 Hi! New Owner of a 96 riv with an L67 supercharged engine
sdconcepts
Hi! New Owner of a 96 riv with an L67 supercharged engine Empty
PostSubject: Hi! New Owner of a 96 riv with an L67 supercharged engine   Hi! New Owner of a 96 riv with an L67 supercharged engine EmptyTue Aug 18, 2009 6:55 am
I just bought my 96 Riv from a little old lady with 111000 miles on clock. i know she did some preventative maintenance but i want to make sure the car is safe to drive before i start modding. i will do a full tuneup this weekend and i will check the brakes, suspension and steering. is there anything else i should look for?
thanks
Jerry
http://www.sdconcepts.com
Merit : 111
PostSubject: Re: Hi! New Owner of a 96 riv with an L67 supercharged engine   Hi! New Owner of a 96 riv with an L67 supercharged engine EmptyTue Aug 18, 2009 7:24 am
At 111,000 miles I would detension the belts and check all the pulleys for any play, you are checking for loose bearings (side to side movement) and rotate the pulleys and check for any grinding feeling in the bearings.
At 100,000 miles it is common for these pulleys to go bad. When they fail they will disintegrate very soon after you start to hear noise and in most cases they will take a belt out with them and strand you on the side of the road.
You'll be able to tell if any of them have already been replaced by looking at them. If they appear to be original then plan on replacing all of them with the belts.
There is a very good Write Up on here for that job. It can be a pain to do but well worth it.
I had one pulley start to make noise and changed only that one because it was easy to get to, then within a couple of weeks I had two others making noise. To do all of them at once with the belts will cost you a little less than $200.00. That write up has a picture of all the pulleys and thier locations and the Dayco P/N's for the pulleys - can be cross referenced for Gates or NAPA.
Just click on the "Write Ups" tab on top of this page.
Also change the Supercharger oil. GM says it never has to be changed (bullshit).
So if the previous owner was having it serviced by the dealer then it more than likely never has been changed and is over due. Look in the Write Up section for the procedure and use the GM or equivalent SC oil (8 oz.).
Last edited by Rickw on Tue Aug 18, 2009 9:30 am; edited 3 times in total (Reason for editing : Fix typo)
PostSubject: Re: Hi! New Owner of a 96 riv with an L67 supercharged engine   Hi! New Owner of a 96 riv with an L67 supercharged engine EmptyTue Aug 18, 2009 8:43 am
Does the car have a supercharger? If so it's in your best interest to check the level of the supercharger oil. This is one of the most overlooked maintenance items, and you can suck the old oil out and replace it, or just top it off. I would recommend sucking it out and replacing.
You can get new SC oil from the dealership in 4 oz bottles, but get 2 bottles if you are doing a full change.
Merit : 111
PostSubject: Re: Hi! New Owner of a 96 riv with an L67 supercharged engine   Hi! New Owner of a 96 riv with an L67 supercharged engine EmptyTue Aug 18, 2009 8:46 am
Derek,
Read the title of his post....it includes the word supercharged and also read the post i made above. Recommended the replacement of SC fluid.
PostSubject: Re: Hi! New Owner of a 96 riv with an L67 supercharged engine   Hi! New Owner of a 96 riv with an L67 supercharged engine EmptyTue Aug 18, 2009 8:47 am
oops there it is, sorry I missed it. I read quickly and it was the only thing I didn't see.
» The Owner and his CEO...
» Newcastle owner Mike Ashley takes Rangers stake to almost 9%
» Nadayu 28 (Direct Deal with Owner, with pictures)
» WARNING to DEFAULTERS
» Inside the Mostyn Funship 30 years on!
