| | Write-Up: Supercharger Coupler Replacement (Series II) | |
| Author | Message |
96RIVMANN Member
Name: Paul Location: MN Joined: 2007-10-22 Post Count: 226 Merit: 9
 | Subject: Write-Up: Supercharger Coupler Replacement (Series II) Thu Jun 04, 2009 11:55 am | |
| Write-up is below. For questions & discussion on coupler replacements, please see: http://rivperformance.editboard.com/t9160-faq-best-sc-coupler-for-supercharged-riviera___ Just replaced my coupler with one I bought off ebay from seller darossillcusa and wanted to report that it took me about 1.5 hrs to complete the job. Removed the alternator, sucked out all the stinky oil, and pulled the snout. Finished it up by applying some loctite 518 and all is well now. No more rattle at idle. |
Ash Apprentice
Name: Marty Age: 34 Location: S. Central Indiana Joined: 2008-05-21 Post Count: 98 Merit: 4
 | Subject: Re: Write-Up: Supercharger Coupler Replacement (Series II) Thu Jun 04, 2009 4:25 pm | |
| Ah yes, the rattle-free supercharger. Verry nice. It's not that bad a job is it? And a great write-up on this site too.
That's actually the first thing I did to mine. (Purchased about one year ago.)
Cheers |
1998 Riv Aficionado
Name: Dave Age: 51 Location: Viking Country Joined: 2007-01-17 Post Count: 4065 Merit: 33
 | Subject: Re: Write-Up: Supercharger Coupler Replacement (Series II) Fri Jun 05, 2009 8:52 am | |
| Paul, was this a black OEM style coupler? Hope you got one of the green longer wearing ones such as ZZP and Intense offer. |
96RIVMANN Member
 | Subject: Re: Write-Up: Supercharger Coupler Replacement (Series II) Fri Jun 05, 2009 6:35 pm | |
| Yep, it was indeed the green one. |
RivGuy Trainee
Name: Bob Norton Joined: 2009-06-14 Post Count: 32 Merit: 0
 | Subject: Re: Write-Up: Supercharger Coupler Replacement (Series II) Tue Aug 11, 2009 3:30 pm | |
| Can the coupler be replaced without removing SC? How much is the coupler? Bob |
L67 Fanatic
Name: Matt Joined: 2007-06-05 Post Count: 1115 Merit: 37
 | Subject: Re: Write-Up: Supercharger Coupler Replacement (Series II) Tue Aug 11, 2009 3:36 pm | |
| | RivGuy wrote: | Can the coupler be replaced without removing SC? How much is the coupler? Bob |
Yes all you have to do is remove the snout which is the part with the pulley. It's held on by a few bolts and isn't too hard to get off. Depending on what coupler you buy its between $15 and $30 IIRC. ZZPerformance.com has them. |
Rickw Expert
Name: Rick Age: 53 Location: Lancaster, MA Joined: 2008-09-13 Post Count: 5957 Merit: 96
 | Subject: Re: Write-Up: Supercharger Coupler Replacement (Series II) Tue Aug 11, 2009 3:40 pm | |
| On the 1995, you have to remove the whole SC first, then the snout. From what I've read. Look in the "Write Ups" section for a detailed explanation of how to R&R coupler. |
RivGuy Trainee
 | Subject: Re: Write-Up: Supercharger Coupler Replacement (Series II) Tue Aug 11, 2009 5:28 pm | |
| What type does a 96 have? |
xxsupergman25xx Fanatic
Name: Scotty Age: 25 Location: Pittsburgh, PA Joined: 2007-03-03 Post Count: 1224 Merit: 13
 | Subject: Re: Write-Up: Supercharger Coupler Replacement (Series II) Tue Aug 11, 2009 5:54 pm | |
| m90 u can just remove the snout. its pretty easy from what ive seen. much easier then the dreadful 95 |
Natesriv Member
Name: Nate Age: 42 Location: KCMO Joined: 2007-01-18 Post Count: 394 Merit: 12
 | Subject: Write-Up: Supercharger Coupler Replacement (Series II) Sun Jan 24, 2010 11:07 am | |
