 FAQ: Vacuum Hoses & Lines (Series II SC)
PostSubject: Re: FAQ: Vacuum Hoses & Lines (Series II SC)   Thu Mar 06, 2008 12:43 am
i know they eventually dry out and crack.
silicone vac lines are supposed to resist heat better. I might use them when I do my intake because most of the vac lines will have to come off anyway and I know I will break a few.
PostSubject: Re: FAQ: Vacuum Hoses & Lines (Series II SC)   Thu Mar 06, 2008 7:24 am
RhinoFLA wrote:
.....the rubber Tee I was using .....
Are you sure it's rubber? Hard plastic maybe? I should be able to find you a hard polypropylene replacement at work, if you want to try one. (on the house)
PostSubject: Re: FAQ: Vacuum Hoses & Lines (Series II SC)   Fri Mar 07, 2008 6:16 pm
Sorry for the late reply. No Matt, it's the one near the boost bypass canister. It just looked dried out and some pieces had fallen off.. i'm pretty sure it's rubber, it's quite flexible.
It's the T with the zip tie on it.
Sag
PostSubject: Re: FAQ: Vacuum Hoses & Lines (Series II SC)   Sat Mar 08, 2008 4:52 pm
I made mine wit a brass fitting and brake lines some work but will work forever.
PostSubject: VACUUM LINES   Mon May 05, 2008 5:12 pm
where do i purchase them??? the dealer told me im nuts pretty much!!!........ but i need the ones that go to the Lower intake manifold and to the throttle body.... just the connectors......... need help ASAP
PostSubject: Re: FAQ: Vacuum Hoses & Lines (Series II SC)   Mon May 05, 2008 5:59 pm
If you are talking about the "T" fittings by themselves the dealer is right, they are not available from anyone! The only way they sell them is the whole assembly, it is called a Vacuum Harness. It comes with the two "T" fittings and the straight one on one end and the 90* on the other end and all of the lines in between. Around $20 so not too expensive just a pain to get them! The straight and the 90 are available from Advance in their help stuff but not the "T's"
qprint
PostSubject: cant identify vacuum thingy   Wed Jul 16, 2008 1:44 pm
I saw a 1/2" rubber vacuum hose cracked and after I pulled it to replace it, I saw a small 1 inch plastic thing with a hose connector on each end. it has a metal wire mesh inside it. I dont know what direction this connector goes .
A vacuum hose from the top of the engine connects to a metal bent rod [8 inches length] towards the driver side down to near the bottom of the rad into this vacuum connector, connects to a rubber hose and into a large 5 inch round item.
If i had a diagram, it would help me
I have 1996 SC 3800 II Rev
PostSubject: Re: FAQ: Vacuum Hoses & Lines (Series II SC)   Wed Jul 16, 2008 3:27 pm
It sounds like the vacuum line to the brake booster. A picture would certainly help...
lionfish
PostSubject: Re: FAQ: Vacuum Hoses & Lines (Series II SC)   Wed Jul 16, 2008 3:35 pm
The round 5” item on the driver’s side is the vacuum modulator on the 4T60E transmission.
I went to Advance Auto Parts to find some new plastic connectors after my vac lines crumbled. For my non-supercharged engine, I purchased a plastic T connector with two 3/8” and one ¼” port, a 3/8” to ¼” plastic adapter for the modulator connection, a ¼” to 3/16” plastic adapter for the fuel rail, two feet of ¼” fuel line for the modulator, one foot of 3/8 fuel line for the throttle body connection, one foot of 3/16 fuel line for the fuel rail connection.
qprint
PostSubject: Re: FAQ: Vacuum Hoses & Lines (Series II SC)   Fri Jul 18, 2008 12:51 pm
vacuum modulator looks like mine
Which direction is it installed ?
large or small port towards vacuum hose running to top of engine ?
lionfish
PostSubject: Re: FAQ: Vacuum Hoses & Lines (Series II SC)   Wed Jul 23, 2008 12:17 pm
The port with notch in it points down in my car. It is connected to a 1" piece
of hose that is connected to the vacuum modulator.
