 S/C base gasket?
Pat_Czuba
S/C base gasket? Empty
PostSubject: S/C base gasket?   S/C base gasket? EmptyWed Sep 09, 2009 4:17 pm
Is there such a thing for the 95's? I was asked to grab one at NAPA AutoParts but they didn't have any listings?
PostSubject: Re: S/C base gasket?   S/C base gasket? EmptyWed Sep 09, 2009 4:20 pm
It might be part of an intake manifold gasket set, and not available separately. Otherwise you'd probably have to order one from the dealer or monsterpartsonline.com (discount online GM parts dealer), but either way won't be a quick pickup...
Pat_Czuba
PostSubject: Re: S/C base gasket?   S/C base gasket? EmptyWed Sep 09, 2009 4:28 pm
Thanks! My friend asked me because this weekend we are taking the super charger off and replacing the coupler because i just bought the kit... Also i'm going to clean / paint the supercharger and i guess my buddy was saying that i should look to see if i could get one incase whatever gaskets do... (leak?) Im still new to this we just don't want to run into any problems this weekend..
PostSubject: Re: S/C base gasket?   S/C base gasket? EmptyWed Sep 09, 2009 4:32 pm
If you are taking the S/C off, you'll definitely want a new gasket. The old one will probably tear when you take it apart.
Pat_Czuba
PostSubject: Re: S/C base gasket?   S/C base gasket? EmptyWed Sep 09, 2009 4:34 pm
Thought so... so you would suggest to me that i buy the kit u ur talking about?
PostSubject: Re: S/C base gasket?   S/C base gasket? EmptyWed Sep 09, 2009 4:37 pm
I'm not positive that the kit contains the gasket that you need... but usually an "intake manifold gasket set" contains everything necessary from the intake upwards, which should include the S/C gasket if the application is correct.
Pat_Czuba
PostSubject: Re: S/C base gasket?   S/C base gasket? EmptyWed Sep 09, 2009 4:39 pm
Alright, i'm gunna call a few more stores... thanks bud!
PostSubject: Re: S/C base gasket?   S/C base gasket? EmptyWed Sep 09, 2009 4:50 pm
The intake kit from Fel-Pro only has the LIM gasket and some other small stuff. It does not include the SC gasket, that's separate.
I would specifically ask when calling for gasket kits, what's included and more importantly what's not included.
Pat_Czuba
PostSubject: Re: S/C base gasket?   S/C base gasket? EmptyWed Sep 09, 2009 4:53 pm
I just caught the GM dealership in town before 5 and they said they had one in stock i can pick it up tomorrow morning... they said they ONLY found the base gasket.... lucky me! I definitely didn't want this to be postponed..... I'm also getting all the stuff in my signature done this weekend minus the rims... a little pre-emptive but i'm very exited about it
PostSubject: Re: S/C base gasket?   S/C base gasket? EmptyWed Sep 09, 2009 4:56 pm
Don't forget the SC gasket O-Rings in case they are not sold with the gasket.
Pat_Czuba
PostSubject: Re: S/C base gasket?   S/C base gasket? EmptyWed Sep 09, 2009 5:00 pm
I will rememmber to ask that when i pop in tomorrow, thanks!
PostSubject: Re: S/C base gasket?   S/C base gasket? EmptyWed Sep 09, 2009 5:03 pm
Good Luck and have some fun doing it.
woggy
woggy
PostSubject: Re: S/C base gasket?   S/C base gasket? EmptyThu Sep 10, 2009 9:59 am
the sc gasket is called the upper intake gasket and comes separate than the lim gasket. this upper kit (felpro) comes with the 2 yellow water jacket o rings
PostSubject: Re: S/C base gasket?   S/C base gasket? EmptyThu Sep 10, 2009 10:50 am
thanks for fixing up my info Rickw and woggy!
Merit : 62
PostSubject: Re: S/C base gasket?   S/C base gasket? EmptyThu Sep 10, 2009 1:28 pm
Yes the Fel-pro kit comes with the UIM gasket and the two O-rings...I just bought one Tuesday when I did my coupler. Part # MS95741 in case you need it.
PostSubject: Re: S/C base gasket?   S/C base gasket? EmptyFri Sep 11, 2009 3:26 am
Tell them Upper intake plenum.. it will show up..
S/C base gasket?
» football base
» Base Building
» Used - Cobra HG A 1500 Base-Load Medium Magnet Mount 300W CB Antenna
» JR base loaded TX arial.
» Sally Pearson might lose her track
