 indy newb
IndyRivi
indy newb Empty
PostSubject: indy newb   indy newb EmptySun Sep 06, 2009 11:31 am
Hi from indy.
Looking at purchasing a GM employees 99 diamond white riv with tan int this friday (payday) and its pretty cherry.
Just wanted to introduce myself. Are there any other members in Indiana?
krazyfish
indy newb Empty
PostSubject: Re: indy newb   indy newb EmptySun Sep 06, 2009 11:47 am
Welcome to the board!
Im not from Indiana, but a little south from Kentucky.
What part of Indiana you in? Indianapolis? Based on the name.
Ash
Ash
indy newb Empty
PostSubject: Re: indy newb   indy newb EmptySun Sep 06, 2009 11:58 am
Greetings.
I'm in Columbus, IN.
indy newb Empty
PostSubject: Re: indy newb   indy newb EmptySun Sep 06, 2009 12:03 pm
Congratulation on the find and welcome aboard.
Thats my favorite color.
Bert tavis
IndyRivi
indy newb Empty
PostSubject: Re: indy newb   indy newb EmptySun Sep 06, 2009 12:50 pm
yep I'm on the east side of indianapolis.
I did run it to my mechanic to run codes and it needs a fuel solenoid and a boost regulator or whatever those two things under the cover are. Looks like easy fixes but he said theyre hard to find.
Anyone know where I can find em?
indy newb Empty
PostSubject: Re: indy newb   indy newb EmptySun Sep 06, 2009 1:05 pm
If there are no driveability problems or symptons or SES light you might consider clearing the codes and see if they reappear before replacing any components.
How about the car....how many miles and how much?
Bert tavis
IndyRivi
indy newb Empty
PostSubject: Re: indy newb   indy newb EmptySun Sep 06, 2009 1:19 pm
my mechanic, Darwin, cleared the codes but you can tell when you open the fuel door theres way too much pressure. as far as the boost controller, ill sit on it and see what happens I guess.
The car has 141k with a sunroof and factory chromies and maybe upgraded sound but im throwing in a new system. Shes was asking 3500 but she said she would take 3000. Seemed high at first but shes replaced the charger alternator and done all maintenance on it. Plus you have to love the feel of floating at 100mph
indy newb Empty
PostSubject: Re: indy newb   indy newb EmptySun Sep 06, 2009 1:39 pm
I would say buy it.
Be careful with aftermarket electronics, these cars dont like them.
In the "Write-Ups" at the top of the page you will find tons of info.
Bert tavis
indy newb Empty
PostSubject: Re: indy newb   indy newb EmptySun Sep 06, 2009 1:42 pm
I wonder if anyone has tried replacing the gas cap to make sure somehow that is not causing the problem. study
Bert tavis
Merit : 148
indy newb Empty
PostSubject: Re: indy newb   indy newb EmptySun Sep 06, 2009 2:31 pm
IF in fact you need those parts try monsterautoparts.com -or- a GM dealer. There are some later model GM cars using the same engine, engine parts for the 99s are not all unobtanium yet.
indy newb Empty
PostSubject: Re: indy newb   indy newb EmptySun Sep 06, 2009 5:51 pm
Albert, it's "monsterpartsonline.com" not monsterautoparts.com. They are an online discount GM dealer. I highly recommend them for GM parts.
IndyRivi
indy newb Empty
PostSubject: Re: indy newb   indy newb EmptySun Sep 06, 2009 6:19 pm
Bert tavis
Actually, theres a valve on the tank thats suppose to help regulate the pressure but we manually opened it and closed it without a prob, He then checked the wiring and found the part was defective.
Its helpful to have a good mechanic with free estimates smile
Merit : 111
indy newb Empty
PostSubject: Re: indy newb   indy newb EmptySun Sep 06, 2009 8:42 pm
Make sure you check all your local auto parts stores first for those item's. I've found NAPA to carry things that other auto parts stores told me were dealer only and vice-verse.
If you can post pic's of what you need I might be able to get you the GM P/N which will help your search on www.Monsterpartsonline.com greatly.
Sometimes they won't show a part as available but if you plug in the P/N then it will pop up as available. They're prices are generally 40 - 50% of retail for OEM GM parts. I've gone through them for many parts, sometimes it may take a week or more to receive the parts but if you can wait it's worth it.
For a 1999:
The Boost By-pass Valve (vacuum operated) GM # 1997244 (less than $25.00 at monsterparts)
I think the other thing you are talking about is the: Canister Purge Valve P/N 1997289 (less than $18.00 at monsterparts)
You'll need to verify these are the parts you need before buying them.
One way I do it when I'm not sure what P/N I need is to go to my local GM dealer parts counter and ask to see the pictures of what it is I think I need (play dumb) and he rotates the screen for me to see and then I ask for a print out of the part numbers because I can't afford to buy or order today. Then explain, when I come back we won't have to look up the numbers again and I can just order them by P/N. It also gives you a chance to see how much they cost from GM retail. Then I just take the part numbers and plug them in to monsterpartsonline.com search engine and voila.
You didn't say if you had an SES light on or not. I would think the canister purge valve would trip a light as it is part of the emission control system. But I don't know for sure. You did say your mechanic retrieved codes though. Do you know what those codes are. It would help determine the exact parts you need.
Merit : 148
indy newb Empty
PostSubject: Re: indy newb   indy newb EmptySun Sep 06, 2009 10:20 pm
thanks you are right, sorry indy I was in way too much of a hurry. monsterautoparts is not a site I have used. monsterpartsonline is a good site.
IndyRivi
indy newb Empty
PostSubject: Re: indy newb   indy newb EmptySun Sep 06, 2009 11:05 pm
For a 1999:
The SES light was on but I got the codes cleared so I dont know which ones they are anymore.
Once I get the car, I should be able to take a picture and post it
indy newb Empty
PostSubject: Re: indy newb   indy newb EmptySun Sep 06, 2009 11:28 pm
Sorry, chime'n late here. I live rigth outside Indianapolis in Plainfield. PRJ Performance is on the west side of town (close to New Palestiene). I think there is another member from Greencastle... Maybe we can get together at some of these small car shows around the area.
IndyRivi
indy newb Empty
PostSubject: Re: indy newb   indy newb EmptyMon Sep 07, 2009 1:14 am
Sounds good. Last show I was at was at Edward's Drive-In on the southside. It was an old school meet and they usually have a few lookers there over the weekends. Whatds PRJ specialize in?
indy newb Empty
indy newb
» Indy All Women's Half marathon Inaugural
» A new nighttime quarter/half/full marathon in Indy
» Selling my Indy Mini Bib - anyone?
» Indy trail runner died last Saturday at Eagle Creek
» Indy Mini- How to execute a perfect training run
