 Write-Up: Side Bumper Molding Removal
2 posters
Write-Up: Side Bumper Molding Removal Empty
PostSubject: Write-Up: Side Bumper Molding Removal   Write-Up: Side Bumper Molding Removal EmptyTue Jul 28, 2009 12:38 pm
sqrivi wrote:
99Rivman wrote:
LOOKS GREAT thumbsup rock
Just wondering, are you going to remove the side molding when you paint? I can give you a couple of pointers on that if you are, let me know if you want that info. cheers
Thanks, I am game for all the advise, tips, and help I can get.
Hope this is not more than you are looking for!
The easiest way to remove the moldings if to PRY them off CAREFULLY, they are held on with spring clips and a little 2 sided tape. I don’t know if there is a special tool to release the pressure on the spring clips but I had several of the pins that they attach to on the molding break off removing them. Maybe EWolfe can throw in here and let you know how/what he did to remove them?
I have marked in RED in the pictures below where the clips are, and in GREEN where the 2 sided tape is, and the front of the door molding slides out of/into the slot at the front of the door, marked in BLUE.
The clips and their location:
Write-Up: Side Bumper Molding Removal Moldin10
Write-Up: Side Bumper Molding Removal Moldin11
On the fender there is 2 sided tape and 1 clip.
Write-Up: Side Bumper Molding Removal Moldin12
On the door start at the back, remove 5 clips and then remove molding by sliding rearward.
Write-Up: Side Bumper Molding Removal Moldin13
Write-Up: Side Bumper Molding Removal Moldin14
On the quarter there are 3 clips and a piece of 2 sided tape at the back.
Write-Up: Side Bumper Molding Removal Moldin15
If you are going to remove the mirror and door handle you will have the interior door panel off and can reach/release the clips from inside the door, which would solve that area anyway?
HTH
sqrivi
Merit : 52
PostSubject: Re: Write-Up: Side Bumper Molding Removal   Write-Up: Side Bumper Molding Removal EmptyTue Jul 28, 2009 1:03 pm
Thanks man, that is lots of help.
