| Car Trouble | |
3.8 Riviera Amateur
Name : Tyre Location : La Joined : 2009-05-26 Post Count : 44 Merit : 1
| Subject: Car Trouble Wed Aug 12, 2009 6:57 pm | |
| Omg guys.....The Riviera is acting up... I need your opinions.....So I moved the car today and it started up fine.....it moved and everything. I just tried to start it up and I believe the battery died on me... ...This what happened.....I turned the key and no crank....all the gauges looked dim.....and the odometer gauge lights were flashing.....for a little while and came back on.... I heard a little rattle under the hood....The only reason I can think of is the battery?.....any other experiences u guys? | |
| Subject: Re: Car Trouble Wed Aug 12, 2009 7:22 pm | |
| What is the battery voltage reading with key off.? You can test voltage reading from under hood connector on passenger side fender well or go directly to battery under rear seat. Then check with key ON. Report results. | |
| Subject: Re: Car Trouble Wed Aug 12, 2009 7:38 pm | |
| You can also try turning on your headlamps with the key on. Are they bright or dim? And what's the Battery voltage under a load.? | |
| Subject: Re: Car Trouble Wed Aug 12, 2009 7:51 pm | |
| - 3.8 Riviera wrote:
- I heard a little rattle under the hood....The only reason I can think of is the battery?.....any other experiences u guys?
Have you looked at the belts. Specifically the accessory belt driving your alternator. Is it still on, is it slipping at all? | |
| Subject: Re: Car Trouble Wed Aug 12, 2009 9:01 pm | |
| Sounds like a weak battery and you need a jump start. How long has it been sitting? What is the voltage before you jump it and after it is running? | |
| Subject: Re: Car Trouble Wed Aug 12, 2009 10:16 pm | |
| If voltage is below 10.5V, try jumping and see if it holds a charge. If not, replace battery.
If you still have the problem with flashing gauges, check the headlight bulbs. Have you upgraded the headlamps with aftermarket? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
#1BearsFan Enthusiast
Name : Bill Location : North Carolina Joined : 2008-07-28 Post Count : 231 Merit : 4
| Subject: Re: Car Trouble Thu Aug 13, 2009 1:13 pm | |
| Must be something goin' around.... I just had to replace my battery yesterday... Got in on Tuesday... barely started. Pulled the seat, cleaned the terminals (battery still showed green in window), started up and took an hour drive. On the way back, stopped at my mechanics place and again barely started. Had my mechanic test... failed load test. Battery was only able to hold 10.7v. $127.00 later I was rollin with a new battery. Broke and happy.... | |
| Subject: Re: Car Trouble Thu Aug 13, 2009 10:33 pm | |
| - #1BearsFan wrote:
- Must be something goin' around....
I just had to replace my battery yesterday... Got in on Tuesday... barely started. Pulled the seat, cleaned the terminals (battery still showed green in window), started up and took an hour drive. On the way back, stopped at my mechanics place and again barely started. Had my mechanic test... failed load test. Battery was only able to hold 10.7v. $127.00 later I was rollin with a new battery. Broke and happy.... if you had the original battery, it was about time. Albertj | |
| Subject: Re: Car Trouble | |
| Car Trouble | |
