I'm looking for this as well. Broke a few fixing my trim last week. I know there are two types used in the front. One has a hole for mounting fasteners, the other is coated black and inserts into a slot in the fender well lower front moulding.
The crash manual I have lists them and Monster Parts Online shows:
Part Number: 25639947...2/side Fender - Exterior trim - Wheel opng mldg - Retainer Rear 1995 - 1999/ List Price...$2.30/ Your Price...$1.37 Part Number: 25639946...7/side Fender - Exterior trim - Wheel opng mldg - Retainer Front 1995 - 1999 / List Price...$1.53/ Your Price...$0.91
I'm not sure why they say front and rear since they are both listed on the front fendertrim section? Front of the molding and rear of the molding maybe?
Thanks for the info, Randall. The 25639947 is the black tab clip. They go on the front edge of the fender, toward the bumper. The 25639946 must be for the others with holes. Not sure how they are arranged in the rear, but I thought I saw Phillips screws back there? Makes sense they'd all be 25639946 for the back.
Actually the wheel well molding is held on with clips all the way around, there is a screw towards the back that is for the rocker molding. Going to post about that in another thread.
99Rivman Aficionado
Name : Randall Location : North Carolina Joined : 2007-01-16Post Count : 2009 Merit : 89
I have searched and I am still unsure. I need the retainer clips that are used to attach the chrometrim to the front fender, both part number and where to buy. Also are they sold as a kit or each, and if each how many are there for each side?
Thanks guys......
They are sold by each. They are pretty cheap. Seriously, just go to the dealer. They are not cheaper by mail order due to the shipping. They are bagged 10 to a bag, there are 2 types (get 1 bag of each and you are probably set). Front retainer should be 25639947, rear should be 25639946. Front and rear refer to the clips' position in the wheel arch, not to whether they are fro the front or rear openings - both types are used in each opening. The 2 bags should run about $40. At the dealer you should be able to get them one by each if you want, too, for about $2.- each.
I do not remember how many go on each side and it does not really matter if you get a bag of each.
sqrivi Fanatic
Name : scott Location : madison, al Joined : 2008-03-15Post Count : 375 Merit : 52
Slide them in from the bottom of one side of the moulding rather than trying to snap them in or you will break most if not all.
99Rivman Aficionado
Subject: Re: FAQ: Fender Chrome Trim & Clips Sat Jul 25, 2009 10:04 am
Thanks guys......
List now is: Part Number: 25639947...2/side … $2.91ea Part Number: 25639946...7/side … $2.12ea
99Rivman Aficionado
Subject: Re: FAQ: Fender Chrome Trim & Clips Sat Jul 25, 2009 10:06 am
Some dealerships will let you order/sell you what you need and give you the whole bag! I had this happen at one dealership, they didn’t want to make a home for the leftovers! Others will not though, will make you BUY the whole bag?!?
Part Number: 25639947...2/side … $2.91 … need 4 … for both sides Part Number: 25639946...7/side … $2.12 … need 14 … for both sides
As others here will say, some dealerships will give discounts if you just ask! I usually get around 25% off of list from most of them. Albert is right about getting these at a dealership as apposed to mail order.
99Rivman Aficionado
Subject: Re: FAQ: Fender Chrome Trim & Clips Sat Jul 25, 2009 10:08 am
The plastic on these clips is VERY brittle! The placement of the clip is determined by where the holes in the inner wheel well are.
Subject: Re: FAQ: Fender Chrome Trim & Clips Sat Jul 25, 2009 4:03 pm
I need a few if anybody got stuck with a bag of them...
DEMonte1997 Aficionado
Name : Rick Age : 45 Location : CT Joined : 2009-03-03Post Count : 1429 Merit : 37
This might sound like a stupid question but does anyone know if the front fendertrim can be removed with the clips still in place? I don't want to break them again and have to order 24 more of them. I'm guessing they can with some careful pulling from inside the fender. Any experience would be MUCH appreciated.
Do you mean the inner splash shield? I do not think you can get the splash shield off with the clips in place.
The puller tool for the pushpin/clips is like $8. You can also pull the clips with pliers and a screwdriver.
Name : Aaron Age : 46 Location : C-bus, Ohio Joined : 2007-01-13Post Count : 18448 Merit : 251
Do you mean the wheel well arches?
You do have to remove the plastic clips with the pull-out centers before you can release the tabs on the 'chrome' itself. You shouldn't be breaking them, though, if you pull the center pin before trying to remove the whole clip... An easy way to get them started is to use a pair of dikes, parallel with the 'blade' of the center pin, and gently squeeze enough for the wedges to get under the head and start pulling the pin out. This is the same direction as that strange little 'tunnel' that points out to the edge of the clip on one side... Then you can grab the pin with your fingers and pull it out to its stop, or release-position, or just pull it all the way out and put it part way back in before replacing the clip in the car.
Does any one know if you can still buy the wheel well chrome moldings?
I bought one a few years ago, but things have been getting discontinued at an alarming rate, sold off to aftermarket suppliers that charge 3X what the dealer originally did...
The first & easiest thing to do is to write down your VIN, and take it to the closest GM dealer and have them look up the wheel arch moldings.
Name : Dave Age : 63 Location : In The AZ Oven Joined : 2007-01-17Post Count : 4502 Merit : 44
I stopped by a local GM dealer and ordered just the qty's needed. They were able to locate broken-bag pieces at a couple locations so I didn't have to buy full bags.
