 FAQ: O2 (Oxygen) Sensor Information
FAQ: O2 (Oxygen) Sensor Information - Page 3 Empty
PostSubject: Re: FAQ: O2 (Oxygen) Sensor Information   FAQ: O2 (Oxygen) Sensor Information - Page 3 EmptyMon Jul 19, 2010 10:36 pm
Not sure if it was said before but unless you need the parts right at that instant, I'd shop online for them. Denso O2s are probably the best (better than Delco, IMO) and you can get them online for $40. As for a MAF, I'd just hit up Morad. I'm sure he'd sell a low mileage OEM one for a fraction of whatever NAPA wants.
GL
PostSubject: Re: FAQ: O2 (Oxygen) Sensor Information   FAQ: O2 (Oxygen) Sensor Information - Page 3 EmptyMon Jul 19, 2010 11:06 pm
How about a used N* TB and LQ4 MAF.
Would you recommend used from Morads or just buy new from ZZP.????
PostSubject: Cheapest place to buy a non-universal O2 sensor for our cars?   FAQ: O2 (Oxygen) Sensor Information - Page 3 EmptyWed Nov 03, 2010 1:01 pm
I poked around rockauto and found a Denso O2 sensor for pretty cheap. Put the part # into google and found it for $35/shipped from Amazon. This seems way too good to be true. A buddy of mine just fell into this sort of situation and what he ordered was a universal. He said it had to be spliced onto the existing pigtail.
For AC Delco, I found the part # AFS109: Saw it for REAL cheap on ebay as cross-listed for a Chevy Express van?? suspect Link
^^ That can't be right...
For Denso, I found part #234-4018 but I think that is the universal. http://www.amazon.com/Denso-234-4018-Oxygen-Sensor-Ratio/dp/B000C5WCOA
Anyone else order one of these sensors recently? I'm looking to save some $$ frown
Merit : 152
PostSubject: Re: FAQ: O2 (Oxygen) Sensor Information   FAQ: O2 (Oxygen) Sensor Information - Page 3 EmptyWed Nov 03, 2010 2:05 pm
It *could* be right; there are some "direct fit" sensors that fit a family of applications (same # of wires and same plug on the pigtail) but the pigtails are different *lengths*. What you end up doing is lashing the extra pigtail length up onto itself with zip ties, near the plug (not near the sensor) end.
Derek
PostSubject: Re: FAQ: O2 (Oxygen) Sensor Information   FAQ: O2 (Oxygen) Sensor Information - Page 3 EmptyWed Nov 03, 2010 3:09 pm
The Denso sensor part# 2344018 that you listed shows on rockauto as an 'oe type', plus if you click more info it shows a pic of the connector end. I don't think that is a universal. Can't help with the Ac Delco but if you call your local dealer they should be able to give you a correct part number and possibly cross-reference it for you. Good luck.
Merit : 152
PostSubject: Re: FAQ: O2 (Oxygen) Sensor Information   FAQ: O2 (Oxygen) Sensor Information - Page 3 EmptyWed Nov 03, 2010 3:40 pm
For my $$ I'd buy the Denso, worst case is there will be some extra wire to cinch up.
PostSubject: Re: FAQ: O2 (Oxygen) Sensor Information   FAQ: O2 (Oxygen) Sensor Information - Page 3 EmptyWed Nov 03, 2010 4:09 pm
I saw the info pic too Derek and thought it was too good to be true. lol
Thanks for the help guys. Going to grab one now. smile
Merit : 62
PostSubject: Re: FAQ: O2 (Oxygen) Sensor Information   FAQ: O2 (Oxygen) Sensor Information - Page 3 EmptyWed Nov 03, 2010 4:23 pm
Rick - I recently had to order one as well, but I did it through Advance Auto. I don't remember the price, but the part number on mine was #234-4012 . I don't know how different that is from '4018', but I hope that helps a bit.
