 Write-Up: Filled Rear Motor/Transmission Mount
PostSubject: temp   Mon Oct 31, 2011 10:33 pm
I didn't use a primer. The weld cures to a hard rubber over a few days time. If you make sure to spread a coat of weld over each end, doing one side at a time, it should stay in the voids. There's also a flash line inside the voids to give the weld something to grab. Worst case, the weld falls out and you are left with an ordinary mount.
werdstrave
werdstrave
PostSubject: temp   Sun Feb 19, 2012 7:37 pm
Hey guys. I need to replace both transmission mounts front and rear. The rear more so than the front. It seems like you guys have done this without an engine lift of any kind. Is this true? MrRiviera did a write up on page 4 for the rear without one.
Can I replace both the front and rear mounts by supporting the engine from underneath? I haven't found a write up for the front mount. Is there anything else strange with these jobs I should know about?
PostSubject: Re: Write-Up: Filled Rear Motor/Transmission Mount   Sun Feb 19, 2012 8:19 pm
There is more info dealing with the rear mount after page 4 (this thread).
Specifics on replacing/improving the front mount can be found here:
http://rivperformance.editboard.com/t2586-write-up-hockey-puck-casting-front-side-motor-mounts
For all other inquiries on engine mounts, see our FAQ thread:
http://rivperformance.editboard.com/t882-faq-engine-transmission-motor-mounts#9227
werdstrave
werdstrave
PostSubject: Re: Write-Up: Filled Rear Motor/Transmission Mount   Thu Mar 01, 2012 10:55 am
Hey guys,
I just ordered the rear and front transmission mounts from rock. The front one looks solid but when I opened and felt the rear mount Anchor 3065, it felt extremely flimsy and I could tell without a doubt it would be kaput in a year. I could just about dig a finger nail into it and tear it. It was also flaking black particles on my hand. Were all your guys' 3065 parts like this? It just seems flimsy and was wondering if I got one from a bad batch. Says made in India.
werdstrave
werdstrave
PostSubject: Re: Write-Up: Filled Rear Motor/Transmission Mount   Thu Mar 01, 2012 11:11 am
Anchor 3065 vs DEA 3065? Any differences?
PostSubject: Re: Write-Up: Filled Rear Motor/Transmission Mount   Thu Mar 01, 2012 11:54 am
This the same mount we're all getting from Rockauto. It's beefier than the OEM version. See page from FAQ thread: http://rivperformance.editboard.com/t882p120-faq-engine-transmission-motor-mounts
PostSubject: Re: Write-Up: Filled Rear Motor/Transmission Mount   Thu Mar 01, 2012 12:48 pm
Now fill it in with some liquid nails clear seal!!!
werdstrave
werdstrave
PostSubject: Re: Write-Up: Filled Rear Motor/Transmission Mount   Thu Mar 01, 2012 12:58 pm
Hmm, the front mount seemed way more robust and a lot harder plastic. The rear just seems flimsy. I went down to advanced auto and checked one out down there, same construction so I guess I didn't get one from a bad batch. Seems like most people are using some kind of sealant to seal these on this forum. I read here that it will reinforce it but may make for stiffer shifting. I'm sure they were designed without fill for a reason. Has anyone here installed the rear mount without any fill? James, why liquid nails? Others were saying 3M window urethane.
PostSubject: Re: Write-Up: Filled Rear Motor/Transmission Mount   Thu Mar 01, 2012 2:18 pm
The most obvious reason is isolation from NVH (noise, vibration, harshness). It's the same reason almost every bushing on the car's suspension is also a soft rubber material. It's the same reason the air intake uses noise silencing parts, and for the same reason the PCM tune uses very soft (slow) shifting.
But as many of us have found, suppressing NVH doesn't necessarily (usually doesn't) mean the car will perform to its fullest, or have maximum durability. Softer parts wear out faster, and once they break, you'll feel the need to replace, because you were used to soft and quite. Modifying an OEM mount by filling with a harder material will increase it's life span and allow the engine's torque to be transferred more directly, resulting in better throttle response. This happens at the expense of higher levels of NVH. Everyone has a different tolerance level for this, and I personally feel the Riv was designed too soft from the factory. Some can go even further than me and be quite happy with the result.
Here's something you can try (at your own risk). Lock the car in 1st gear, drive it up to about 35-40 MPH, let off the gas, then hit the throttle again rapidly at this speed. The car will display a beastly amount of torque in doing this, and if you have original mounts, you'll might tear them apart, as they were never meant to take this kind of stress in addition to the age/miles they have. You may hear a solid 'clunk' as the rubber insulator gives out and the mount makes contact with the cradle. But if you replace the insulators with something more durable and solid, the car and the engine will gladly take this kind of abuse, you will feel the car respond better to the applied torque. It really changes the character of the car into something less soft and more spirited.
werdstrave
werdstrave
PostSubject: Re: Write-Up: Filled Rear Motor/Transmission Mount   Thu Mar 01, 2012 2:34 pm
Well said Aaron. Are you guys filling the front mount too?
PostSubject: Re: Write-Up: Filled Rear Motor/Transmission Mount   Thu Mar 01, 2012 2:42 pm
The fronts can be filled, but I felt the alternate 'hockey puck' solution works best. It seems like this idea couldn't possibly be a good one, but after completing this mod, I'd say it's one of the more reliable jobs I've done.
