| humming from front end | |
rmjoia Special
Name : rich Age : 49 Location : new bedford,MA Joined : 2007-10-23 Post Count : 5 Merit : 0
| Subject: humming from front end Tue Jun 09, 2009 11:44 am | |
| I just put in a mps 3.6. two days later I'm getting a loud hummind sound over 30 miles an hour and it gets louder the faster I go . possible wheel issue or did my mechanic flub my supercharger. please help!! | |
| Subject: Re: humming from front end Tue Jun 09, 2009 11:56 am | |
| Check the screws on the SC pulley are tight.
Does the humming only happen when you get on the gas? or when you are just coasting? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
rmjoia Special
| Subject: Re: humming from front end Tue Jun 09, 2009 12:04 pm | |
| The humming starts after 25 -30 mph . then it's a constant. slows as I slow the car. | |
| Subject: Re: humming from front end Tue Jun 09, 2009 12:26 pm | |
| check your wheel bearings. does the noise go away or get louder during turns? also take a close look for unusual tire wear. maybe even swap the front and rear tires to see if the noise moves too.
you actually got a shop to install a 3.6 pulley?!? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
71stagegs Enthusiast
Name : steve Age : 71 Location : L.I NY Joined : 2008-03-09 Post Count : 189 Merit : 2
| Subject: Re: humming from front end Tue Jun 09, 2009 1:11 pm | |
| get up to speed put it in neutral if it gets lower its the motor | |
rmjoia Special
| Subject: Re: humming from front end Tue Jun 09, 2009 2:11 pm | |
| to 71stagegs' ? I tried putting into neutral at 65 mph still there. I just noticed my mechanic put on a double sided sc belt . he said the gatorbackbelt I got from intense (gb6-660)was too small. seeing as I have zero exper. with mech stuff I took his word for it. any other possibillity | |
| Subject: Re: humming from front end Tue Jun 09, 2009 3:00 pm | |
| If you have no change in sound when you let the engine speed down, it's most likely the wheel bearing. Do you have the Trac/ABS light on? | |
| Subject: Re: humming from front end Tue Jun 09, 2009 3:15 pm | |
| You could put it in neutral at speed, then shut the car off on a straight road. See if the hum goes away with engine off. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: humming from front end | |
