 So my asshole buddy cant close a door properly.
So my asshole buddy cant close a door properly. Empty
PostSubject: So my asshole buddy cant close a door properly.   So my asshole buddy cant close a door properly. EmptyFri Aug 07, 2009 12:28 am
we were leaving a place today...and he didnt close the door all the way. i gas it to make a uturn..and the door flies open. now the door doesnt close properly. i imagine he bent the hinges. like it opens and closes...but it must be catching on something near the where the edge where the door handle meets the body. im so pissed. any thoughts on how to fix this?
PostSubject: Re: So my asshole buddy cant close a door properly.   So my asshole buddy cant close a door properly. EmptyFri Aug 07, 2009 12:35 am
yes. eye the body lines where they meet. between the door and the fender. after determining where the gap is prouder, loosten the bolts. depending if the gap is wide at the top or the bottom. after loosening the bolts just bump the door back in place. and she should square right up. if this is unclear write back. but its a piece of cake
PostSubject: Re: So my asshole buddy cant close a door properly.   So my asshole buddy cant close a door properly. EmptyFri Aug 07, 2009 12:47 am
thanks for the quick response..knowing i dont need new parts will help me fall asleep tonight..
why loosen the bolts? why not tighten the other ones depending on the gap? wouldnt it be more secure?
PostSubject: Re: So my asshole buddy cant close a door properly.   So my asshole buddy cant close a door properly. EmptyFri Aug 07, 2009 12:48 am
also..why dont i need a new part? wouldnt it be bent/damaged if this happened? seems to good to be true lol
Merit : 91
PostSubject: Re: So my asshole buddy cant close a door properly.   So my asshole buddy cant close a door properly. EmptyFri Aug 07, 2009 12:53 am
That's what I'm wondering.
Sorry about your trouble mate. You ever wonder if people treated horses the way they treat cars, a hundred years ago? As important as a car is, it's hard to believe how little respect most people give them.
PostSubject: Re: So my asshole buddy cant close a door properly.   So my asshole buddy cant close a door properly. EmptyFri Aug 07, 2009 1:00 am
didnt they whip horses, put them in stables, feed em straw? both cars and horses got little respect lol
xxsupergman25xx wrote:also..why dont i need a new part? wouldnt it be bent/damaged if this happened? seems to good to be true lol
still need robo to answer that.
PostSubject: Re: So my asshole buddy cant close a door properly.   So my asshole buddy cant close a door properly. EmptyFri Aug 07, 2009 1:01 am
usually the door just torques out of its line. its a simple matter of realigning the body lines. the same thing happened to me but the guilty one was a gust of wind. and the door hinges are stout steel. they rarely bend.
PostSubject: Re: So my asshole buddy cant close a door properly.   So my asshole buddy cant close a door properly. EmptyFri Aug 07, 2009 1:03 am
gotta go poking around and be willing to loosen bolts,first the top,play with that,dont work? loosen the bottom and repeat
PostSubject: Re: So my asshole buddy cant close a door properly.   So my asshole buddy cant close a door properly. EmptyFri Aug 07, 2009 1:07 am
thanks again for the quick reponse ill give it a try 2morro.
with my luck im sure something went terribly wrong lol
Repped Robosampras
PostSubject: Re: So my asshole buddy cant close a door properly.   So my asshole buddy cant close a door properly. EmptyFri Aug 07, 2009 1:15 am
itl be fine
PostSubject: Re: So my asshole buddy cant close a door properly.   So my asshole buddy cant close a door properly. EmptyFri Aug 07, 2009 9:09 am
The hinges wouldn't bend, but either the door itself bent or the pillar the hinges are bolted to bent. My guess is the pillar, but either way there is some adjustment in the hinges, so you should be able to correct most of it.
Good luck!
PostSubject: Re: So my asshole buddy cant close a door properly.   So my asshole buddy cant close a door properly. EmptyFri Aug 07, 2009 1:34 pm
i must be dumb. i looked at it..there is more of a gap at the top. i loosened and tightened many things..made zero change. just have to add that to the list of shit that needs done.
PostSubject: Re: So my asshole buddy cant close a door properly.   So my asshole buddy cant close a door properly. EmptyFri Aug 07, 2009 1:42 pm
With the door in the fully open position pick up on the end of the door.
Does it move at all?
Bert tavis
PostSubject: Re: So my asshole buddy cant close a door properly.   So my asshole buddy cant close a door properly. EmptyFri Aug 07, 2009 1:58 pm
like theres nothing loose...its kinda hard to tell cuz the whole car moves when i pick up the door. lol
PostSubject: Re: So my asshole buddy cant close a door properly.   So my asshole buddy cant close a door properly. EmptyFri Aug 07, 2009 3:27 pm
if the gap is at the top loosen the top bolts. firmly push the top of the door,might have to give her a nice nudge, and close the gap. should work. if anything is bent i should be able to see that. cracked paint,bulging metal,puckering,...if nothing bent,just keep working it its a pia but you can fox it
Merit : 122
PostSubject: Re: So my asshole buddy cant close a door properly.   So my asshole buddy cant close a door properly. EmptyFri Aug 07, 2009 3:43 pm
scotty could probally lift up the whole side of the car... smile
PostSubject: Re: So my asshole buddy cant close a door properly.   So my asshole buddy cant close a door properly. EmptyFri Aug 07, 2009 3:49 pm
i tried that. that was the first thing i did..try and force it back. didnt see any bulgin metal. didnt see anything cracked. my car is going in for a coupler change and the cam sensor error next week or so. ill just say the door is sticking and have the guy loook at it.
funny u mention that karma.
me and my friends goal is to actually be able to pick up a front end and move a car. we figured if we can squat or deadlift 600 each..we could do it easily. i can only deadlift around maybe 300 calmly. maybe 350-400 with adrenaline ONE time. yay
Merit : 152
PostSubject: Re: So my asshole buddy cant close a door properly.   So my asshole buddy cant close a door properly. EmptySat Aug 08, 2009 12:35 am
Many years ago I drove a Mercury Lynx (basically a Ford Escort in a polo shirt). I went to a car wash and accidentally locked the keys in ti, running.
They guys working the car wash were local high school football players, and I was in pretty good shape too (I can still leg-press the entire stack of weights on a Nautilus machine). We picked the car up by its bumpers and carried it our of the wash lane until my dad could bring the spare keys out.
With the Riv you'd have to figure out how to get a grip on the bumper brace bars. And the Riv (~3600 lbs) weighs about twice what the Lynx weighed (~1800 lbs). I would not try it on the Riv at all, I do not thing the fun is worth the risk or aggravation.
Why not don't and say you did (JK)?
PostSubject: Re: So my asshole buddy cant close a door properly.   So my asshole buddy cant close a door properly. EmptySat Aug 08, 2009 1:20 am
oh no way in hell can i do this on the riv. i was supposed to put his car down in there..a cavalier. its a cool feat. not many people can say they did it.
Merit : 152
PostSubject: Re: So my asshole buddy cant close a door properly.   So my asshole buddy cant close a door properly. EmptySat Aug 08, 2009 2:11 am
It took four of us with 2 extras to spot. We lifted the car by the bumpers at the bumper mounting struts. The extras followed us at middle of each bumper in case of a problem but did not lift. I called cadence. We did straight snatch like in weightlifting, first locking arms straight then lifting car with legs. moved the car in shuffle steps, in careful unison, 6-8 inches per step, put it down in unison. Probably the only reason it worked is those football players knew how to lift and knew how to follow directions 'cause if someone screwed up it would probably have hurt.
PostSubject: Re: So my asshole buddy cant close a door properly.   So my asshole buddy cant close a door properly. EmptySat Aug 08, 2009 7:55 am
this reminds me of a funny story from the high school days - our youth group teacher always drove econoboxes, started back then with a Datsun 210... over the years moved up to a geo metro. anyway, one of our favorite gags was to turn his car sideways wherever he left it. Once, years and years after youth group was long ended, I went with a friend who had been in the group with us to visit him (hundreds of miles away). He had a garage with an opener, and was very proud that he had a place to park his car. We found the opener he had hidden in his kitchen, and in a time when he was busy, we opened the garage, turned his geo metro sideways, closed the garage and it was like nothing happened... Turned out he didn't try to go anywhere until two days later... That was one of the funniest phone calls I ever got. He got it out with a 17 point turn... lol
PostSubject: Re: So my asshole buddy cant close a door properly.   So my asshole buddy cant close a door properly. EmptySat Aug 08, 2009 11:59 am
haha! funnnnyy!
PostSubject: Re: So my asshole buddy cant close a door properly.   So my asshole buddy cant close a door properly. EmptySat Aug 08, 2009 12:30 pm
lol thats awesome.
Merit : 152
PostSubject: Re: So my asshole buddy cant close a door properly.   So my asshole buddy cant close a door properly. EmptySat Aug 08, 2009 12:33 pm
One thing that's Not Funny At All is something I heard while traveling, about people tipping Smart cars on their sides for fun.. Turns out they have a relatively high center of gravity; if you take advantage of that in a certain way you don't need help to tip them over. 2 or 3 people can easily do so.
Whatever you do, please don't do that, don't help do that and please actively discourage others from doing so as long as that discouragement does not endanger yourself. This is, however, very useful to know in case you need to defend yourself and one of those very light vehicles is involved somehow.
PostSubject: Re: So my asshole buddy cant close a door properly.   So my asshole buddy cant close a door properly. EmptySat Aug 08, 2009 1:08 pm
u can tell by lookin at them they have a high center of gravity. thats pretty messed up to do something like that
although i dont think the information is pertinent if one of those things is zoomin at 20 mph right at u, in this case...get the hell out the way.
» Cabelas Door Buster Sale ~ Garmin 60CSX $199
» Help with a shower door
» connecting buddy leads
» JR to JR buddy lead
» 2 door wooden cupboard for sale - brand new!
