 95 colors
perbe
95 colors Empty
PostSubject: 95 colors   95 colors EmptyMon Jul 20, 2009 12:29 pm
I recently bought a White 95. It seems buick had 3 whites that year
White clear coat
Bright White clear coat
and
White Diamond Pri Tri Coat ( I assume this is a metallic which I do not have)
Anyone know which white was offered as an option on the 95?
I was looking to buy paint at this site hoping it would be a better match then the cans sold at Pep Boys etc... www.paintscratch.com. Anyone ever use their products?
95 colors Empty
PostSubject: Re: 95 colors   95 colors EmptyMon Jul 20, 2009 12:36 pm
The paint code is listed on the "Service Parts Identification" tag, on my '95 it is stuck on the inside of the right rear quarter panel, behind the trunk trim panels. Using the paint code number on that tag is the best way to know you get the correct paint.
95 colors Empty
PostSubject: Re: 95 colors   95 colors EmptyMon Jul 20, 2009 1:01 pm
When I needed to know which of the numbers on the tag were the paint code, I went to the body shop and asked them to tell me which number was the paint code.
It just so happens that there is a paint supplier across the street from this body shop that will mix any paint you want by paint code in an aerosol can for small paint jobs. Cost less than $20.00 for a can.
95 colors Empty
PostSubject: Re: 95 colors   95 colors EmptyMon Jul 20, 2009 11:31 pm
OR, you could just give them the number on your tag like the one I have circled in red here and they could give you the proper paint? This is from my ’99 but the number for the ’95 will also start with a “U”.
95 colors P1010012
perbe
95 colors Empty
PostSubject: Re: 95 colors   95 colors EmptyTue Jul 21, 2009 11:12 am
Thanks for the picture, I got tied up raising kids and other unimportant stuff last night.
This will be my first attempt at paint/body work and I would prefer to do at least an acceptable job the first time. I had about a 3x2 inch spot bubble and flake off the trunk lid. It looks like the last owner did a very poor patch of the same problem about 2 inches away. I will fix both at the same time. so the total area will be about 7 inches long and 3-4 inches tall. Any good online tutorials for doing paint touch up?
95 colors Empty
PostSubject: Re: 95 colors   95 colors EmptyTue Jul 21, 2009 12:48 pm
For two years now I've been taking an adult education (evening session) Auto Body class at our local Voc-Tech high school. I highly recommend this if you can find something like it in your area. There's nothing like having a body shop to work in with an experienced instructor helping out with the basics.
95 colors Empty
PostSubject: Re: 95 colors   95 colors EmptyTue Jul 21, 2009 1:48 pm
I have tried to do that for several years but things just haven't worked out. headbutt
perbe
95 colors Empty
PostSubject: Re: 95 colors   95 colors EmptyTue Jul 21, 2009 1:59 pm
not finding one here, the adult education for autos only goes into basic maintenance. Almost all of the DIY classes are computer classes these days.
95 colors Empty
PostSubject: Re: 95 colors   95 colors EmptyTue Jul 21, 2009 2:06 pm
Might have to travel into the BIG CITY to find a class.
95 colors Empty
95 colors
» Hatfeild trail colors vs Brimstone
» See Kovalev in Sens Colors Here
» TCM sticker colors
» EPI Secondary Spring weights/colors
» New Brooks Pure Project Colors
