 95 riv codes need a little help!
chrldo
chrldo
95 riv codes need a little help! Empty
PostSubject: 95 riv codes need a little help!   95 riv codes need a little help! EmptySat Jan 02, 2010 4:25 pm
i've got three codes ;ic circuit low voltage , egr pintle position circuit , ignition/dist engine speed input circuit range/perf . if theres someone who knows what the problem is please reply . i did replace coil pack . did tune up. changed egr valve.it runs rough . slow acceleration of rpms when you rev it up . and sounds terrible .
PostSubject: Re: 95 riv codes need a little help!   95 riv codes need a little help! EmptySat Jan 02, 2010 4:49 pm
Anyone with a 1995 wiring diagram want to take a look and see what the common factor between these issues are.
I would bet on an electrical problem of some sort. Chafed or broken wire somewhere. That's why I say there may be a common problem that can be found on a wiring diagram possibly.
PostSubject: Re: 95 riv codes need a little help!   95 riv codes need a little help! EmptySat Jan 02, 2010 11:16 pm
You may want to try replacing the PCM with another known good used one, it could also be a bad ground wire or voltage supply wire.
Is it a supercharged or n/a '95? It matters a lot. Please add that information at least to your signature, and don't forget to activate your signature in your user settings.
chrldo
chrldo
PostSubject: Re: 95 riv codes need a little help!   95 riv codes need a little help! EmptySun Jan 03, 2010 11:13 am
IT IS SUPERCHARGED with 60k miles . i know ecm and bcm , what is pcm ?and where is it ?
nigelf
nigelf
Merit : 20
PostSubject: Re: 95 riv codes need a little help!   95 riv codes need a little help! EmptySun Jan 03, 2010 11:44 am
pcm should be behind glove box..
What are the actual code numbers?
PostSubject: Re: 95 riv codes need a little help!   95 riv codes need a little help! EmptySun Jan 03, 2010 12:04 pm
PCM = Powertrain Control Module
This is what's installed in your vehicle.
ECM = Engine Control Module
Installed on other make cars.
chrldo
chrldo
PostSubject: Re: 95 riv codes need a little help!   95 riv codes need a little help! EmptySun Jan 03, 2010 1:09 pm
Thanks guys for your reply. I've got 2 part cars both run I'll switch the PCM and see if that works.
code numbers are: p-1406, p-1361, p-0321
PostSubject: Re: 95 riv codes need a little help!   95 riv codes need a little help! EmptySun Jan 03, 2010 1:13 pm
Actually, ECM/PCM is more about vintage than make.
When the transmissions were still "normal", the computer was an Engine Control Module... Now that they are trying to make solenoids and silicon work as well as vacuum, governors and hydraulics, the computers are Powertrain Control Modules.
» Evike.com / Airsoftpost.com Coupon Codes
» RZR trouble codes.
» RedBox Codes
» Moultrie Error Codes
» Can Am P-Codes
