 fuel and brake lines
2 posters
89riv
fuel and brake lines Empty
PostSubject: fuel and brake lines   fuel and brake lines EmptyMon Dec 21, 2009 3:34 pm
I am planning on replacing all the fuel, and brake lines on my 89 riv. Do you guys know what holds the hose to the sending unit? If its like most mpfi cars, it should run about 60psi right? If so, there must be a fitting on the end of the hose and sending unit. Clamps wouldnt be alright to use would they? I am just trying to get an idea of what I am going to need to get. For all the hard lines I am going to use summit SS line, and I am not sure what to use for the hose.
PostSubject: Re: fuel and brake lines   fuel and brake lines EmptyMon Dec 21, 2009 4:23 pm
» Brake/Fuel Lines Surface Rust
» Steel braided brake lines
» Write-Up: Brake Line Repair
» do these fuel lines look like they need replacing?
» Write Up: Installing Stainless Steel Brake Lines