| Okay, on my To Do list was replacing the coupler for the s/c. An easy job, smelly, but easy. Here's some pics  First remove alternator (disconnect negative battery terminal first)  then suck out the oil (about 2.2 fills of this syringe thing) Smells like a diaper! A used diaper!  dispose of it. I didn't want to mix it with my used motor oil as I think it will leave a smell forever!  Remove the bolts holding the s/c in place. 10 mm (some also say 3/8's" ) . OH BEWARE THERE'S ONE ON THE VERY BOTTOM. I LOOKED 3 TIMES DIDN'T SEE IT, COULDN'T GET S/C SNOUT OFF...HAMMERING AND WEDGING...LUCKILY BEFORE I F'ED UP I CHECKED WEB AND SURE ENOUGH...I'D MISSED THAT BOLT ON BOTTOM!!  snout off. a little oil, but not too much  old coupler. looks fine, but does have about 1/16' wiggle..enough to make a rattle  new coupler on, very tight fit...hammer gently on to snout. then line up with s/c on engine and bolt back into place  the kit came with a red gooey gasket material. I used it liberally as I had nicked the aluminum finish trying to wedge snout off (didn't know I'd missed a bolt) You see it sqeezing out the edge there? That's it, took longer than I expected as I wasn't aware of the last bolt..could have been bad if I had kept prying, but I found it, it came off no problem and all is well.. I will keep my eye on the oil level for the next week to ensure I didn't mess anything up. The s/c is aluminum and I scratched the mating surfaces a little, so I dremmeled the nicks out...and the gasket material is gooey enough to fill void....but I'll keep checking. BUT, I have earlier posts talking about a shuddering noise when I'm at idle in drive at lights & such...well, after this new coupler, it doesn't do that anymore... I'm not sure the coupler was the problem, it could have been a belt issue or the power steering hoses (I wiggled them some...could that have been it??) Anyway, she's back on the road!
Rickw Expert
 | Subject: Re: Write-Up: Supercharger Coupler Replacement (Series II) Sun Jan 24, 2010 12:14 pm | |
| Thanks Nate, We finally have photo's of a series 2 SC coupler change. |
Natesriv Member
 | Subject: Re: Write-Up: Supercharger Coupler Replacement (Series II) Sun Jan 24, 2010 3:07 pm | |
| Thanks! There's actually another post on this out there on the webtubes http://www3.sympatico.ca/aepa/blowerinstall.html Thank goodness for it! It's an easy fix everyone, if you've got that wobble in the s/c snout and a rattling sound (especially when you shut car off and you hear a rattle for a split second). I'm glad I did it  |
98riviera98 Aficionado
Name: Travis Age: 22 Location: Passing you Joined: 2007-02-08 Post Count: 4773 Merit: 7
 | Subject: Re: Write-Up: Supercharger Coupler Replacement (Series II) Sun Jan 24, 2010 3:10 pm | |
Mr.Riviera Aficionado
Name: Matthew Age: 25 Location: Florida Joined: 2007-01-17 Post Count: 4008 Merit: 82
 | Subject: Re: Write-Up: Supercharger Coupler Replacement (Series II) Sun Jan 24, 2010 4:34 pm | |
| are we sure the bolts are 10mm? i seem to recal almost striping the bolts at some point b/c i was using the wrong socket. however i cant remember if the correct one was 10mm or 3/8. anyone want to run out and see which one has less play? _________________  |
robotennis61 Junkie
Name: robotennis Age: 50 Location: las vegas Joined: 2007-12-17 Post Count: 3865 Merit: 72
 | Subject: Re: Write-Up: Supercharger Coupler Replacement (Series II) Sun Jan 24, 2010 4:41 pm | |
