 Replacement Bulb Part Numbers
Replacement Bulb Part Numbers Empty
PostSubject: Replacement Bulb Part Numbers   Replacement Bulb Part Numbers EmptyWed Jul 01, 2009 2:01 pm
Different light bulbs for your Riviera
Low Beam Headlamp
9006
9006LL Long Life Halogen Upgrade: Lasts one and a half times longer
High Beam Headlamp
9005
Parking Light
3057
3057LL Long Life Upgrade: Up to twice the life of the standard lamp
Front Turn Signal
3057
Rear Turn Signal
3057
Tail Light
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
3057
Stop Light
3057
High Mount Stop Light
1156
1156LL Long Life Upgrade: Up to twice the life of the standard lamp
License Plate
194
Back Up Light
3057
Front Sidemarker
194
Rear Sidemarker
194
Ash Tray
161
Glove Box
194
Map Light
168
Dome Light
168
Step/Courtesy Light
161
168
194
Trunk/Cargo Area
211-2
Under Hood Light
561
PostSubject: Re: Replacement Bulb Part Numbers   Replacement Bulb Part Numbers EmptyWed Jul 01, 2009 2:18 pm
Nice thank you!!!!
LaFlare
PostSubject: Re: Replacement Bulb Part Numbers   Replacement Bulb Part Numbers EmptySun Dec 05, 2010 2:51 pm
you know how there's a light on the passengers side floor, is there also supposed to be one on the drivers side? just noticed that there is none on my drivers side, i went down to check for a bulb or a spot for one but didn't see anything, maybe i just missed it?
PostSubject: Re: Replacement Bulb Part Numbers   Replacement Bulb Part Numbers EmptySun Dec 05, 2010 6:26 pm
Yes there should be one on the drivers side. There is a spot for the bulb. You might have to take the cover off to find the connector if it was disconnected and is hanging behind the cover.
Merit : 153
PostSubject: Re: Replacement Bulb Part Numbers   Replacement Bulb Part Numbers EmptySun Dec 05, 2010 7:20 pm
If the bulb was in service a long time before it burned out, it may have turned silver and not really look that much like a bulb except the shape.
LaFlare
PostSubject: Re: Replacement Bulb Part Numbers   Replacement Bulb Part Numbers EmptyTue Dec 07, 2010 2:40 pm
cool thanks i'll have another looksee today. last time i checked was at night time with a flashlight, and today is sunny out i will check.
Step/Courtesy Light
161
168
194
which ones the correct one? well i'll probably have figured out by the time i check back on here
Jimdangello
Jimdangello
PostSubject: Re: Replacement Bulb Part Numbers   Replacement Bulb Part Numbers EmptyThu Jan 03, 2013 1:33 pm
Thanks a ton for this! You save me a ton of time and frozen fingers out there in 30 degree weather trying to figure out what bulbs i needed. Going to change to LED's all around.
PostSubject: Re: Replacement Bulb Part Numbers   Replacement Bulb Part Numbers EmptyThu Jan 03, 2013 6:08 pm
Jim D., please do tell where you're getting your LEDs from. Thank you.
PostSubject: Re: Replacement Bulb Part Numbers   Replacement Bulb Part Numbers EmptySun Jan 20, 2013 4:36 pm
Rear Sidemarker
194
Thank you!
» RZR 900 universal/ U-Joints
» Red Arrow replacement arrived!
» which part of toronto is grass roots canada located?
» Polaris center caps
» Houllier's replacement?
