 lost 1st and overdrive 4T60-E
3 posters
lionfish
lionfish
lost 1st and overdrive 4T60-E Empty
PostSubject: lost 1st and overdrive 4T60-E   lost 1st and overdrive 4T60-E EmptyTue Feb 02, 2010 3:58 pm
II lost overdrive while driving on the interstate. When I got home I noticed that
first was gone also. Only 2nd and 3rd are functioning. I did a search and noticed that a solenoid controls 1st and 4th. Is it hard to replace? Any thoughts on the number of hours involved?
PostSubject: Re: lost 1st and overdrive 4T60-E   lost 1st and overdrive 4T60-E EmptyTue Feb 02, 2010 4:05 pm
I'm not a Transmission rebuilder by trade but (I did stay at a Holiday inn last night) have paid to have some work done on that part of the trans.
The left axle/drive shaft has to be removed to gain access to the left cover on the trans. Under that cover are the misc. valves and switches that can be replaced.
I paid $600.00 the last time i needed any work done in there.
Theres quite a bit of labor to gain access, left wheel, brakes, spindle and axle need to be removed, if I recall correctly.
That was at a shop labor rate of $72.00/hour
PostSubject: Re: lost 1st and overdrive 4T60-E   lost 1st and overdrive 4T60-E EmptyTue Feb 02, 2010 9:12 pm
Unfortunately it is a lot of hours. To get the side case off involves quite a bit of labor. The solenoids are cheap in comparison.
Call around to a few different shops, see what they think the labor will run.
Good luck!
lionfish
lionfish
PostSubject: Re: lost 1st and overdrive 4T60-E   lost 1st and overdrive 4T60-E EmptyThu Feb 04, 2010 9:26 am
Good luck!
I called and got two quotes:
1) $376 plus $90 diagnostic fee ($466 total)
2) $700
This is a big labor fee for a $20 part.
Riv Performance ::   N/A 3800 Tech :: Series II N/A Engine, Transmission, PCM-
