| Cleaning carpeted floor mats | |
ibmoses Aficionado
| Subject: Cleaning carpeted floor mats Sun Oct 18, 2009 12:37 am | |
| The carpeted floor mats I had to clean were very dirty( 00 Regal) so I used all of the following methods to get them cleaned up like new. If yours are not very dirty all of the methods may not really be necessary. If you are obsessive/compulsive like me you may want to use all of the methods anyhow... Go to the local spray & wash so you can use the high pressure wand. Carry something small and heavy to sit on the edge of the mats so they dont blow away while you are using the high pressure wand. Get a can of the Tuff Stuff interior/carpet cleaner or any other chemical you like. Spray the mats liberally with the chemical and let it soak in for approx. 20 minutes. Dont let the mats sit in the direct sunlight while the chemicals soak in. You can scrub your tires and wheels while the mats soak... Use the high pressure washer to clean them after they have soaked for a while, its very simple. The next part was my wifes idea. Spray the mats with some Spray & Wash and fill the clothes washing machine with Hot water. Let them soak in the water however long you can, she let them soak all day. Then turn the machine on agitate for a minute or two and then set the machine to spin to get all of the water out. Fill the machine with cold water and then spin the water out. Use a fan or direct sunlight to dry them and then spray liberally with Downy. Bert | |
| Subject: Re: Cleaning carpeted floor mats Sun Oct 18, 2009 1:00 am | |
| Seems like an awfull lot of work for some mat's. Wouldn't it be easier to buy new, unless of course they were original GM. But then again I'm the one that put wire wheel hub caps in the dishwasher. (not without a scolding) Thanks for the tip's Burt, never thought of the Spray'n'Wash stuff. | |
ibmoses Aficionado
| Subject: Re: Cleaning carpeted floor mats Sun Oct 18, 2009 1:48 am | |
| The dishwasher came in handy during the restoration of the GS The method for cleaning the floormats is for the GM carpeted floor mats. After ten years they tend to be pretty filthy. Really no work involved, no getting down on your knees and scrubbing with a brush or any af that nonsense required. Bert | |
Name : Matthew Age : 37 Location : Florida Joined : 2007-01-18 Post Count : 4394 Merit : 101
| Subject: Re: Cleaning carpeted floor mats Sun Oct 18, 2009 2:05 am | |
| we do that at work too. I usualy spray them with a carpet degreaser/ citrus cleaner, then hit them with a pressure washer, and then use the steam cleaner to extract the extra water. works 9/10 times. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Cleaning carpeted floor mats Sun Oct 18, 2009 3:11 am | |
| does the color change (fading) when you do all this?
| Subject: Re: Cleaning carpeted floor mats Sun Oct 18, 2009 4:22 am | |
| I like the washing machine idea... Just one question: what's the Downy for? Do you drive barefoot? Just for the hell of it, I'll mention my own method for cleaning mats, area rugs, etc. I have a stiff-bristle push broom that's not too wide, maybe 14 or 15 inches, so it's not too much effort to use and it concentrates the force. I lay the carpet on the patio, soak it well with the hose, then sprinkle it with powdered Tide and scrub it in with the broom. After 10 minutes I re-wet it, give it another brushing, and then blast-rinse it with the hose nozzle and hang it up to dry. Takes maybe 20 minutes all told and works pretty well... For touch spots, Bissell makes an excellent fabric and carpet cleaner that is (naturally) getting hard to find: It was originally called Oxy-Kic, now I think it's Oxy-Pro. It is a twin-tank aerosol that combines when you press the trigger, and really does wonders. | |
ibmoses Aficionado
| Subject: Re: Cleaning carpeted floor mats Sun Oct 18, 2009 2:53 pm | |
| - albertj wrote:
- does the color change (fading) when you do all this?
Albertj You are correct(as always) the high pressure steam cleaner I used will cause slight color fade. A regular pressure washer like what one would use at the local car wash should not cause the color to fade(I dont think) Most of youse guys can probably get by with just using the washing machine method. The driver side mat is usually the worst(obviously) if you have to get aggressive cleaning it and cause it to fade you might want to use some paint to restore the color a little. The paint(dye) is available in spray cans and a light coat will do wonders....the front mats I cleaned were awful so I had to get aggressive with them and used the super hot steam pressure washer. Eldo: the Downy just makes them smell better, mine were stanking pretty bad. Bert | |
| Subject: Re: Cleaning carpeted floor mats | |
