| Big Block vs. Small Block V8 | |
+13Eldo Ironclad-454 ibmoses Sweepspear DEMonte1997 turtleman Jack the R L67 Hometown Hero 1998 Riv AA 1wickedninja Rickw 17 posters |
Hometown Hero Junkie
| Subject: Re: Big Block vs. Small Block V8 Tue Dec 29, 2009 2:58 pm | |
| - Rickw wrote:
- Hometown Hero wrote:
- I have the AMC 360 and its hilarious how many times people tried telling me it was a Dodge engine.
Did AMC cast their own blocks and heads for the 360 and other sizes ??? You betcha when it comes to V8's anywayz! They were designed from the ground up at the request of Mark Donahue for his T/A 5.0L race car (the Javelin won the Trans am racing championships back to back in 1971, and 1972 with the 304. The 304,343,360, and the 401 all share the same block. There is not 1 single part on that generation of engine that is interchangable with any of the major car manufacturers of then and today. If people ever tell you AMC 360 is a Chrysler 360 feel free to slap away, because if they have ever looked at either engine you can tell immediatly that they aren't the same block just by distributer location alone. Chrysler 360 distributor is located offset drivers side rear of engine block. http://image.moparmusclemagazine.com/f/9365594/mopp_0701_03z+1971_dodge_demon+engine.jpg AMC 360 distributor is located in front of the engine intake manifold @ a 45degree angle downward into the rear of the WP mount housing. The oil filler neck is also located just behind the distributor and is vertical off the intake unlike any other engines manufactured in autmobile applications. At least that I'm aware of. http://bringatrailer.com/wp-content/uploads/2007/11/1972_AMC_Javelin_SST_360_Go_Pack_V8_Engine_1.jpg Here's some reading on the topic for those interested. http://www.gremlinx.com/AMC-Myths.htm | |
Boattail Bill Fanatic
Name : Bill Age : 67 Location : Carson City, NV Joined : 2008-11-22 Post Count : 381 Merit : 4
| Subject: Re: Big Block vs. Small Block V8 Tue Feb 09, 2010 4:34 pm | |
| Hey guys. Don't forget there was a Buick 400, too!! | |
The Riv Amateur
Name : John Rolfing Age : 58 Location : Reading this over your shoulder...... Joined : 2009-06-12 Post Count : 30 Merit : 3
| Subject: Re: Big Block vs. Small Block V8 Tue Feb 09, 2010 6:44 pm | |
| - Boattail Bill wrote:
- Hey guys. Don't forget there was a Buick 400, too!!
And the 400 can be bored to run the standard bore 430 pistons!!! Hey, Boattail Bill!! | |
The Riv Amateur
| Subject: Re: Big Block vs. Small Block V8 Tue Feb 09, 2010 7:01 pm | |
| http://buickperformance.com/4bolt5.jpg
Buick actually cast up two four bolt main blocks in hopes of going pro stock racing. It was labeled the "Stage III." Only one is known exist. Click the link above. | |
| Subject: Re: Big Block vs. Small Block V8 Tue Feb 09, 2010 7:28 pm | |
| - The Riv wrote:
- http://buickperformance.com/4bolt5.jpg
Buick actually cast up two four bolt main blocks in hopes of going pro stock racing. It was labeled the "Stage III." Only one is known exist. Click the link above. We used T/A Performance's girdle to hold our 455's crank in place. So far it's working well. Once I hit the N2O on an overpressurized bottle and blew a hole out the side of the cylinder, but the crank never dropped! | |
Its a car part now Member
Name : Michael Age : 39 Location : Illinois Valley Joined : 2009-01-31 Post Count : 98 Merit : 4
| Subject: Re: Big Block vs. Small Block V8 Tue Feb 09, 2010 11:57 pm | |
| The Buick small block apparently looked like the big block, same timing cover and was apparently the almost the same width as the 455. The bore spacing was close so it was only 3.8 bore max, like a 3800. They started as a 215inch aluminum block and ended up 350 iron block(3.8 bore and 3.85stroke vr 3800 3.8bore and 3.4 stroke). here the Wikipedia article I double checked to make sure my memory wasn't playing tricks on me, been awhile since I've seen any magazine articles about Buick small blocks. Land Rover made a variant till 2006, they maxed out at 5L, 5.2L with aftermarket stroker parts. | |
| Subject: Re: Big Block vs. Small Block V8 Wed Feb 10, 2010 2:06 am | |
And the 400 can be bored to run the standard bore 430 pistons!!! Hey, Boattail Bill!! Hey, John!! Sorry I've been away so long. Just don't seem to be able to afford to do much with the Buick(s) at the moment, so I guess going on-line & talking about them just kinda rubs my face in it or something. Oh well, I'll recover - - someday. At the rate it's going, it might be YEARS, though. Oh well - that's the way it goes, I guess. | |
The Riv Amateur
| Subject: Re: Big Block vs. Small Block V8 Mon Feb 15, 2010 6:57 pm | |
| [quote="Its a car part now"]The Buick small block apparently looked like the big block, same timing cover and was apparently the almost the same width as the 455. The bore spacing was close so it was only 3.8 bore max, like a 3800. They started as a 215inch aluminum block and ended up 350 iron block(3.8 bore and 3.85stroke vr 3800 3.8bore and 3.4 stroke). here the Wikipedia article I double checked to make sure my memory wasn't playing tricks on me, been awhile since I've seen any magazine articles about Buick small blocks. Land Rover made a variant till 2006, they maxed out at 5L, 5.2L with aftermarket stroker parts.[/quote The 455, 350 and the original 231C.I. odd-fire V-6 are all designed using the same basic format. All share the funky oiling system, but the V6 is fine do to the much smaller main and rod journals. Forgive me, I'm not trying to be some Buick know it all, but I've been these things for more decades than I probably should have. | |
The Riv Amateur
| Subject: Re: Big Block vs. Small Block V8 Mon Feb 15, 2010 7:05 pm | |
| By the way, don't dog those AMC engines. There's a couple of guys here with 10 sec. 401 powered Gremlins. Yes, Gremlins. | |
| Subject: Re: Big Block vs. Small Block V8 Mon Feb 15, 2010 7:35 pm | |
| I almost hate to admit it, but I always liked the built Gremlins. Back in the day, in my neighborhood, there were a couple of the 401's that always interested me. Especially after one of those bastards beat me in a race. I had a 1967 GTO w/400 cu in RAM AiR 1 engine, 4spd POSI, Convertible Factory Stock, but still a car to contend with.
| Subject: Re: Big Block vs. Small Block V8 Mon Feb 15, 2010 7:40 pm | |
| Anyone ever see "HemiGremi" from Hotrodders.com? I always thought that was a pretty cool idea! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Big Block vs. Small Block V8 | |
