 Would this work to fix a crack?
Would this work to fix a crack? Empty
PostSubject: Would this work to fix a crack?   Would this work to fix a crack? EmptySun Oct 04, 2009 3:22 pm
i think the name of it is JB welder? i have a crack in my front exhaust manifold would i be able to just apply this stuff? i know there is a cracked manifold topic....but i dont wanna take it off.
PostSubject: Re: Would this work to fix a crack?   Would this work to fix a crack? EmptySun Oct 04, 2009 3:44 pm
No
Bert tavis
Merit : 153
PostSubject: Re: Would this work to fix a crack?   Would this work to fix a crack? EmptySun Oct 04, 2009 3:53 pm
JB weld won't really work because of the heating/cooling. Coefficient of expansion is very different between that epoxy and cast iron (the manifold's material) so the epoxy tends to bust off or, if you get it bonded right, it'll cause breaking again nearby.
I imagine there might be an appropriate repair epoxy but I don't know what it is. IF I were you I would ask at a farm or industrial supply store, and if I remember right Scotty you're out in Cecil (near but not in Pittsburgh) so a counterperson or clerk in a Tractor Supply or an independent industrial supply store ought to have an answer for this one. I suspect that someone may have formulated a steel- or iron-filled epoxy that they claim works. But I'd ask someone whose livelihood depends somewhat on whether it works & you won't find such a person at a big-box discounter or home center.
PostSubject: Re: Would this work to fix a crack?   Would this work to fix a crack? EmptySun Oct 04, 2009 5:00 pm
wont work. ive tried. i took my headers down to meineke and got the cracks welded up for $20....
PostSubject: Re: Would this work to fix a crack?   Would this work to fix a crack? EmptySun Oct 04, 2009 5:22 pm
thanks guys
and no albert im in pgh. sum1 else is in cecil
Merit : 153
PostSubject: Re: Would this work to fix a crack?   Would this work to fix a crack? EmptySun Oct 04, 2009 11:14 pm
xxsupergman25xx wrote:
thanks guys
So sorry...
BTW you might consider contacting junkyards (Leetsdale comes to mind) - should not be hard to pull good exhaust manifold(s) off a car with 3800 that is otherwise headed for hte crusher, there are a LOT of them - Buick Regal, Pontiac GP, others from the late 80s up. They will know.
PostSubject: Re: Would this work to fix a crack?   Would this work to fix a crack? EmptyMon Oct 05, 2009 7:09 am
PostSubject: Re: Would this work to fix a crack?   Would this work to fix a crack? EmptyMon Oct 05, 2009 2:46 pm
thanks bert. but unfortunately the series one looks like this..
oo o
and series 2 looks like this
ooo
they arent interchangeable. it sux.
» Any one do body work or repainting?
» 2006 Work and Play for sale.
» Custom airbrush work?
» I am going to work on a property near Marble Bar. Detector in bag first.
» Need your collective brains to work for a minute guys.