-Andrew Z
Derek
PostSubject: Re: FAQ: O2 (Oxygen) Sensor Information   FAQ: O2 (Oxygen) Sensor Information - Page 3 EmptyWed Nov 03, 2010 6:11 pm
Andrew that part # is for the 95 model, 97 appearently is different. I'm not sure what's different but the delco and bosch also use different part #s for each so its definitely not a typo. We're actually lucky in that ours are cheaper.
Merit : 62
PostSubject: Re: FAQ: O2 (Oxygen) Sensor Information   FAQ: O2 (Oxygen) Sensor Information - Page 3 EmptyWed Nov 03, 2010 7:28 pm
My apologies - One of the few times I've ignored which year car I was looking at.
PostSubject: Re: FAQ: O2 (Oxygen) Sensor Information   FAQ: O2 (Oxygen) Sensor Information - Page 3 EmptyThu Nov 04, 2010 2:09 pm
Rock-auto confirmed that it is direct plug and play. I have a Denso on the Regal and it reads much more accurately than the stock Delco.
As an aside-do NOT get a Bosch. I've seen a half dozen cats go bad shortly after changing over to one of those sensors. They don't seem to jive well with this GM setup. :/
PostSubject: Re: FAQ: O2 (Oxygen) Sensor Information   FAQ: O2 (Oxygen) Sensor Information - Page 3 EmptyFri Mar 18, 2011 10:29 pm
So I'm thinking of getting an O2 sensor. I was planning on getting either AC Delco or NGK. Both seem to get good reviews and both are available at the parts desk up here. People here seem to swear by Denso, which is only available up here online. Also, NKG are 20% off this weekend at a part source up here, any opinions?
PostSubject: Re: FAQ: O2 (Oxygen) Sensor Information   FAQ: O2 (Oxygen) Sensor Information - Page 3 EmptyFri Mar 18, 2011 10:42 pm
The AC delco I paid top $ for @ the dealer, shows its running lean with my scanner.Not being a diagnostician at all, I dont know what that means except it aint worth shit.when I had my Acura,I bought many NGK parts and not one ever failed. plugs wires etc..all super reliable. I didnt even know that NGK made for the Riv. I would take a chance on the NGK
PostSubject: Re: FAQ: O2 (Oxygen) Sensor Information   FAQ: O2 (Oxygen) Sensor Information - Page 3 EmptySat Mar 19, 2011 12:02 am
got a denso in the riv and have had no problems. very responsive sensor, but it was replacing a 150k mile sensor so i dont really have a new "other" brand to compare it to.
FAQ: O2 (Oxygen) Sensor Information - Page 3 Dsc_0110
PostSubject: Re: FAQ: O2 (Oxygen) Sensor Information   FAQ: O2 (Oxygen) Sensor Information - Page 3 EmptyThu Dec 05, 2013 9:55 pm
So we should see the O2 in the 9s at WOT and around 4.5 when chilling?
< 4.5 and you are rich. less O2 and more fuel
> 4.5 and you are lean. more O2 and less fuel
Is that right?
Please educate me.
Thank you.
96_Juggernaut
96_Juggernaut
Name : Todd Balestrini
PostSubject: Re: FAQ: O2 (Oxygen) Sensor Information   FAQ: O2 (Oxygen) Sensor Information - Page 3 EmptyThu Dec 05, 2013 10:12 pm
Damn... Recently installed a Bosch sensor..
PostSubject: Re: FAQ: O2 (Oxygen) Sensor Information   FAQ: O2 (Oxygen) Sensor Information - Page 3 EmptyThu Dec 05, 2013 10:22 pm
@charlie
No. You have it backwards.
< 450mV you're lean
> 450mV you're rich
Lean means you have too much air and not enough fuel.
Rich is the opposite...not enough air, too much fuel.
At WOT, your O2 should read between 800mV-850mV.
Anything really above 850mV is considered too rich.
Anything under 800mV might cause a lean condition.
