| My '97 when I clean it... | |
+14albertj robotennis61 GMFreak8 flyineagle96 Mr.Riviera DEMonte1997 T Riley 99Rivman deekster_caddy stan BMD 1wickedninja IBx1 Eldo 18 posters |
GMFreak8 Addict
| Subject: Re: My '97 when I clean it... Fri Feb 26, 2010 5:27 pm | |
| - Eldo wrote:
- Mr.Riviera wrote:
- Very clean indeed!
is that a caddy horn on the fuse box?
Ding-ding-ding-ding, we have a winner!
When I got this car, before my Eldo went to heaven, I was not pleased with the "un-American" sound of the horns... Turns out that the OE horns are F and high-A, so I pulled the low-D out of the Cad and mounted it to a fender bolt in the Rivi. Now I have a "properly deep" D-minor chord. .
(BTW, if anyone's interested, I think ArmorAll sucks. That stuff I used on the engine cover and the intake plumbing is Stoner Trim Shine, the same thing I use on the gray/black rocker panels and air dams... It lasts a long time, gets more 'satin' after a while, and sprays on evenly with no wiping required usually - I highly recommend it.) . You mind doing a writeup or going into detail more on how you did the horn swap? I agree with you, the horn in the Riviera sounds like something you'd expect out of a toyota camry not an American car. I wanted to take the horn out of my old Park Ave from the 80s and put it in but never got around to it. I'd love to learn how you did the horn swap more. | |
| Subject: Re: My '97 when I clean it... Fri Feb 26, 2010 5:43 pm | |
| wow! that bay is cherry! how u manage to slow the car without a break pedal and find time to spiff her up is beyond me? | |
| Subject: Re: My '97 when I clean it... Fri Feb 26, 2010 7:46 pm | |
(BTW, if anyone's interested, I think ArmorAll sucks. That stuff I used on the engine cover and the intake plumbing is Stoner Trim Shine, the same thing I use on the gray/black rocker panels and air dams... It lasts a long time, gets more 'satin' after a while, and sprays on evenly with no wiping required usually - I highly recommend it.) . I added a low-C and a D. Turns out the OE horn circuit is more than adequate for 4 horns and it's not *that* hard to fit 2 horns onto each OE bracket. It's just loud (and dissonant) enough to be heard in city traffic and distinguished around booming car audio. Albertj Albertj | |
| Subject: Re: My '97 when I clean it... Fri Feb 26, 2010 8:06 pm | |
| So if you hear a D-Minor in your driveway, you know it's me... If it's a D-Minor- 7th, it's Albert. Kyle, there was really nothing more to the job then what I said... I just looked around the engine bay until I found a spot that had room for the horn and also had an existing bolt large enough to hold the horn bracket. I might have had to bend the bracket a little, but that's it... If you go to a wrecking yard, look under the hoods of some Cadillacs - the note of the horn is stamped into it (D). - robotennis61 wrote:
- wow! that bay is cherry!
how u manage to slow the car without a break pedal and find time to spiff her up is beyond me? You answered your own question. You have a lot more time to work on the car if you don't waste it by using the brakes all the time... | |
GMFreak8 Addict
| Subject: Re: My '97 when I clean it... Sat Feb 27, 2010 12:32 pm | |
| Subject: Re: My '97 when I clean it... Sat Apr 17, 2010 6:42 pm | |
| Sorry Kyle, I just found out that I never replied to your last questions: A> The horns are in the front fenders, ahead of the wheelwells, so rather than try to find the wires within the looms, I just undid the clips in the front half of the right well and Scotch-Lok'd onto the existing wire. B> No... Actually, as I said, you already have 2 different horns, the musical notes F and A. Adding low-D completes a D-minor chord, which is a 'natural' sound. C> Uhhhh, NO... | |
GMFreak8 Addict
| Subject: Re: My '97 when I clean it... Sat Apr 24, 2010 2:00 pm | |
| - Eldo wrote:
- Sorry Kyle, I just found out that I never replied to your last questions:
C> Uhhhh, NO... Thanks for the reply. I gotta do something. The horn on the Riv is downright pathetic. You can't even use it to get mad at someone, all you do is make them laugh and yourself turn bright red. I thought you'd like the Dixie horn thing. I'm not sure if it was mentioned before, but where abouts did you get the horns? | |
VJD2 Fanatic
Name : Vinny Location : Connecticut Joined : 2010-02-21 Post Count : 310 Merit : 5
| Subject: Re: My '97 when I clean it... Sat Apr 24, 2010 10:48 pm | |
| My stock horn sounds fine to me. Pretty decent and people get the point when I lay on it. | |
| Subject: Re: My '97 when I clean it... Thu May 20, 2010 11:07 pm | |
| - deekster_caddy wrote:
- Looks great. Definitely take some pictures with GG scenery in the background.
Well, here are my last Riviera-of-the-Month / 2011 Calendar pictures, probably my final California photos, period... I got the Bridge, the water, even Sutro Tower in the background - and I couldn't even reach the upper half of the road because the bloody thing was closed for construction when I drove up there! Not to mention the constant flow of tourists' cars... (and no, I didn't trailer it up there. ) As some of you know, I prefer "sleeper' mods", and I'd like to think that this car is not only electrically and mechanically better than stock, but right now looks better than it did in the showroom (including the underhood shots on page 2...) On a clear day, you can see General Motors...
