 A/C LEAK
senabunns
PostSubject: A/C LEAK   Wed Jul 29, 2009 4:00 pm
hey my a/c will not hold a charge for more than a day or so. i know you are suppose to get the kit to fill it up wit neon die and use the light to find the leak but before i start any of that was just wondering if maby anyone knew if there were any commin spots ware the a/c would be leaking from.
thanks
PostSubject: Re: A/C LEAK   Wed Jul 29, 2009 4:01 pm
Usually the compressor. I have a used one if you are interested. But fill it up with the dye just to make sure.
PostSubject: Re: A/C LEAK   Wed Jul 29, 2009 4:08 pm
Derek,
I'm interested in your used one if it fit's a 96 Riv.
PM me with cost and I'll pick it up.
senabunns
PostSubject: Re: A/C LEAK   Wed Jul 29, 2009 4:16 pm
so u think my compressor would be completely shot than.
PostSubject: Re: A/C LEAK   Wed Jul 29, 2009 4:21 pm
Mine dos not work anymore tho..
had the system filled up on start of month and now its empty.
seems that it had been leaking before i filled it up again.
leaks beside the compressor head where the pulley shaft goes into the compressor.
Need to replace a head gasket and change the bearing should be ok again after that.
A/C LEAK
