| FAQ: Steering Column Slop, Problems & Replacement | |
+639ty7rivi EyeDoc1 Yardley kylan_13 sloppyriv brutusk1 Z-type 71stagegs edward harmon matt270avian premature jack jbird ratnfested billfrank85 JOE RIV 1 GreenJeanS stan laddieboy1 al_roethlisberger saintsnsinners 2000ws6transam Karma nvsteve Spin Derek GreenMonster 97SC_CALI_RIV turtleman jenkkijussi moldymac Mr.Riviera Abaddon Eldo Mikel ibmoses robotennis61 Rickw deekster_caddy albertj sburch23 99Rivman BMD duster_do_little SuperRiv07 skuchin LARRY70GS Steve98 ewolfe0050 Jack the R SC95Riv rivcop heyzelchi AA racinfan ¤DoughBoy¤ SpaceBar zebster okiedrifter 96 pearl rivi on 22's jax95riv 1998 Riv NO 4 EVR HirohataMerc 67 posters |
2000ws6transam Enthusiast
Name : steve Age : 47 Location : Indy Joined : 2011-10-29 Post Count : 181 Merit : 6
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Thu Apr 26, 2012 2:58 pm | |
| ahh, ok i have to replace body isolator pads from time to time on a school bus, working on cars is no longer hard lmao. i assume they are the same on the aurora? i use to be a good CNC machinist lol wish i had access to all that stuff still... i bored out T/Bs 75mm to 82-84mm and drilled my own rotors | |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Sat Aug 18, 2012 4:26 am | |
| It looks like my update from this morning didn't take...
- FYI, the Permatex Bearing Mount for Worn Parts that I used on the right-hand tilt-pin 2 years ago, on page 9, failed about a month ago. After pulling everything apart again, there was literally nothing left of the material that I had coated the pin with...
- After my careful considerations last time, this time I decided the hell with it: I just smeared a nice blob of JB Weld across the lower side of the ear and over about 1/3 of the end of the pin... There is very little sideways force on that pin, compared to the up & down force that eats away at the metal and the Permatex, and if I need to get back in there for any reason I can still chip the JB away.
(Also, this time I left out the lower 2 screws from the column covers so I can get back in without removing the dash panel...) | |
saintsnsinners Member
Name : Thomas Joined : 2013-02-06 Post Count : 67 Merit : 5
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Thu Feb 21, 2013 8:26 am | |
| So I'm kinda fuzzy can I pull the knuckle and upper column from a 97 aurora to replace a broken knuckle on my 97 riviera? | |
al_roethlisberger Junkie
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Mon Apr 01, 2013 10:51 pm | |
| No surprise, but I've got this same minor play in my 95 and then found this thread Great and very helpful into... so I'll add this to the "list" of things to look into over the coming weeks/months as I work out the minor bugs. Thanks for the great write up! Al | |
laddieboy1 Special
Name : laddieboy1 Location : Commerce City Joined : 2013-04-14 Post Count : 2 Merit : 0
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Sun Apr 14, 2013 1:23 pm | |
| Just purchased a very nice "63 Riv. Has a Goodwrench 350 w/ th400 trans. Also got the 401 Nailhead if anyone is interested. The tilt is FUBAR'ed , wheel goes in all directions (should'a seen me dirve it home, lol). After a day of just trying to disengage it from steering rod, I'm at a loss. Is there a schematic out there on this beast ? Is it similar to other Riv's I see discussed here ? Also, is there a way to repair drivers door switches, drivers window switch doesnt make contact inside of plastic box. Thanks to everyone for any info on these problems. | |
| Subject: temp Sun Apr 14, 2013 9:49 pm | |
| Wow....a 63 Riv?post pics immediately. | |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Sun Apr 14, 2013 9:54 pm | |
| Post them in the Showroom, please. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Thu Apr 18, 2013 6:12 pm | |
| - laddieboy1 wrote:
- Just purchased a very nice "63 Riv. Has a Goodwrench 350 w/ th400 trans. Also got the 401 Nailhead if anyone is interested. The tilt is FUBAR'ed , wheel goes in all directions (should'a seen me dirve it home, lol). After a day of just trying to disengage it from steering rod, I'm at a loss. Is there a schematic out there on this beast ? Is it similar to other Riv's I see discussed here ? Also, is there a way to repair drivers door switches, drivers window switch doesnt make contact inside of plastic box.
Thanks to everyone for any info on these problems. There isn't a whole lot of 60's Riviera discussion here, we are mainly 90's and some 80's Riv owners. Not trying to send you away, but you should try the ROA (Riviera Owners Assoc) forums on the AACA website. TONS of 60's Riv owners there to help you out. Although they won't think highly of that GM 350 under the hood... Plus you will likely find a buyer for the 401 is you really don't want to keep the orig engine (if it is). | |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Wed May 01, 2013 10:59 am | |
| Somewhere back in this thread someone had asked/wondered if any other make/model had the same steering column setup as the Riviera. Well, while I was at a salvage yard, I saw a late 90s Park Avenue and it had a similar setup as ours with the rectangular alloy "box" and side pins. The Park Avenue setup was a bit smaller than ours overall, but definitely of the same general design.