T Riley Guru
| Subject: Re: My '97 when I clean it... Thu May 20, 2010 11:16 pm | |
T Riley Guru
| Subject: Re: My '97 when I clean it... Thu May 20, 2010 11:17 pm | |
| Lies.. i meant COVER of the 2011 calendar.. no voting needed.. i chose it. | |
| Subject: Re: My '97 when I clean it... Thu May 20, 2010 11:26 pm | |
| - 98riviera98 wrote:
- Lies.. i meant COVER of the 2011 calendar.. no voting needed.. i chose it.
most definitely in the calendar running! are those new corner lenses? _________________ 1996 with 254k miles, L32Â 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Wow, THANKS Travis... I hadn't even finished my post in the ROTM thread yet! | |
| Subject: Re: My '97 when I clean it... Thu May 20, 2010 11:27 pm | |
are those new corner lenses? Yes, a year or so ago... You can see them in the first photo on this thread. That's why I'm so finicky about cornering lenses! | |
| Subject: Re: My '97 when I clean it... Thu May 20, 2010 11:32 pm | |
| Looks like mine, but your interior may be a darker shade of grey. | |
| Subject: Re: My '97 when I clean it... Thu May 20, 2010 11:34 pm | |
| Jack: Nope, the dash-top is gray, and therefore my Dash-Mat, but the interior is the ubiquitous "Medium Neutral"... (Beige) | |
BMD Aficionado
| Subject: Re: My '97 when I clean it... Fri May 21, 2010 8:37 am | |
| You got a beautiful car, sunny California and the surf, does anyone else hear the Beach Boys? Sweeeet Mark, your car looks really sharp and exterior colour looks almost silver in these shots. It certainly looks like you take your time detailing your ride when you clean it (like me). | |
Sweepspear Fanatic
| Subject: Re: My '97 when I clean it... Fri May 21, 2010 11:46 am | |
| It looks fantastic! Do you have new headlight and cornering lamp lenses on that car? I've never seen any so clear. Headlights look like glass. (If they are glass I'd like to know where to get some.) | |
| Subject: Re: My '97 when I clean it... Sat May 22, 2010 12:23 am | |
| - BMD wrote:
- You got a beautiful car, sunny California and the surf, does anyone else hear the Beach Boys? ...It certainly looks like you take your time detailing your ride when you clean it (like me).
Would you believe that I bought it from a little old lady in Pasadena? (She's the terror of Colorado Boulevard...) Thanks, and yes, I spent 2 days scrubbing, detailing and 'waxing'... Actually, I use Rejex aircraft sealer after the paint and chrome are clean. It is one of the reasons I can go so long between washes: it makes it harder for dirt to stick, and easier to wash off. Then, Eagle One All Tire & Wheel cleaner to suck the brown dirt out of the tires, and Trim Shine on the rocker panels, air dams and the tires (after a few days driving, the tires get a more satin finish than in the photos.) - Sweepspear wrote:
- It looks fantastic!
Do you have new headlight and cornering lamp lenses on that car? I've never seen any so clear. Headlights look like glass. (If they are glass I'd like to know where to get some.) Thank you, too. The cornering lenses were replaced about a year ago (left) because the best I could get after working on them with Plastix was the one on the right... However, the headlights were evidently made out of a different plastic than so many of the mistakes that the industry made (including our own cornering lights, right next to them... The jackasses!) I replaced the driver's side, but the passenger side looks just as good, as you can tell on Page 1. Plus, it still has the black tube inside surrounding the end of the bulb, which the replacement lens lacks...
| Subject: Re: My '97 when I clean it... Sat May 22, 2010 12:26 am | |
| ye gads!@ dats 1 clean ride! i bet it would look even better with a sqrivi set up | |
Sweepspear Fanatic
| Subject: Re: My '97 when I clean it... Sat May 22, 2010 7:10 pm | |
| - Eldo wrote:
Thank you, too. The cornering lenses were replaced about a year ago, and this was after working on them with Plastix.... Ah! I see it's a Meguiar's product. I'm going to have to try it. For many years I have used Meguiar's Mirror Glaze plastic cleaner and polish. (The white & Blue bottles) While it works well, I have never seen results like that! | |
| Subject: Re: My '97 when I clean it... Sat May 22, 2010 10:58 pm | |
| - Sweepspear wrote:
For many years I have used Meguiar's Mirror Glaze plastic cleaner and polish. (The white & Blue bottles) While it works well, I have never seen results like that! Whoops, I have to clarify that Dale! I'll go back in and rephrase it, but I was saying that I put in new lenses because that lens on the right side of the photo was as good as I could get with the Plastix... The one on the left is the brand new lens.
| Subject: Re: My '97 when I clean it... Sat May 22, 2010 11:51 pm | |
| I want to get new ones also rather than trying to get all the yellow out. Mine are really yellowed and just need replacing. What were they, about $100.00 for the pair. I want to get a pair, so when I have the car detailed and buffed out I can replace those and have it looking real clean. The body shop I go to is top shelf and pricey, but he owes me some work, so I'm going to have this years door dings taken care of and some touch up here and there. It's due. | |
Sweepspear Fanatic
| Subject: Re: My '97 when I clean it... Sun May 23, 2010 11:40 am | |
| Yeah, I read that wrong. That's what I get for gleaming a post quickly. | |
| Subject: Re: My '97 when I clean it... | |
