peev0021 Amateur
Name : steve Location : ottawa Joined : 2008-11-05 Post Count : 23 Merit : 0
| Subject: SES and running cold Sun Aug 30, 2009 9:12 pm | |
| I switched to a 160 deg stat this summer and it was working well keeping the temps away from the red, but now with the colder weather in canada and the gauge is only reading roughly 55 to 60 deg C. And my SES light is coming off and on perodically, and was woundering if thats too cold to be running and if it is caused by the cold engine temp. | |
| Subject: Re: SES and running cold Sun Aug 30, 2009 9:24 pm | |
| You should not run a 160 thermostat unless you have a way to reprogram the PCM for it. Switch to a 180 and your problems should go away. It can affect a lot of operating parameters, and the computer thinking the engine is not warmed up yet. | |
| Subject: Re: SES and running cold Mon Aug 31, 2009 12:00 am | |
| I don't think there's any reason to run a 160º except for track use. Switch to 180º and maybe your SES will go out, but it could be an unrelated issue. I used to run the 160º in my Series II engine, never tripped a code or light. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
peev0021 Amateur
| Subject: Re: SES and running cold Tue Sep 01, 2009 3:12 pm | |
| thanks, ill try and switch it this weekend | |
| Subject: Re: SES and running cold | |