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Wed May 01, 2013 11:04 am | |
Al Thx for the input, but it's definitely not the same. I did a P/N cross reference a while ago (further back in this thread). The Aurora is the ONLY vehicle that shares the upper housing with ours. | |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Sun Sep 22, 2013 10:29 pm | |
Checked mine out while I was replacing the turn-signal multi-switch today. My slop is on the left side, but very minor. Some people who aren't really sensitive to these sorts of things might not even notice. However, my pins seemed quite tight and the slop seemed to be on the inside, where the pin seats in the inner bracket. Since the pins weren't backed out, there wasn't really much I could do unless I pulled them apart like AA did and machined a new part. Given mine is pretty minor and the pins seem tight, I'll just leave it alone for the foreseeable future. If it gets worse, I can look into a solution like AA did I guess. Al | |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Sun Sep 29, 2013 4:09 am | |
| I think you're probably right to let well enough alone - If it ain't broke...
My own column, since I use the tilt every time I get in or out of the car, had the pins walking out of the outer ears as well as wearing out the inner races. | |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Sun Sep 29, 2013 9:42 am | |
| If it doesn't bother you, I'd leave it alone. Inspecting it was a good idea. After fixing mine, I almost never change the wheel position out of fear it will wear the pin holes again! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Sun Sep 29, 2013 9:01 pm | |
| Yeah, I rarely adjust mine..... which I'm sure helps.
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Mon Sep 30, 2013 1:25 pm | |
| I doubt that simply adjusting the tilt position has caused all the problems we've had. If it's done properly, with one hand on the wheel at 12 or 6 to hold it from smacking against the stop, I don't see why it would wear much at all. Poor design to have it spring loaded so heavily, if you ask me.
BTW, I had to have my whole column replaced a couple years ago, as the aluminum framework itself was all broken up. I got lucky, the dealership quoted a couple hundred bucks to FIX the wheel slop. Once they took it apart and things FELL apart in their hands, they sourced a good used column and ate the cost difference. At 6'4" I need to move the wheel up and down. | |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Mon Sep 30, 2013 1:37 pm | |
| I agree, Dave, that adjusting wheel tilt won't cause the problems to the extent that you've seen. I think adjusting the tilt angle does encourage loosening of the pins just enough so that one falls out - further damage is caused from daily use - steering while driving with just one pin in place. The wheel will then tilt up/down even without engaging the release button, wearing out the receiving hole in the casting. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Wed Oct 02, 2013 5:27 am | |
| - 1998 Riv wrote:
- I doubt that simply adjusting the tilt position has caused all the problems we've had. If it's done properly, with one hand on the wheel at 12 or 6 to hold it from smacking against the stop, I don't see why it would wear much at all. Poor design to have it spring loaded so heavily, if you ask me.
I certainly agree about poor design, though I think the problem is mainly in the materials they chose - MORONS! The spring is the least of the problems. As I've said elsewhere, it's almost unbelievable that these rectangular columns (which are about TWICE as big as the original round tilt columns from '65 or '66) can be so damned delicate... Between my Grand Am & Eldorado I've put over a quarter-million miles on 2 'regular' round tilt-columns without anything wearing out or breaking!! I just want to add that in my own Rivi - with the pins reinstalled and "glued over" with epoxy - my column seems to like me to hold the wheel at about 1:30 and pull down lightly before I pull the tilt lever... | |
GreenJeanS Rookie
Name : GreenJeanS Joined : 2010-10-01 Post Count : 14 Merit : 0
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Sun Feb 02, 2014 3:17 pm | |
| I am currently in the middle of this tear down/repair. I have everything apart but found out that one of my pivot pins is missing. The upper and lower housing are both in good shape. I just need a replacement pin but have been unable to locate a part number or retailer that offers them for my '97 riviera. | |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Sun Feb 02, 2014 4:09 pm | |
| Your pin is missing because the holes are enlarged from wear and the pin fell out. It's probably under your dash or seat. A new pin would also be loose and will fall out. I had a machinist measure the holes with gauge cylinders and turn a new set of pins for a tight friction fit. Still good now after a few years. See earlier pages in this thread for the write-up. Good luck. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
GreenJeanS Rookie
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Sun Feb 02, 2014 4:46 pm | |
| Thank you for the reply. I did see your post earlier w/ custom pins. Unfortunately the pin is not in the car anywhere. I do not have access to a machinist and I am not to concerned with the pin coming out again as I plan to get rid of the car once drivable. Are stock pin replacements not available, is that my problem? | |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Sun Feb 02, 2014 6:27 pm | |
| I'm pretty sure it's sold as a steering column assembly, and likely only used ones now exist. Problem is, replacing the entire assembly is a pretty big job. I may still have my old pins in the garage. I'll check. But the empty hole is enlarged, so the pin will likely fall right out. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
GreenJeanS Rookie
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Mon Feb 03, 2014 9:29 pm | |
| thanks again for getting back to me. If you find those pins and are willing to sell them to me that would be awesome! In the mean time i will be actively looking for a machinist that can cut me a replacement pin. just in case | |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Tue Feb 04, 2014 2:57 am | |
| Of course, a self-serve wrecking yard would also be a source... But I just can't see that original pin getting out of the car! | |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Tue Feb 04, 2014 10:26 am | |
| Mine found its way onto the floor mat. Then it's only up to a human with a vacuum hose. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Tue Feb 04, 2014 11:52 am | |
- Mine found its way onto the floor mat. Then it's only up to a human with a vacuum hose.
Those damnable HUmans!! | |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement | |
