 89 riv
89riv
89 riv Empty
PostSubject: 89 riv   89 riv EmptySat Aug 22, 2009 8:52 pm
89 riv Empty
PostSubject: Re: 89 riv   89 riv EmptySat Aug 22, 2009 10:26 pm
Check your voltage and make sure your battery connections are clean and tight (check BOTH ends of the cables).
89riv
89 riv Empty
PostSubject: Re: 89 riv   89 riv EmptySun Aug 23, 2009 12:58 am
voltage is around 12 with the igition on, Ill check the connection of the cables that does make sense. I should look for the obvious first.
89 riv Empty
PostSubject: Re: 89 riv   89 riv EmptySun Aug 23, 2009 7:05 am
Also try jumping it from another vehicle. Just clicking with no crank could be low voltage too.
89riv
89 riv Empty
PostSubject: Re: 89 riv   89 riv EmptyMon Aug 24, 2009 1:30 am
The cable going to the starter was loose, we tightened it and it was barely cranking so we replaced the starter. It works fine now,
89 riv Empty
PostSubject: Re: 89 riv   89 riv EmptyMon Aug 24, 2009 7:28 am
nice car. i love the regal wheels on there
89riv
89 riv Empty
PostSubject: Re: 89 riv   89 riv EmptyMon Aug 24, 2009 12:32 pm
Thanks! Yeah they look alot better than the spoke hub caps lol. They only bad thing is that they didnt come with center caps, and the only place I can find them is from GM. There only 20 a piece though, not to bad.
89riv
89 riv Empty
PostSubject: Re: 89 riv   89 riv EmptyMon Sep 14, 2009 1:35 am
Anyone know where I can get the chrome impact strip around the car re chromed? Its not in great shape.
Merit : 91
89 riv Empty
PostSubject: Re: 89 riv   89 riv EmptyMon Sep 14, 2009 2:00 am
Google "chrome restoration." I see a couple places.
I had some small stuff chromed by Holley Carbuerators once but I don't know if they'll do big stuff. Not sure I'd recommend them either.
89 riv Empty
89 riv
