 Series II (Supercharged) Write-Ups Index
Series II (Supercharged) Write-Ups Index Empty
PostSubject: Series II (Supercharged) Write-Ups Index   Series II (Supercharged) Write-Ups Index EmptySun Apr 15, 2007 10:12 am
(Click on links)
Replacing Supercharger Belt Tensioner
Replacing Accessory Belt Tensioner
Replacing Air Conditioner Compressor
Transmission Fluid and Filter Change
Hockey Puck & Filling Front/Side Motor Mounts
Filling/Replacing Rear Transmission Mount
Porting & Polishing M90 Blower
Installing M90 Blower
North Star Throttle Body Install
Spectre Intake for Northstar TB
Lower Intake Manifold (LIM) Gaskets
Building a Flexible Tube Fenderwell Intake
SC Snout Seal Replacement
SC Coupler Replacement
Radiator Replacement
Thermostat Installation
Replacing Water Pump
Installing Meziere Electric Water Pump
Fuel Pump/Sending Unit Replacement
Fuel Pump Re-Wire Mod
Installing SS Fuel Lines
3800 SC Engine Removal/Installation
Transaxle Removal/Installation
4T65e-HD Transmission Rebuild
4T80e Transmission Installation
XP Cam & Valvetrain Install
Installing Transmission Cooler
Replacing Alternator
Removing Crank Pulley/Harmonic Balancer
Installing FWI Filter, Heat Shield, Air Scoop
Fuel/Oil Pressure Sending & Gauges
Modified Air Box CAI
Replacing Belts and Pulleys
Gutting the Air Box
Glasspack Mufflers
Changing Supercharger Oil
L32(Series III) Engine Install/Swap
Removing/Installing SC Pulley
Custom CAI
Installing SLP Exhaust Headers
Building a Custom 4" PVC Fenderwell Intake
Installing Rocker Arms, Valve Springs, and Push Rods
» Lucas Oil Off Road Racing Series Short Course---USTREAM TV Live
» Melton 400m Series - 22nd & 29th July
» hmf swamp series exhaust
