 PROM and or Bin file for 95 Riviera
74vert
Merit: 0
PostSubject: PROM and or Bin file for 95 Riviera   Wed Jan 13, 2010 9:39 pm
Hello. I think I found the site that I need to reside. I was sent here from the BuickForums.com.
Here's my problem that I posted on the BuickForums.com
My Riviera was and still is running like crap; stalls, bucks, idles rough, and gets bad gas mileage.
I took it to a garage have it fixed. Short story, the mechanic indicates that my computer
is good, but I need a new PROM.
After some searching, I've determined that my ECM service number is 16183247, and the broadcast code for my PROM is BKZS. I understand that a prom can be "flashed" if the Bin File is known.
Does anyone know where I can get a PROM for my car or the Bin File to have one flashed?
Merit: 72
PostSubject: Re: PROM and or Bin file for 95 Riviera   Wed Jan 13, 2010 9:43 pm
www.gmtuners.com he can do anything you need done.
you can use me as a referal, my name is prince albert
Merit: 83
PostSubject: Re: PROM and or Bin file for 95 Riviera   Wed Jan 13, 2010 9:54 pm
Hi Brad, Welcome to the site!
Try car-part.com to find a used PCM replacement. Otherwise if you are looking for a custom flash I'd go with robo's recommendation. I have no experience with them.
74vert
Merit: 0
PostSubject: Re: PROM and or Bin file for 95 Riviera   Wed Jan 13, 2010 9:55 pm
Thanks, I'll contact them.
Merit: 72
PostSubject: Re: PROM and or Bin file for 95 Riviera   Wed Jan 13, 2010 9:58 pm
you got it buddy
74vert
Merit: 0
PostSubject: Re: PROM and or Bin file for 95 Riviera   Wed Jan 13, 2010 10:03 pm
Thanks. I'll check that out too.
Merit: 87
PostSubject: Re: PROM and or Bin file for 95 Riviera   Thu Jan 14, 2010 7:56 am
Yeah, the 95's an oddball, not simple to do anything with, especially tuning and PCM stuff..
Both referrals were good, but I would lean towards GMtuners, I've never heard anything but amazing things about them.
74vert
Merit: 0
PostSubject: Cool, I'm making some progress   Mon Feb 15, 2010 5:55 pm
Worked with gmtuners and they seem to know their stuff. I was able to buy a mem-cal adapter board from them. It installed between my old prom and the computer board. Now my mechanics computer with communicate with the car. Sounds good right. Well, now the car's sending a P1670 code, quad driver module 4 failure. Does anyone know what this code means and what is a quad driver module 4 failure?
Merit: 96
PostSubject: Re: PROM and or Bin file for 95 Riviera   Mon Feb 15, 2010 6:42 pm
There are multiple Quad drivers in the PCM itself.
As the name suggests they are a set of 4 electronic switches. You will need to find out if it is a PCM fault or the actual system in the car that is reporting the fault. P1670?
If you worked with gmtuners and they know their shit, then they can tell what is wrong, through some relatively simple diagnosis.
Or if you have a 1995 FSM it will explain the fault in more detail and give you a troubleshooting guide to determine if it's the PCM or a control circuit involved with P1670.
If you are more interested in the definition of Quad Drivers, try going to Wikipedia and plugging in Quad Drivers. It may give you some info that will be helpful.
To properly diagnose the problem you will need the FSM, Alldata or Mitchell OnDemand.
Merit: 96
PostSubject: Re: PROM and or Bin file for 95 Riviera   Mon Feb 15, 2010 7:31 pm
Someone on here recently got the factory set of manuals on Ebay motors for less than $20.00.
Doesn't happen everyday but it does happen and they are most valuable when trying to diagnose problems such as what you are going through right now.
Try wickipedia if you haven't already for Quad Driver.
Name:
Merit: 100
PostSubject: Re: PROM and or Bin file for 95 Riviera   Mon Feb 15, 2010 8:05 pm
Doesn't this sound like the 'broken wire in the firewall connector' problem? The top left wire? Or am I confusing this with something else?
74vert
Merit: 0
PostSubject: Re: PROM and or Bin file for 95 Riviera   Mon Feb 15, 2010 8:58 pm
Thanks for the replies so far. I'm pretty much old school when it comes to autos. I'll get in touch with gmtuners Tuesday, and see what they come back with. I'm pretty happy that at least I know the board I bought seems to communicate with the mechanics computer.
Thanks guys. cheers
Merit: 96
PostSubject: Re: PROM and or Bin file for 95 Riviera   Mon Feb 15, 2010 9:22 pm
My Photobucket account has been compromised and shut down otherwise i could send a diagram of the QDM#4 Fault.
Albert, it doesn't appear to be related to the firewall connector harness issue.
QDM #4 Fault involve one or more of these. Generally you'll find one that then triggers the Quad Driver Fault. (These are the 4 circuits that are driven by the Quad driver in the PCM that will give a P1670..For the 1995 Riv.
1. A/C Relay
2. MIL Light
3. Fan 1 Low Speed
4. Fan 2 high Speed
These are components / systems that should be tested to see if any one of these has gone bad.
Series/parallel cooling fan relay
Low speed fan relay
high speed fan relay
10 Amp cooling fan fuse
15 Amp MIL Fuse
10 Amp HVAC Cont. Fuse
It makes much more sense with the FSM and/or a Diagram.
Obviously the MIL circuit is part of the driver so it can report the problem and is generally not the problem.
» 7th Game File 10/28/06
» symphony A95 flash file
» host baraye upload file
» Nokia all Good pm file 2012
» WARNING (X-FILE) Anomaly Research
