 series 1 swap in 1995 regal gs
2 posters
riv416
series 1 swap in 1995 regal gs Empty
PostSubject: series 1 swap in 1995 regal gs   series 1 swap in 1995 regal gs EmptyThu Jan 21, 2010 3:17 pm
i have a 1995 buick regal gs with the l27 motor and i just recently got my 1995 riv rear-ended and totaled:( my question is ?would it be hard to swap over my supercharged series 1 into my regal gs coupe?
PostSubject: Re: series 1 swap in 1995 regal gs   series 1 swap in 1995 regal gs EmptyThu Jan 21, 2010 11:37 pm
I would guess you might need a custom ECM to handle it, but the rivs ECM might just work. I would expect it to work out, although you might need to add a wire from the PCM to the boost bypass valve. The rest of the harness should be similar enough. I would suggest getting fsm's for both cars so you can compare engine harnesses.
» 1995 prototype riv swap series 1- series II
» FAQ: Series I to Series II / Series III Engine Swap
» Help Me Please!!!! Series 1 swap
» Series III 3 engine swap
» FAQ: M90 Blower In Place of M62?
