 setting the idle
blackrose613
setting the idle Empty
PostSubject: setting the idle   setting the idle EmptyMon Dec 07, 2009 8:08 am
Is there a way to set the "in gear" idle?
When the car is in park or neutral, it idles fine, right around 1k when warm and about 1200 when cold.
however, when the care is in drive and I am at a stop, the idle drops to about 600. this is way to low IMO. I think it should be around 800-850.
Is there a way to reset just this idle?
PostSubject: Re: setting the idle   setting the idle EmptyMon Dec 07, 2009 8:20 am
These are the normal settings. On '96-up Rivieras you can set the idle to different values with a computer and tuning software. The software runs $300-400.
For '95 Rivs I don't think there is any tuning software available.
More info: http://rivperformance.editboard.com/series-ii-engine-transmission-f4/cold-temps-high-idle-t2036-15.htm
blackrose613
PostSubject: Re: setting the idle   setting the idle EmptyMon Dec 07, 2009 8:31 am
thanks for the info Aaron!
Merit : 153
PostSubject: Re: setting the idle   setting the idle EmptyMon Dec 07, 2009 11:30 am
Yep. Leave it alone.
PostSubject: Re: setting the idle   setting the idle EmptyMon Dec 07, 2009 9:09 pm
if i recall, the 96+ s/c cars have the warm idle rpm set at like 650. why do you think this is too low?
Are you getting a vibration or surging?
If so you should take a look at the trans and motor mounts and make certain there is no vac leak.
setting the idle Dsc_0110
blackrose613
PostSubject: Re: setting the idle   setting the idle EmptyWed Dec 09, 2009 6:30 am
Ive checked/replaced all the vac lines. I am getting a vibration so old/broken mounts are prolly to blame. I am pretty sure I have at least 1.
I just felt it was a little low. most of the other cars I own/owned had a warm idle around 750 when in gear. my durango and my GP are like that.
setting the idle
» Gpx 4000 setting help
» Boost setting with your 4500
» Newby needs some setting advice on a Garrett AT Pro
» What are the best setting to run a GPX 4000 in the PIlbra with a 11 dd coil
» gpz7000 cant use extra deep with severe soil setting (VIC type soil) ?
