 Engine turns over but won't catch at all
1995 Riv
Engine turns over but won't catch at all Empty
PostSubject: Engine turns over but won't catch at all   Engine turns over but won't catch at all EmptyThu Jul 09, 2009 3:22 pm
I was messing around under drivers dash with a mixing door actuator and then moved car up. It has not started since.
PostSubject: Re: Engine turns over but won't catch at all   Engine turns over but won't catch at all EmptyThu Jul 09, 2009 4:35 pm
1. did you go through all the fuses to make sure you didnt ground out something while under the dash?
2. would be odd for it to happen at the same time, but a bad crank positon sensor will cause the motor to just crank over and over and never start.
3. can you hear the fuel pump prime? (key "on" listen for a buz from rear)
Engine turns over but won't catch at all Dsc_0110
1995 Riv
PostSubject: Re: Engine turns over but won't catch at all   Engine turns over but won't catch at all EmptyThu Jul 09, 2009 4:53 pm
Maybe fuel pump
PostSubject: Re: Engine turns over but won't catch at all   Engine turns over but won't catch at all EmptyThu Jul 09, 2009 5:10 pm
Go back under the dash by the mixing door and see what wires you bumped. Push wiring harnesses around and try to start it again. Good luck! frown
1995 Riv
PostSubject: Re: Engine turns over but won't catch at all   Engine turns over but won't catch at all EmptyThu Jul 09, 2009 5:15 pm
Thanks
» My battery barely turns the starter. Could it be a bad a connection?
» Engine wont turn over with spark plugs in.
» RCGF 45cc Petrol Engine
» Where would i be most likely to catch a Zander and how?
» Tecumseh engine
