 what to do ?
gosloriv
PostSubject: what to do ?   Sat Mar 31, 2007 4:46 pm
Last night i wasted the Rivi motor !!! Now i havent taken the pan off yet to see how much damaged i did. I think i may have spun a bearing sounds really bad if that isnt the case i will probably jus thro sum bearings in and call it a day but if idid spin a bearing and the crank is damaged i might as well go with a used engine. Anyone have any ideas and where should i look for one and are the engines interchangable from say a bonni,grand prix, ect ?Help me !!! sad
PostSubject: Re: what to do ?   Sat Mar 31, 2007 5:11 pm
lower block from any Regal, Grandprix, Bonneville, Lesabre, eighty eight, ninghty eight, park avenue etc will work. other this like accessory s and things you will have to change over from your old engine. . Since your there put a cam in. and use the ported LIM.
gosloriv
PostSubject: Re: what to do ?   Sat Mar 31, 2007 6:05 pm
can this engine be pulled from the top?
gosloriv
PostSubject: Re: what to do ?   Sat Mar 31, 2007 6:19 pm
how much for a cam !!
what to do ?
