 95RiviSC's Problem Thread
95RiviSC
95RiviSC
95RiviSC's Problem Thread - Page 2 Empty
PostSubject: Re: 95RiviSC's Problem Thread   95RiviSC's Problem Thread - Page 2 EmptyWed Jul 15, 2009 11:41 pm
^^I've had the ignition module replaced not too long ago. I'm getting pretty flustered with this car.
http://www.clublakers.com
PostSubject: Re: 95RiviSC's Problem Thread   95RiviSC's Problem Thread - Page 2 EmptyWed Jul 15, 2009 11:52 pm
Make sure the ground wire that comes off the ICU is making good contact.
It may have been disturbed when ICU was changed.
Merit : 153
PostSubject: Re: 95RiviSC's Problem Thread   95RiviSC's Problem Thread - Page 2 EmptyThu Jul 16, 2009 12:16 am
I think you're on it Rick. We'll see.
95RiviSC
95RiviSC
PostSubject: Re: 95RiviSC's Problem Thread   95RiviSC's Problem Thread - Page 2 EmptyThu Jul 16, 2009 12:51 am
Excuse my ignorance but what does ICU stand for?
PostSubject: Re: 95RiviSC's Problem Thread   95RiviSC's Problem Thread - Page 2 EmptyThu Jul 16, 2009 5:57 am
ICU = Ignition Control Unit
It's located under the coil packs. The coils are actually screwed right to it.
I believe that was the module you had replaced.
There should be a black wire coming from it and bolted or screwed to a ground.
Make sure the wire is not broken and that the connection is clean and tight.
PostSubject: Re: 95RiviSC's Problem Thread   95RiviSC's Problem Thread - Page 2 EmptyThu Jul 16, 2009 7:18 am
My 00 Regal was acting crazy and having all sorts of driveability problems. The problem was the connector with all the wires that connects to the coil pack was loose. Tightened it up and solved the problem. Seems like it is called a DIC connector(not sure it that is the correct terminology) Its easy to spot it.
Bert tavis
PostSubject: Re: 95RiviSC's Problem Thread   95RiviSC's Problem Thread - Page 2 EmptyThu Jul 16, 2009 7:33 am
Bert tavis
good idea to check it - the connector is on the front of the coil packs and help in by a 7mm bolt head, just make sure it is snug.
95RiviSC
95RiviSC
PostSubject: Re: 95RiviSC's Problem Thread   95RiviSC's Problem Thread - Page 2 EmptySat Aug 01, 2009 1:44 pm
So the problem has been narrowed down to the black ground wire that is connected to the ignition module. The mechanic says he needs to know what voltage it is, whether it's 12V or 5V, to fix the problem. Any ideas?
PostSubject: Re: 95RiviSC's Problem Thread   95RiviSC's Problem Thread - Page 2 EmptySat Aug 01, 2009 4:40 pm
Could someone with the 1995 FSM verify the voltage requirement via wiring the diagram.
Actually all years should be the same but I loaned my FSM to a local guy I recently met.
PostSubject: Re: 95RiviSC's Problem Thread   95RiviSC's Problem Thread - Page 2 EmptySat Aug 01, 2009 5:59 pm
My FSM was just returned and it states:
The PCM provides 5volts to the ignition control module bypass circuit when conditions are appropriate for PCM control of spark timing (IC mode).
If the PCM does not apply 5 volts to the bypass circuit, or if the ignition control module does not receive it, the module will control spark timing at a fixed rate of 10* BTDC.
95RiviSC
95RiviSC
PostSubject: Re: 95RiviSC's Problem Thread   95RiviSC's Problem Thread - Page 2 EmptyThu Aug 13, 2009 5:55 pm
Thanks for the help man. Supposedly the mechanic fixed it. I drove home from my parents house last week and the car ran great. After a couple days, it started doing it again.
Also, I've noticed another problem. The battery light seems to always be on. Sometimes when I come to a red light or stop sign, it turns off then turns back on when I accelerate.
I went to another mechanic today and he told me to have the catalytic converter check. That the converter may be causing the stuttering problem. I did a little research and I don't think it's that.
PostSubject: Re: 95RiviSC's Problem Thread   95RiviSC's Problem Thread - Page 2 EmptyThu Aug 13, 2009 7:08 pm
Battery light coming on while accelerating or anything above idle: if that's correct i would suspect an over voltage situation.
Test with a voltmeter at alternator at idle and with throttle above idle and record voltage. Should not exceed 14.5 volts
Could be a bad voltage regulator overcharging your battery or a bad thermistor at the battery telling the regulator to put out more volts.
You need to check with a voltmeter though, anything else is just guessing.
You need to do it soon because if the system is putting out too much voltage and over charging the battery you will have excessive gassing of the battery under the back seat and emitting hydrogen gas...not good.
