: Re: non functioning instrument cluster   Mon May 25, 2009 8:12 am
I've heard many times of the digital clusters failing. Most likely it needs to be rebuilt/refurbished. I can't recall who rebuilds them, but I know I saw the answer long ago on the Riviera Owners Association. http://www.rivowners.org/
If you can get your hands on another, known good one, try swapping them out. It's a pretty common failure over time.
Ship
PostSubject: Re: non functioning instrument cluster   Mon May 25, 2009 12:44 pm
There's a guy that rebuilds them on ebay for around $100+ but you have to send him your core. You might also check car-part.com (North America database of auto junkyards) for a tested used one which are going for $100 to $200 (+ shipping). They are a wicked easy swapout to do.
Ship
PostSubject: Re: non functioning instrument cluster   Mon May 25, 2009 12:47 pm
By the way, a Riviera instr cluster from a '90 through '93 will fit along with one from a Reatta '90 through '91.