96Super
PostSubject: Need a vacuum diagram   Tue Aug 11, 2009 3:47 pm
I have searched all over, and can't find the basic Vacuum diagram anywhere. I changed my Super Charger, and now need to figure out the vacuum lines to finish.
Thanks,
Newb - Tony
96Super
PostSubject: Re: FAQ: Vacuum Hoses & Lines (Series II SC)   Tue Aug 11, 2009 3:55 pm
Looks like that is only a list of parts to purchase. I'm just looking for a pic, or scanned image of the vacuum line routing. Just so I can go start my car back up today.
Thanks again
Merit : 100
PostSubject: Re: FAQ: Vacuum Hoses & Lines (Series II SC)   Tue Aug 11, 2009 3:59 pm
did you change out the supercharger with another one from a 96 or is i a newer design?
on our 96's we have a different vac tree since we need a line going to the transmission. you will probably have to rig up a new design like tonysmooth did when he swapped out his blower for a P&P.
...maybe he can post of pic of what he did you for?
PostSubject: Re: FAQ: Vacuum Hoses & Lines (Series II SC)   Tue Aug 11, 2009 4:03 pm
Thanks again
Yeh, I read your post to quickly and thought you needed a diaphram, not a diagram.
Sorry about that. i deleted my response.
If anyone has the Factory Manual for the 1996 it will show the proper hose routing.
I gather there isn't a decal on the radiator support otherwise you wouldn't be asking.
PostSubject: Re: FAQ: Vacuum Hoses & Lines (Series II SC)   Tue Aug 11, 2009 4:09 pm
Thanks again
I have the manual, but wont be able to look it up til much later tonight. So i should have an answer later on.
96Super
PostSubject: Re: FAQ: Vacuum Hoses & Lines (Series II SC)   Tue Aug 11, 2009 4:10 pm
Thanks again
I'm surprised. There is not even a drive belt diagram
96Super
PostSubject: Re: FAQ: Vacuum Hoses & Lines (Series II SC)   Tue Aug 11, 2009 4:12 pm
L67 wrote:
Thanks again
That would be awesome!! Did you buy the shop manual from the dealer? How much was it? I'll probably buy one since I plan on keeping this for 100k or so
PostSubject: Re: FAQ: Vacuum Hoses & Lines (Series II SC)   Tue Aug 11, 2009 4:14 pm
Again, available in the FSM.
If you plan on keeping the car you might want to look at buying a set of Factory Manuals from EBay used. They come up for sale often.
You can expect prices to be between $30.00 and $50.00.
I bought a set within a week of buying my car and they have been invaluable.
PostSubject: Re: FAQ: Vacuum Hoses & Lines (Series II SC)   Tue Aug 11, 2009 4:15 pm
Go to EBay Motors and then look for manuals, IIRC.
PostSubject: Re: FAQ: Vacuum Hoses & Lines (Series II SC)   Tue Aug 11, 2009 4:22 pm
It's under Parts and Accessories, then drop down tab to Manuals
96Super
PostSubject: Re: FAQ: Vacuum Hoses & Lines (Series II SC)   Tue Aug 11, 2009 5:03 pm
Well, I paid a subscription to alldatadiy.com The good news is I have 2 diagrams I need. The bad news is the new S/C did indeed come from a 1999 engine. So... I am now missing the 3-tree of vacuum lines (Manifold Vacuum Source) Do you know how I can get around this? Can I use a "T" type connector and use the extra vacuum from the blank (Dead center of the S/C getting vacuum from the throttle body?
96Super
PostSubject: Re: FAQ: Vacuum Hoses & Lines (Series II SC)   Tue Aug 11, 2009 5:12 pm
Here is a visual:
Photobucket
or is that is not working:
http://illiweb.com/fa/pbucket.gif
96Super
PostSubject: Re: FAQ: Vacuum Hoses & Lines (Series II SC)   Tue Aug 11, 2009 5:13 pm
Correction, in the picture above it would be Number 4
PostSubject: Re: FAQ: Vacuum Hoses & Lines (Series II SC)   Tue Aug 11, 2009 5:18 pm
Is that diagram from a '99 or '96? My '98 does not look like this. It has a T under the s/c snout and the line from the MAP sensor continues around from there to the F/P regulator to the BBV.
Page 2 of 8Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
