| FAQ: Sunroof/Moonroof Problems & Adjustment | |
+23gadabout c0reyl Rickw robotennis61 VJD2 #1BearsFan EatDirtFartDust Ironclad-454 98RIV7777 rivboy rivman96 '96reese 99Rivman Chicken ewolfe0050 jimmyriv Mr.Riviera steve1173 Kustom Kreationz albertj AA deekster_caddy ibmoses 27 posters |
| Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Tue Mar 30, 2010 3:30 am | |
| pain in the arse. lol. btw,ihp,rolf! | |
VJD2 Fanatic
Name : Vinny Location : Connecticut Joined : 2010-02-21 Post Count : 310 Merit : 5
| Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Tue Mar 30, 2010 9:45 am | |
| - robotennis61 wrote:
- you have to clean all the mating surfaces including the rubber seal. pia, but you have to clean the cables with wd40,then grease with whatever the manufacture recomends for grease. that should help.if you live in Ct then the winter might have made its way into the roof.....
Hmmm, thanks for the tip(s). Hopefully that solves the problem and its nothing worse than just lubing things up. Sounds like another project for a good day. Its pouring here now. Luckily no leaks that I can see so far. - Rickw wrote:
- I wouldn't be opening it too much until i figured out what was wrong.
I've not had that problem, but maybe someone else on here has and can help you. You bet I won't be messing with it. I opened it once and got it shut, now that is where is stays until I figure this out! | |
c0reyl Addict
Name : Corey Age : 32 Location : JMU virginia Joined : 2011-07-25 Post Count : 569 Merit : 2
| Subject: How do I remove the sliding panel that covers the sunroof? Tue Sep 18, 2012 8:27 pm | |
| I have no idea how to remove it, and since I'm going to dye it, it would be a lot easier if I removed it first | |
gadabout Special
Name : Dee Age : 72 Location : Highland Heights, KY - near civilization Joined : 2012-08-25 Post Count : 5 Merit : 0
| Subject: Liner Material came loose from Moon Roof Cover Wed Dec 12, 2012 11:30 am | |
| Has anyone every unscrewed the moon roof from outside while the moon roof was opened to access the top side of the moon roof cover? The cloth on the sliding moon roof cover on the inside has come loose and I would like to repair it and the only way I can see to repair it, other than take the whole headliner out, is to access it from the outside. Help!
| Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Wed Dec 12, 2012 11:34 am | |
| _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
gadabout Special
| Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Wed Dec 12, 2012 11:53 am | |
| I am wondering if anyone has ever tried to unscrew the moon roof from the outside once the moon roof is open?
I need to get to the top side of the cover to glue the fabric back tight. It has come loose on the inside where it slides back and forth. | |
gadabout Special
| Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Wed Dec 12, 2012 11:59 am | |
bigdave Fanatic
| Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Wed Dec 12, 2012 5:53 pm | |
| I don't know your budget but you might be surprised at how little an interior shop may charge you for the whole job. Might be worth getting a quote before you tackle this yourself. I had the headliner redone in one of my cars and the price difference for me to pull the headliner or let them do it was only $20. Just something to think about. | |
| Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Wed Dec 12, 2012 10:07 pm | |
| - gadabout wrote:
- Has anyone every unscrewed the moon roof from outside while the moon roof was opened to access the top side of the moon roof cover?
you might want to get a quote for having a shop do this. | |
Rivlanta Member
Name : Craig Location : Atlanta, GA Joined : 2009-07-19 Post Count : 60 Merit : 22
| Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Thu Dec 13, 2012 5:31 am | |
| Dee...I had the same problem with my interior "moon roof" inside sliding cover. I repaired it by first removing the glass top cover from the outside according to the disassembly instructions in the 1997 Riv Service Manual. Then I was able to remove the sliding cover, re-attach the covering using adhesive, and re-install in reverse order. It was challenging, but not impossible. If you don't have a Riv Service Manual, let me know and I will try and scan the appropriate pages and either upload here, or send them to you in PDF via email. | |
shizzlep Special
Name : Shawn Perry Joined : 2014-04-06 Post Count : 7 Merit : 0
| Subject: Moonroof Motor Thu Apr 17, 2014 11:04 pm | |
| Does anyone know were to find sunroof parts I think my motors shot? | |
R1V 1T UP Enthusiast
Name : Timothy Location : Buffalo Joined : 2009-02-05 Post Count : 104 Merit : 0
| Subject: Sun / Moon Roof Loud Ratchet Sound Sun May 10, 2020 6:12 pm | |
| - jimmyriv wrote:
- Does anyone have any experience with sunroof limit switches. (Location, adjustment)?
Mine just started acting up. When opening the back up it makes a loud ratcheting noise at the full up position instead of just stopping. When closing it from that position, it just continues to fully opening instead of stopping at the normal closed position. This is happening to me now and since the photos posted were so long ago they are no longer visible. Does anyone know how to fix this? My sunroof cover is also in bad condition with the headliner coming off and adhesive flakes getting everywhere when I try to close it. What is the best way to go about fixing this? I think with a little bit of attention it should be in great shape. Thank you for reading! | |
| Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Wed May 13, 2020 3:15 am | |
| As I think you know, the repairs to the sunroof headliner will most likely require you to drop the headliner and get access to the sunroof.
This will allow you to fix all the fabric falling off by either re-gluing your existing fabric or getting new fabric from an interior shop and scraping everything off and cleaning the surface for a new coat of adhesive. Or you can pay an interior shop to do it all for you if your not comfortable doing it yourself.
Good Luck and post on here what you chose to do. I'm interested as I have a headliner that needs to be done also. | |
| Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment | |
