| FAQ: Rims, Wheels that Look Good on the Riv | |
+139Calvin90 Rivieraz R1V 1T UP MaxLegroom carguy8888 nickwon DeepFrozen albertj Lmck3 ubushaus XCELLR8 jbird Animator Yoss ZEP 98riv jayeli ironclyde h20man Johnny5 llamalor2112 96_Juggernaut al_roethlisberger chitown_riv98 joshuadalegrimes 69GSColorado Sir Psycho Sexy Rivillac th3fr4nchi5e Z-type charlieRobinson bigdave matt270avian makemann1 LT1Squirrel highwaywarrior Rogerh11 The Roadmaster LARRY70GS Ultra16 Ron's Rocket Riv Karma RidzRiv Jason gmann3001 denim rivparadise BigRay1125 Riv95SC wee-one ghpcnm BlownRiv Eldo crlombardi69 EatDirtFartDust Cmurphy Bowersk flyineagle96 J. Chris Davis Abaddon Fastbuick95 BMD madrivage envus87 stan Tank krazyfish DEMonte1997 Hometown Hero TheAviator robotennis61 sburch23 No-Lift parrot5254 charged95riv manofmany L67 97 park ave StrictlyBusiness sqrivi 97rivsc patillac EASHER 1wickedninja curious riv captshiner Snowdog Rickw SuperRiv07 jamie KillaKeninaRiv riviera2454 deekster_caddy Chicken SamsSC Supercharged Steve98 ewolfe0050 Shintsu Joey98riv IBx1 ibmoses texasfan010 mr.19982tone palermocorey90 TonySmooth89 97Riv-Jon Buapo Archangel Ridin-Rivi oldsman105 mcgusto82 TradeMark Natesriv 97rivman RivMan 54_nailhead Rivster Rebekahssm T Riley ¤DoughBoy¤ SpaceBar mayfair4life187 dreww Jack the R 1998 Riv RhinoFLA AA jimmyriv bumpyknucks 99Rivman jax95riv SoCal Riv turtleman gosloriv Blowin95 Mr.Riviera racinfan xxsupergman25xx 143 posters |
New wheels for 95 Triple black?? | Yes | | 33% | [ 1 ] | No | | 67% | [ 2 ] |
| Total Votes : 3 | | Poll closed |
charlieRobinson Expert
| Subject: Re: FAQ: Rims, Wheels that Look Good on the Riv Mon Jun 08, 2015 9:25 pm | |
| ^^^^ not a bad chop at all. 5 star wheels are muscle to the max and they always look great on the Riv. | |
matt270avian Expert
| Subject: Re: FAQ: Rims, Wheels that Look Good on the Riv Mon Jun 08, 2015 10:20 pm | |
| I tried pulling the Cragars off of our Camaro and putting them on, but there wasn't enough offset. Need spacers.
Last edited by matt270avian on Mon Jun 08, 2015 10:38 pm; edited 1 time in total | |
| Subject: Re: FAQ: Rims, Wheels that Look Good on the Riv Mon Jun 08, 2015 10:33 pm | |
| - matt270avian wrote:
- I tried pulling the Cregars off of our Camaro and putting them on, but there wasn't enough offset. Need spacers.
The lug pattern isn't even the same.... | |
matt270avian Expert
| Subject: Re: FAQ: Rims, Wheels that Look Good on the Riv Mon Jun 08, 2015 10:37 pm | |
| - Abaddon wrote:
- The lug pattern isn't even the same....
They're the old school universal ones. They slid over the wheel studs but not all the way down to the hub because they hit the caliper. | |
| Subject: Re: FAQ: Rims, Wheels that Look Good on the Riv Tue Jun 09, 2015 11:14 am | |
| Anyone know how much factory wheel (not the chrome ones) and tire weighs?
Got 48 pound wheel+tire combos on the way. | |
th3fr4nchi5e Addict
| Subject: Re: FAQ: Rims, Wheels that Look Good on the Riv Tue Jun 09, 2015 8:25 pm | |
| Just weighed my stock 12 spokes with 225/60 Bridgestone Affinitys at 42.6-42.8 lbs each | |
| Subject: Re: FAQ: Rims, Wheels that Look Good on the Riv Wed Jun 10, 2015 12:28 am | |
| - th3fr4nchi5e wrote:
- Just weighed my stock 12 spokes with 225/60 Bridgestone Affinitys at 42.6-42.8 lbs each
Thanks for that! Dang. I was hoping to be closer to stocker weight Mine combo is 17.7lb wheel + 28lb tire = 45.7lb | |
matt270avian Expert
Sir Psycho Sexy Junkie
| Subject: Re: FAQ: Rims, Wheels that Look Good on the Riv Sat Jun 27, 2015 10:59 pm | |
| I think you might need some tires if you're going to do any good in autocross man! | |
matt270avian Expert
| Subject: Re: FAQ: Rims, Wheels that Look Good on the Riv Sat Jun 27, 2015 11:23 pm | |
| - Sir Psycho Sexy wrote:
- I think you might need some tires if you're going to do any good in autocross man!
THIS smartass...... | |
| Subject: Re: FAQ: Rims, Wheels that Look Good on the Riv Sat Jun 27, 2015 11:24 pm | |
chitown_riv98 Fanatic
Name : Ruben Age : 42 Location : Illinois Joined : 2008-03-10 Post Count : 399 Merit : 4
| Subject: Re: FAQ: Rims, Wheels that Look Good on the Riv Thu Aug 06, 2015 2:16 pm | |
- Just 4 rears, probably going to run 235/45/18s instead of the OEM 225/50/18s.
Hey Matt would they be the 18x7? Because I was thinking of these Bonneville gxp wheels but I think they are 18x8. Would they work? | |
matt270avian Expert
| Subject: Re: FAQ: Rims, Wheels that Look Good on the Riv Thu Aug 06, 2015 3:11 pm | |
| The Bonneville wheels look slightly different, but they will work just fine. All GXPs had 18x8 in the front 18x7 in the rear. The 18x8s have a different offset (22mm?) than the 18x7s (55mm?) so it brings them out. You would probably like the 18x8s a lot better than the 18x7s because they will end up a lot flusher to the fenders. GP guys have been running GXP 18x8s all around for years without issue, so you'll be fine. | |
| Subject: Re: FAQ: Rims, Wheels that Look Good on the Riv Fri Aug 07, 2015 1:14 am | |
| That's good news , thanks Matt. I wasn't sure if it made a difference with the rims hitting the caliper because of the offset. My buddy smashed his 04 Bonnie gxp and gave me a rim and 3 tires so I'm going to start hunting on ebay | |
matt270avian Expert
| Subject: Re: FAQ: Rims, Wheels that Look Good on the Riv Fri Aug 07, 2015 7:42 am | |
| - chitown_riv98 wrote:
- That's good news , thanks Matt. I wasn't sure if it made a difference with the rims hitting the caliper because of the offset. My buddy smashed his 04 Bonnie gxp and gave me a rim and 3 tires so I'm going to start hunting on ebay
Yep, they'll clear just fine. The 18x8s SHOULD also clear the Brembo 4 pistons off of the CTS-V, as well as the 6 pistons if you use a spacer. It might not be a bad idea to grab the spare from his GXP because it is bigger and has more clearance than our stock spare in case you ever decide to go bigger. His front brakes will also bolt right up and use a 12.7" rotor VS the stock 11.9" as well as a dual piston caliper VS the stock single piston. However, these brakes will not clear the OEM Rivi wheels/spare. | |
XCELLR8 Amateur
Name : Kent Age : 55 Location : Central IL Joined : 2015-10-09 Post Count : 26 Merit : 0
| Subject: Re: FAQ: Rims, Wheels that Look Good on the Riv Mon Oct 19, 2015 8:30 pm | |
| I would like to see some pictures of Riviera with different wheels. I went through all 60 pages and while a few pictures remain, most are no longer up for viewing. I am looking at getting some different wheels and wanting to see the different styles on the Riviera. Doing the google search gets me lots of pictures with dubs or bigger. Thanks | |
llamalor2112 Junkie
Name : Evan Age : 31 Location : Granite Falls, WA Joined : 2012-07-13 Post Count : 852 Merit : 13
| Subject: Re: FAQ: Rims, Wheels that Look Good on the Riv Tue Oct 20, 2015 2:12 am | |
| Mine...though they're long long out of production A mag mockup I did... and I love wires on the riv... | |
matt270avian Expert
| Subject: Re: FAQ: Rims, Wheels that Look Good on the Riv Tue Oct 20, 2015 7:12 pm | |
| I wonder what the GP gold rims with all the spokes would look like.... | |
XCELLR8 Amateur
| Subject: Re: FAQ: Rims, Wheels that Look Good on the Riv Wed Oct 21, 2015 5:44 pm | |
| These are great looking wheels and I'd be interested in what they are also. | |
jbird Fanatic
Name : Jeff Location : Cleveland area Joined : 2013-11-11 Post Count : 364 Merit : 6
| Subject: Re: FAQ: Rims, Wheels that Look Good on the Riv Wed Oct 21, 2015 8:32 pm | |
| It is the calendar cover car. "69GScolorado" He lists the wheels as MSR Black Chrome wheels
Jbird | |
matt270avian Expert
| Subject: Re: FAQ: Rims, Wheels that Look Good on the Riv Wed Oct 21, 2015 9:10 pm | |
| There was a member on here a few years ago that won the calendar cover 2 or 3 years in a row (snowdog I believe?). I absolutely love his rims, even the paint is amazing. | |
XCELLR8 Amateur
| Subject: Re: FAQ: Rims, Wheels that Look Good on the Riv Thu Oct 22, 2015 9:09 am | |
| - jbird wrote:
- It is the calendar cover car.
Jbird Thank you. | |
XCELLR8 Amateur
| Subject: Re: FAQ: Rims, Wheels that Look Good on the Riv Thu Oct 22, 2015 9:11 am | |
- There was a member on here a few years ago that won the calendar cover 2 or 3 years in a row (snowdog I believe?). I absolutely love his rims, even the paint is amazing.
I like those rims also. | |
| Subject: Re: FAQ: Rims, Wheels that Look Good on the Riv Thu Oct 22, 2015 1:46 pm | |
When Snowdog (Timo) got those rims from his father I asked about them. Wanted to buy a set over here. They were only available in European countries. To have a set shipped to the US was way too much money. But they are nice looking rims. | |
| Subject: Re: FAQ: Rims, Wheels that Look Good on the Riv | |
