gosloriv Enthusiast
Name : David Age : 50 Location : Elyria,Ohio Joined : 2007-03-15 Post Count : 152 Merit : 0
| Subject: what to do ? Sat Mar 31, 2007 4:46 pm | |
| Last night i wasted the Rivi motor !!! Now i havent taken the pan off yet to see how much damaged i did. I think i may have spun a bearing sounds really bad if that isnt the case i will probably jus thro sum bearings in and call it a day but if idid spin a bearing and the crank is damaged i might as well go with a used engine. Anyone have any ideas and where should i look for one and are the engines interchangable from say a bonni,grand prix, ect ?Help me !!! | |
oldsman105 Junkie
| Subject: Re: what to do ? Sat Mar 31, 2007 5:11 pm | |
| lower block from any Regal, Grandprix, Bonneville, Lesabre, eighty eight, ninghty eight, park avenue etc will work. other this like accessory s and things you will have to change over from your old engine. . Since your there put a cam in. and use the ported LIM. | |
gosloriv Enthusiast
| Subject: Re: what to do ? Sat Mar 31, 2007 6:05 pm | |
| can this engine be pulled from the top? | |
gosloriv Enthusiast
| Subject: Re: what to do ? Sat Mar 31, 2007 6:19 pm | |
| Subject: Re: what to do ? | |