95RiviSC
95RiviSC
PostSubject: Re: 95RiviSC's Problem Thread   95RiviSC's Problem Thread - Page 2 EmptyThu Aug 13, 2009 7:15 pm
I will go do that right now. Thanks man.
I really appreciate all the help everyone has given me on this site. It's truly appreciated. Thanks again guys!
95RiviSC
95RiviSC
PostSubject: Re: 95RiviSC's Problem Thread   95RiviSC's Problem Thread - Page 2 EmptyThu Aug 13, 2009 9:15 pm
So the voltage test was good. The battery was ~12.68 and the alternator was ~13.4
Merit : 153
PostSubject: Re: 95RiviSC's Problem Thread   95RiviSC's Problem Thread - Page 2 EmptyThu Aug 13, 2009 9:44 pm
Hmmm...
did you check to see if the alternator belt is slipping when you rev the engine... maybe the tensioner is dead; when you accelerate the belt slips and the alt puts out less juice, causing the idiot light to come on. Or maybe the pulley is loose/damaged?!?! Or maybe the brushes in your alternator are worn out.
Just a thought.
95RiviSC
95RiviSC
PostSubject: Re: 95RiviSC's Problem Thread   95RiviSC's Problem Thread - Page 2 EmptyThu Aug 13, 2009 9:59 pm
albertj wrote:
Hmmm...
Just a thought.
I recently replaced both belts. And the alternator is new as well. How would I go about checking the tensioner? Or if the pulley is loose or damaged.
I know I've had the SC pulley replaced too.
Merit : 153
PostSubject: Re: 95RiviSC's Problem Thread   95RiviSC's Problem Thread - Page 2 EmptyThu Aug 13, 2009 10:31 pm
If the belt looks like it vibrates or wiggles when the engine is running and you rev it, odds are the tensioner is wack.
As for the pulleys, with the engine off loosen the tensioner, slip off the belts and inspect them. If a pulley is squeaking replace it with a name brand like Dayco or Gates... or if you're flush get a billet aluminum one made.
95RiviSC
95RiviSC
PostSubject: Re: 95RiviSC's Problem Thread   95RiviSC's Problem Thread - Page 2 EmptyThu Aug 13, 2009 10:55 pm
I'll have to take a look at them tomorrow morning. I'm almost 100% sure that they are fine.
PostSubject: Re: 95RiviSC's Problem Thread   95RiviSC's Problem Thread - Page 2 EmptyThu Aug 13, 2009 11:08 pm
If the 3-way connector is unplugged from the alternator, it will cause the battery light to come on, and the alternator won't charge the battery. But this is probably not the case if you are driving the car and the battery isn't dead, just a thought.
95RiviSC
95RiviSC
PostSubject: Re: 95RiviSC's Problem Thread   95RiviSC's Problem Thread - Page 2 EmptyThu Aug 13, 2009 11:29 pm
Yea the car drives fine (when it doesn't do that annoying stutter once in a while). So I really don't know if the stuttering is directly correlated to that battery light turn on when driving, and off when idle.
mdhall1
mdhall1
PostSubject: Re: 95RiviSC's Problem Thread   95RiviSC's Problem Thread - Page 2 EmptyFri Aug 14, 2009 12:48 am
I had the battery light on in my 95. The problem was a 16 gauge wire that goes through the connection to the battery. No clue what the wire is for but it had broken of f about six inches away from the battery. I spliced the wire back together and my voltage light has only been on when it's supposed to be. It's worked for the last year. I tried to find that wire in alldatadiy so i wouldn't sound like an idiot, no luck.
PostSubject: Re: 95RiviSC's Problem Thread   95RiviSC's Problem Thread - Page 2 EmptyFri Aug 14, 2009 1:17 am
what do u mean?
Merit : 153
PostSubject: Re: 95RiviSC's Problem Thread   95RiviSC's Problem Thread - Page 2 EmptyFri Aug 14, 2009 3:38 pm
Matt is probably referring to the fusible link, which really should be replaced not spliced.
95RiviSC
95RiviSC
PostSubject: Re: 95RiviSC's Problem Thread   95RiviSC's Problem Thread - Page 2 EmptySat Aug 15, 2009 12:01 am
Pulleys and belts checked out fine.
mdhall1
mdhall1
PostSubject: Re: 95RiviSC's Problem Thread   95RiviSC's Problem Thread - Page 2 EmptySat Aug 15, 2009 12:06 am
I figured out what i meant! i was thinking about it all day at work. its the Battery Temperature Sensor. one of the wires was broke. it hooks to the positive terminal on the battery. the sensor is $35 on rock auto. i spliced the wires back together and the only time my battery light comes on is when i first start the car. Sorry about the confusion.
» Custom Chassis Build Thread
» The Costume Thread....
» Eye Candy thread removed!
» Global RC 50cc Raven - Assembly Thread - Pic Heavy
» Homemade Thread ( if it cost to much so you made it yourself, please show it off here!)
