 Throttle Cable Adjustment?
bayarearivi
Throttle Cable Adjustment? Empty
PostSubject: Throttle Cable Adjustment?   Throttle Cable Adjustment? EmptySun Apr 08, 2007 5:01 pm
the throttle cable for my rivi seems to be either not adjusted right or broken. the gas pedal has no kind of leverage anymore and just kinda sit on the floor.
this is what it looks like.
Throttle Cable Adjustment? 2vct7hv
ive looked on a friend of mines rivi and on his cable , the black clip is closer to the little metal object on the left than mine is.
could it be my cable is too long?
gosloriv
gosloriv
PostSubject: Re: Throttle Cable Adjustment?   Throttle Cable Adjustment? EmptySun Apr 08, 2007 5:40 pm
Ha i was tryin to help u with this over at the reagalgs board.Did u look to see if its hooked up right the throttle body yet ?
PostSubject: Re: Throttle Cable Adjustment?   Throttle Cable Adjustment? EmptySun Apr 08, 2007 10:00 pm
What year/engine is your car?
bayarearivi
PostSubject: Re: Throttle Cable Adjustment?   Throttle Cable Adjustment? EmptyTue Apr 10, 2007 3:41 pm
95 buick riviera ..... i think i know what happened . do you see the goldish metal thing on the right. i think that popped through the firewall , either from the engine area or the inside of the firewall and thats why i have more slack in the inside
NO 4 EVR
NO 4 EVR
PostSubject: Re: Throttle Cable Adjustment?   Throttle Cable Adjustment? EmptyTue Apr 10, 2007 3:47 pm
I can't see much in that pic but I do see what you are talking about now. Hope its an easy fix
PostSubject: Re: Throttle Cable Adjustment?   Throttle Cable Adjustment? EmptyTue Apr 10, 2007 3:52 pm
I thought it was Paris Hilton. lol
NO 4 EVR
NO 4 EVR
PostSubject: Re: Throttle Cable Adjustment?   Throttle Cable Adjustment? EmptyTue Apr 10, 2007 3:53 pm
lol
» Is it possible to do away with the linkage setup on the side of a briggs and run your throttle cable directly to your carb?
» Do I have a govenor problem or a throttle problem?
» Carb adjustment
» Throttle and choke clarify please?
» Need some help in diagnosing a runaway throttle issues on 20hp v-twin