At idle, your O2 is going to be bouncing around everywhere. You can see the changes being made by watching STFT. The leaner you are, the more positive STFT goes, and the more rich, it goes negative. You can watch both of those numbers simultaneously on a scanner and see exactly how it works.
PostSubject: Re: FAQ: O2 (Oxygen) Sensor Information   FAQ: O2 (Oxygen) Sensor Information - Page 3 EmptyThu Dec 05, 2013 10:37 pm
Thank you very much.
Yeah, I had it backwards. I thought the higher the O2 value the more oxygen in the mix = lean.
Merit : 91
PostSubject: Re: FAQ: O2 (Oxygen) Sensor Information   FAQ: O2 (Oxygen) Sensor Information - Page 3 EmptyWed May 21, 2014 11:10 pm
I've got a code P0141 "O2 Sensor heater circuit bank 1 sensor 2."  What part do I need to get and what do I have to do to replace it?
PostSubject: Re: FAQ: O2 (Oxygen) Sensor Information   FAQ: O2 (Oxygen) Sensor Information - Page 3 EmptyThu May 22, 2014 7:14 am
I would check the wiring and connector for O2 sensor downstream of the cat converter before replacing anything. Road debris can contact the sensor, causing this code.
PostSubject: Re: FAQ: O2 (Oxygen) Sensor Information   FAQ: O2 (Oxygen) Sensor Information - Page 3 EmptyTue Nov 25, 2014 3:29 pm
I went ahead and did my manifold sensor today. Took all of 20 minutes (minus the time for PB to soak in). I used an O2 sensor socket that I borrowed from the mechanic up the street, and doing this job without it would suck. A lot. Here's pictures of the setup I used (socket, universal, long extension, medium extension) as well as the old and new sensors.
FAQ: O2 (Oxygen) Sensor Information - Page 3 2014-114
FAQ: O2 (Oxygen) Sensor Information - Page 3 2014-115
FAQ: O2 (Oxygen) Sensor Information - Page 3 2014-116
Merit : 91
PostSubject: Re: FAQ: O2 (Oxygen) Sensor Information   FAQ: O2 (Oxygen) Sensor Information - Page 3 EmptyMon Dec 22, 2014 10:55 pm
Finally got around to looking at the sensor - it looks clean as a whitle, no problems anywhere that I can see.  I'm looking at replacements on RockAuto and there are several available with a wide range of prices ($25-$81).  More importantly, we have UPSTREAM and DOWNSTREAM to choose from.  Which one should I get (97 SC  wink )
Once again the error code is "code P0141 "O2 Sensor heater circuit bank 1 sensor 2."
Just to be 1001% certain about this - the sensor I looked at looked like the one in matt270avian's post above, and was between the catalytic converter and the resonator.
KnottyEagle
KnottyEagle
PostSubject: Re: FAQ: O2 (Oxygen) Sensor Information   FAQ: O2 (Oxygen) Sensor Information - Page 3 EmptyMon Dec 22, 2014 11:09 pm
You'll need an UPSTREAM sensor and Denso is the way to go.
PostSubject: Re: FAQ: O2 (Oxygen) Sensor Information   FAQ: O2 (Oxygen) Sensor Information - Page 3 EmptyMon Dec 22, 2014 11:11 pm
Denso is the way to go. Sensor 2 means it's the post-cat sensor, but you might as well do both since they're not to expensive. Might be cheaper on Amazon.
KnottyEagle
KnottyEagle
PostSubject: Re: FAQ: O2 (Oxygen) Sensor Information   FAQ: O2 (Oxygen) Sensor Information - Page 3 EmptyMon Dec 22, 2014 11:25 pm
Oops. Read right over "sensor 2".
Page 3 of 6Go to page : Previous  1, 2, 3, 4, 5, 6  Next
» Important Information
» some information for you Harrogate Town supporters upon your journey to The Shay - FC Halifax Town
» Beginner Needing Information on Sluicing
» Interesting Information Regarding Knee Injury Prevention
» How to wire up a Low Oil Sensor.
