| tune success | |
L8-2BNGO Enthusiast
Name : Devin Age : 37 Location : Orlando Joined : 2009-03-28 Post Count : 135 Merit : 2
| Subject: tune success Thu Sep 17, 2009 12:02 am | |
| so with help from derek i got my tune almost in line. i just want to let anyone know who starts doing a tune. START WITH A VE TUNE!!!! it makes maf tunning soooo easy. after the ve tune. i make changes to my maf and they take effect instantly and stick.
it took me about a week of tunning everyday to get them in line so dont think it takes one day take your time | |
T Riley Guru
| Subject: Re: tune success Thu Sep 17, 2009 1:18 am | |
| - L8-2BNGO wrote:
- so with help from derek i got my tune almost in line. i just want to let anyone know who starts doing a tune. START WITH A VE TUNE!!!! it makes maf tunning soooo easy. after the ve tune. i make changes to my maf and they take effect instantly and stick.
it took me about a week of tunning everyday to get them in line so dont think it takes one day take your time Go dyno again!! | |
| Subject: Re: tune success Thu Sep 17, 2009 8:59 am | |
| nice job! i cant wait till we get my VE finished. i just with we could do it one cell at a time instead of whole changes with the table modifier. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
L8-2BNGO Enthusiast
| Subject: Re: tune success Thu Sep 17, 2009 12:03 pm | |
| yeah i dont know what was up with that, because when i got home it worked fine with my tune... one thing also. when i plugged my maf back in and when for a run of course my tune was off, but i was running really rich, like -10.9 ltfts @ WOT and i was seeing rediculous amounts of knock, but when i leaned out the table. which is now running 2.3 @ wot i only saw a blip of .5* at like 90 then it went away.
i know alot of people say that i lean condition is worse than a rich condition, but everytime ive had any significant amount of knock it was when i was running rich. and when i had been running lean i saw little to no knock. can someone explain that to me? | |
| Subject: Re: tune success Thu Sep 17, 2009 12:33 pm | |
| maybe the + and - are backwards on our cars with the DHP? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: tune success Thu Sep 17, 2009 12:37 pm | |
| It's known - too much fuel can cause knock too. I don't know the exact physics of why, maybe the additional fuel is taking up valuable combustion chamber space, effectively increasing your compression ratio?
Glad to hear you got the finals of the tune worked out! Congrats!! | |
L8-2BNGO Enthusiast
| Subject: Re: tune success Thu Sep 17, 2009 1:18 pm | |
| thanks man! couldnt have done it with out you! | |
L8-2BNGO Enthusiast
| Subject: Re: tune success Thu Sep 17, 2009 5:04 pm | |
| My car is almost tuned but I have a prob. When in idle when the car is hot the ltfts go to -22.6. I heard something bout a cat test or deleting the evap to stop this from happening has anyone heard this? | |
| Subject: Re: tune success Thu Sep 17, 2009 5:14 pm | |
| i've been looking it up on regalgs and it seems like the pcm is set to dump fuel at times to test the efficiency of the cat. this is normally done when hot at cruse or idle. Apparently there is a way to disable cat testing with a tuner, but i havent seen where to access that stuff with a dhp. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: tune success Thu Sep 17, 2009 5:15 pm | |
| from regalgs:
"Sounds like you're running into the cat test issue. On some 01+ cars without a rear O2, the cat test never finishes because it doesn't get feedback from the sensor, so it gets locked into test mode, pegging the LTFTs. There's not currently a way of disabling the test, although people have been requesting that HPT puts it in, as they do it for the V8s. The only solutions so far are to put in an O2 sim, or to flash an older bin to your PCM.
Edit for link: http://www.hptuners.com/forum/showthread.php?t=18516
did you look under engine>fueling>cot to see if there is something you can disable there? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: tune success | |
| tune success | |
