 to remove or not to remove, that is the question
woggy
woggy
to remove or not to remove, that is the question Empty
PostSubject: to remove or not to remove, that is the question   to remove or not to remove, that is the question EmptyThu Oct 15, 2009 2:14 pm
I just dropped my exaust to do a cat delete should I delete the resonator or leave it?
Will it make a very big difference in sound or performance with it removed?
Still using stock mufflers for now.
PostSubject: Re: to remove or not to remove, that is the question   to remove or not to remove, that is the question EmptyThu Oct 15, 2009 2:48 pm
Personally I would keep it since you will have unpleasant cruising drone without it. It will give you a raspier sound and a slight increase in performance but I don't believe its worth it.
Merit : 122
PostSubject: Re: to remove or not to remove, that is the question   to remove or not to remove, that is the question EmptyThu Oct 15, 2009 3:11 pm
I've heard of some people throwing in a glasspack in place of the rez. They seem to like it, I haven't really heard anything negative for it.
I have heard though, of drone with just removing the Rez.
PostSubject: Re: to remove or not to remove, that is the question   to remove or not to remove, that is the question EmptyThu Oct 15, 2009 3:24 pm
I agree with L67. If you remove it, things are gonna get louder during cruising.
Merit : 135
PostSubject: Re: to remove or not to remove, that is the question   to remove or not to remove, that is the question EmptyThu Oct 15, 2009 4:00 pm
Just leave it.
PostSubject: Re: to remove or not to remove, that is the question   to remove or not to remove, that is the question EmptyThu Oct 15, 2009 4:44 pm
karma wrote: a glasspack in place of the rez
yeah ,i read that somewhere too, that a glasspak in place of the rez sounds good while killing the drone and allowing better flow. if your going to be under there cherry bombs are cheap go ahead and replace the rez for one if you have the extra cash and let us know how it sounds.i think its a great idea..... if not, leave the rez. my Acura didn't have one and driving around with a hangover with the music full blast to cover the droning noise was annoying...
Merit : 153
PostSubject: Re: to remove or not to remove, that is the question   to remove or not to remove, that is the question EmptyThu Oct 15, 2009 4:57 pm
recommend you either leave the resonator in or replace it with the longest glasspack you can get that will fit... period...
» Can you remove Engine Counter Weights from a Briggs?
» Gearbox Pulley Impossible To Remove.
» How do I remove a stuck Transaxle Pulley?
» How do you remove stuck rear wheel hubs?
» The easy simple way to remove star post's
