| Wire Harness Help | |
xxsupergman25xx Aficionado
Name : Scotty Age : 37 Location : Pittsburgh, PA Joined : 2007-03-03 Post Count : 1251 Merit : 13
| Subject: Wire Harness Help Mon Jul 27, 2009 12:49 pm | |
| can someone do me a favor and take a picture of the wire harness that the cam sensor runs off of. its setting off the SES light. the guy in FLA put a bandaid on it and now when i start the car on any type of grade, it comes on. sometimes will come on while flat too. so if sum1 could take a pic of where it is and could go one step further and give me a link of where i can get one...that would be awesome. thanks guys | |
| Subject: Re: Wire Harness Help Mon Jul 27, 2009 1:11 pm | |
| The cam sensor wires go directly to the ignition control module. It would be a tricky thing to photograph on a fully dressed motor. Most of the harness is kind of hidden underneath the front accessories. | |
| Subject: Re: Wire Harness Help Mon Jul 27, 2009 2:00 pm | |
| ok..can u show me the wire harness i need to buy? i.e. at autoze, pepboys | |
| Subject: Re: Wire Harness Help Mon Jul 27, 2009 2:20 pm | |
| - turtleman wrote:
- The cam sensor wires go directly to the ignition control module. It would be a tricky thing to photograph on a fully dressed motor. Most of the harness is kind of hidden underneath the front accessories.
don't forget he's got a S1 engine - I have no idea what that harness looks like on a series I. I was about to answer your question then I realized it is for completely the wrong motor. Sorry. Can any of the series 1 guys help out here?? I'm pretty sure if you can get a new harness, it will only be from GM. You are better off looking for used. | |
| Subject: Re: Wire Harness Help Tue Jul 28, 2009 9:31 am | |
BillBoost37 Junkie
| Subject: Re: Wire Harness Help Tue Jul 28, 2009 9:51 am | |
| Best thing is to probably hit up a junkyard. On the S2's GM used the same harness from ICM to crank and cam sensors. Not sure if they did that S1 or not, if they did...it should be easy to get one at a JY. | |
99Rivman Aficionado
| Subject: Re: Wire Harness Help Tue Jul 28, 2009 12:40 pm | |
| I just so happen to be putting pulleys on a friends ’95, I’ll give you what I can. Pictures are a little blurry but I think you can get the routing from them. Best I can do, HTH | |
| Subject: Re: Wire Harness Help Tue Jul 28, 2009 3:10 pm | |
| that looks like a freakin pain lol
am i correct that i must do this from underneath the car? or all the pulleys and belts have to come off?
Last edited by xxsupergman25xx on Wed Aug 05, 2009 3:50 pm; edited 1 time in total | |
99Rivman Aficionado
| Subject: Re: Wire Harness Help Tue Jul 28, 2009 4:24 pm | |
| Done from above, here is the Svs Man instructions: The words "Remove or Disconnect" should be above where the red arrow points. Belts have to come off, and the water pump pulley. Have fun with it | |
| Subject: Re: Wire Harness Help Tue Jul 28, 2009 4:29 pm | |
| thanks a ton randall. ill have to see when i have time to get on this. hopefully it wont die until thenn lol..hasnt yet. | |
| Subject: Re: Wire Harness Help | |
