| Write-Up: Front & Rear Bumper Modification | |
+48playa Derek Ash 97 park ave crlombardi69 stan Abaddon brians74x Blown_99_Riviera turtleman ZEP #1BearsFan L67 GMFreak8 ghost88 DEMonte1997 nigelf blackbart95 jimmyriv Eldo The Riv captshiner patillac Steve98 Lucas Jason albertj BMD Boattail Bill Karma '96reese deekster_caddy woggy Z-type ewolfe0050 97rivsc AA ibmoses Snowdog IBx1 palermocorey90 T Riley sburch23 Jack the R 99Rivman robotennis61 Rickw sqrivi 52 posters |
sqrivi Fanatic
Name : scott Location : madison, al Joined : 2008-03-15 Post Count : 375 Merit : 52
| Subject: Re: Write-Up: Front & Rear Bumper Modification Thu Jul 16, 2009 7:42 am | |
| maybe a small antenna under the dash, but nothing on the outside of the car. | |
Snowdog Addict
| Subject: Re: Write-Up: Front & Rear Bumper Modification Thu Jul 16, 2009 8:58 am | |
| just but one interjor antenna what connects whit the front or rear window. i installed in mine on back window. works great | |
97rivsc Fanatic
Name : mike Age : 34 Location : appleton wisconsin Joined : 2008-09-28 Post Count : 437 Merit : 0
| Subject: Re: Write-Up: Front & Rear Bumper Modification Thu Jul 16, 2009 12:19 pm | |
| snowdog, how and where did you get that kind of antenna? | |
ewolfe0050 Aficionado
| Subject: Re: Write-Up: Front & Rear Bumper Modification Thu Jul 16, 2009 1:43 pm | |
| When I shaved my car I ended up getting a universal hidden antenna that I attacked to my rear strut bar. Works better than the original but you have to make sure it is an inch away from anything steel. I made a small spacer for mine. You can pick them up at any autoparts store for $25-$30. | |
| Subject: Re: Write-Up: Front & Rear Bumper Modification Thu Jul 16, 2009 1:56 pm | |
| That's clever. I'd much rather have that set up than the factory one. | |
sburch23 Addict
| Subject: Re: Write-Up: Front & Rear Bumper Modification Thu Jul 16, 2009 9:46 pm | |
| Will that work for a Navigation antenna? | |
| Subject: Re: Write-Up: Front & Rear Bumper Modification Thu Jul 16, 2009 9:50 pm | |
| i like the idea of deleting the stock antena. weight be gone! does the aftermarket one hook up to the stock wireing? | |
| Subject: Re: Write-Up: Front & Rear Bumper Modification Thu Jul 16, 2009 9:52 pm | |
| Nav antenna has to have a clear view of the sky to work. I lose signal just going under bridges and thick clouds. You don't want to obscure the antennas line of site UP. They do make an antenna that can be placed on the corner of your dash and wired to the Nav unit.. And with all the glass we have on the Riv it should work good. | |
sqrivi Fanatic
| Subject: Re: Write-Up: Front & Rear Bumper Modification Sat Jul 18, 2009 3:44 pm | |
| Subject: Re: Write-Up: Front & Rear Bumper Modification Sat Jul 18, 2009 3:51 pm | |
| That looks excellent. Nice work and the shape is just right. Can't wait to see how the front comes out.!!! | |
Snowdog Addict
| Subject: Re: Write-Up: Front & Rear Bumper Modification Sat Jul 18, 2009 4:03 pm | |
| i hope you'r not painting the rear lip the same color as the car... i think it would make it look BIG and a bit booring. maybe something darker. guess it will look good then and whit the exhaust tips comming through the rear lip. | |
sqrivi Fanatic
| Subject: Re: Write-Up: Front & Rear Bumper Modification Sat Jul 18, 2009 4:49 pm | |
| Everything will be the same color. The exhaust tips and marker lights will break things up a bit. Should keep it from looking to big. Sleek, simple, and clean is the look I am after. | |
| Subject: Re: Write-Up: Front & Rear Bumper Modification Sat Jul 18, 2009 4:52 pm | |
| Subject: Re: Write-Up: Front & Rear Bumper Modification Sat Jul 18, 2009 6:36 pm | |
| - sqrivi wrote:
- Everything will be the same color. The exhaust tips and marker lights will break things up a bit. Should keep it from looking to big. Sleek, simple, and clean is the look I am after.
More phat more better! | |
sburch23 Addict
| Subject: Re: Write-Up: Front & Rear Bumper Modification Sat Jul 18, 2009 8:04 pm | |
| With the color that you intend to use, the Riviera's sensuous curves give it slightly different colors anyway.
However I got to thinking about Snowdogs comment. Remember the Mako Shark show car. It has since been copied but it had silver low and then blended into a blue. I think that would look good on our cars. | |
| Subject: Re: Write-Up: Front & Rear Bumper Modification Sun Jul 19, 2009 1:12 pm | |
| There is something very awesome happening from this angle, the edge contour of the left rear quarter is very good: _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
Z-type Aficionado
| Subject: Re: Write-Up: Front & Rear Bumper Modification Sun Jul 19, 2009 1:30 pm | |
| Pretty neat project ...awesome work! | |
woggy Enthusiast
Name : Paul Age : 62 Location : Altoona, Florida (Somewhere in the ocala national forest) Joined : 2009-04-28 Post Count : 201 Merit : 7
| Subject: Re: Write-Up: Front & Rear Bumper Modification Fri Jul 24, 2009 1:45 pm | |
| very nice work. and thanks for posting the pics as your project comes along. will be one of a kind. I like it! | |
Snowdog Addict
| Subject: Re: Write-Up: Front & Rear Bumper Modification Fri Jul 24, 2009 2:13 pm | |
| cant remember if you sayd somewhere but....are you going to loos the 'trimms' or how ever they are called what are on the sides of the car. or maybe even door handles? would look sick smooth. i had once a idea..but cant find any rivs here in junkyard...but...maybe if you can get some spear sideskirts....cut it in half...and connect 2 of them...so that the wave on the front will be on back tho. i think it would look better that way...more sporty? anyways keep up the good work. | |
sqrivi Fanatic
| Subject: Re: Write-Up: Front & Rear Bumper Modification Fri Jul 24, 2009 10:21 pm | |
| The door handles and the molding down the side of the car will remain. I haven't thought about your idea with the side skirts, that might be cool. I'll think about it. | |
sqrivi Fanatic
| Subject: Re: Write-Up: Front & Rear Bumper Modification Sat Jul 25, 2009 5:27 pm | |
| Subject: Re: Write-Up: Front & Rear Bumper Modification Sat Jul 25, 2009 5:33 pm | |
99Rivman Aficionado
sburch23 Addict
| Subject: Re: Write-Up: Front & Rear Bumper Modification Sat Jul 25, 2009 6:31 pm | |
| Very nice. Thanks for the photos. Keep 'em coming.
You might want to keep the molds. There may be a market brewing here at RivPerformance. | |
sqrivi Fanatic
| Subject: Re: Write-Up: Front & Rear Bumper Modification Sat Jul 25, 2009 7:02 pm | |
| - sburch23 wrote:
- You might want to keep the molds. There may be a market brewing here at RivPerformance.
Will be keeping the molds for both the front and rear. | |
| Subject: Re: Write-Up: Front & Rear Bumper Modification | |
