 problem with Eddie Blattner's table modifier
Merit : 124
PostSubject: problem with Eddie Blattner's table modifier   Tue Aug 18, 2009 4:13 pm
If I try to import my MAF table and log data, and export the new table, it doesn't show any FT information and therefore doesn't make any changes to it.
I'm using HPT
Anyone come across this problem?
PostSubject: Re: problem with Eddie Blattner's table modifier   Tue Aug 18, 2009 5:22 pm
Are you exporting your tables as .csv? IIRC there are a few other tables to load as well, not just MAF.
Merit : 124
PostSubject: Re: problem with Eddie Blattner's table modifier   Tue Aug 18, 2009 8:00 pm
yes, I'm exporting .csv
There doesn't seem to be any problem with anything. The imports and exports go fine. The product has no change from the original maf table and the report that it creates with it has all blanks in the LTFT and STFT fields.
I see you can put in a VE table too but I didn't think you need that to work on the maf and I don't see why the lack thereof would cause FT values to spontaneously disappear.
It did try importing my VE table and it doesn't like it for some reason.
PostSubject: Re: problem with Eddie Blattner's table modifier   Tue Aug 18, 2009 8:15 pm
Can you send me your log data or post it somewhere?
There are settings in the 'export' as well - like what fuel trim cells to make the export for, or maximum percentage to change, or whether to include STFTs in the changes etc.
Now that I've done a lot of MAF tuning, when I'm just tuning MAF I don't bother with the table modifier. For tuning timing and VE it's worth using, but I triple check the changes it's going to make too.
Merit : 124
PostSubject: Re: problem with Eddie Blattner's table modifier   Wed Aug 19, 2009 12:01 am
How could I send you my logs?
PostSubject: Re: problem with Eddie Blattner's table modifier   Wed Aug 19, 2009 6:51 am
post them to scandepot, or just email it to me. If you don't still have my email address, pm me.
Merit : 124
PostSubject: Re: problem with Eddie Blattner's table modifier   Sat Aug 22, 2009 12:37 am