PostSubject: Re: Write-Up: Filled Rear Motor/Transmission Mount   Sat May 26, 2012 9:00 pm
I just got finished replacing my rear trans mount. What a PITA to do without a lift.
I will say that the mount pictured above does fit, and so does the one i bought from AZ for $50.
I didnt do a full write-up but here are the basic steps i took after much trial and error trying to figure this out.
You will need a good collection of tools to do this btw.
1. Take off both end links from the sway bar.
2. Loosen the 4 bolts holding the rear half of the sub frame on. 18mm
3. Jack the trans/motor up with a 2x4 resting on the trans pan
4. Unbolt the 2 bolts holding the steering rack on the frame. 15mm (i was able to get these from the top with a 4 foot bar, swivel joint and ratchet. They are on VERY tight)
5. Next take off the 2 torx bolts going through the bottom of the sub frame. There is a nut on the other side that i believe is an 18mm you will need to hold.
6. Take out the bolt going through the mount. 18mm on the nut end and 15mm on the bolt side.
7. At this point the trans/motor should be completely supported by the jack.
8. There are 2 final bolts going through the mount bracket into the sub frame. 18mm (you will need to rotate the sway bar out of the way)
9. There is also a 10mm screw holding the power steering lines on the mount bracket that will need to come out.
10. Wiggle out the old mount and bracket. You may need to lower the sub frame and move the PS line a little.
11. The old mount should come out easily b/c its likely deteriorated. The new one may need to be greased and hammered in place. (may work if you have a press)
Reverse the steps for reinstall.
Here is a pic of the old mount in the bracket:
Mine was so bad the center part was completely separated from the rest and would just clunk around under hard acceleration/deceleration and over bumps.
I filled the voids of the NEW mount with polyurethane from a left over 3m tube of window weld. It is very stiff now.
Overall i am Very pleased with how the car is after the install. Idle is surprising much smoother. Shifts are less noticeable and i dont have as much power loss at the shift points. There is more power to the wheels when blipping the throttle at any speed and It amy be my imagination but it feels like the car has less body roll now. Maybe the motor/trans was rocking more than i thought.
Was it worth the 6hrs of work and an aching body? YES b/c i saved a bunch of $$ doing it myself.
Thanks for the write up. I just changed mine today and it was a hard job working on the garage floor. I wish I had a lift! There isn't much room to work with and all of the bolts are on there pretty tight. Just a few things I noticed on the write up. You will need a T55 torx for step 5. I ended up breaking one and had to buy another, so be careful. I was also able to remove the mount without having to lower the cradle. Thanks to VegasScott in this thread http://rivperformance.editboard.com/t882p120-faq-engine-transmission-motor-mounts#125958 for letting us know. I did have to pry up on the steering rack to get enough clearance around the power steering lines to get the old mount out. Also for anyone planning on doing this, make sure to buy new endlinks ahead of time if you haven't had them off in a while. I had changed them in 2005 or 2006 and they were rusted on there and I had to get a sawzall out and cut both of the links. I had to run and buy two new endlinks before I could drive. Its a dirty job and took a while, but hopefully I won't have to mess with it for a while.
flyingjunebugs
PostSubject: 3M window weld now discontinued.   Tue Nov 27, 2012 11:24 am
NAPA stocks 3M products, found out today, that window weld is discontinued, had to recall dried up sealant in unused tubes.
They recommended 3M "Ultrapro Sealant", p/n 08300, which is a firm sealant for body joints. $28.00 @ tube!!
So bought a tube of it to try on my fwd and rear mounts.
Bruce in Alaska 1998 Riv
PostSubject: Re: Write-Up: Filled Rear Motor/Transmission Mount   Mon Jul 01, 2013 4:46 pm
I was at the auto paint store the other day and noticed that SEM makes a variety of automotive grade body adhesives and seam sealers. They had some other manufacturers' body adhesives as well, clearly designed for some very specific automotive applications.
Perhaps something to check out at you rlocal auto paint store.
Merit : 179
PostSubject: Re: Write-Up: Filled Rear Motor/Transmission Mount   Mon Jul 01, 2013 5:26 pm
I don't think ANY seam sealer or adhesive is going to be as pliable, nor as strong as Window Weld or equivalent. That stuff is specifically made to withstand enough flex and enough strength to keep the windshield in place with all the body flex, without cracking it. Seam sealer dries MUCH harder than windshield adhesive. Be careful what you buy....
I'm not sure what it's called, but our glass guy that does all of our back glass and windshields uses (obviously) something different. I'll look to see what it is next time he's here as I too, used Window Weld for my front mount. I still have an entire case of it in the basement. Hope it isn't all dried up frown
PostSubject: Re: Write-Up: Filled Rear Motor/Transmission Mount   Thu Dec 12, 2013 11:18 am
...(pics removed from quote)
Just going over this write-up, as I have to do mine soon. Header flex pipe is leaking badly, and investigating that along with a random clunk led us to discover both trans mounts were completely wiped out.
Curious if the window-welded mount has held up over time? And where do you buy Window Weld?
Also, I have noticed from having the subframe out in the past that the mount to subframe bolts on our '98 use a large torx head bolt, which was very difficult to remove last time I had the subframe out. I'm not particularly looking forward to this job... but it desperately needs to be done.
Thanks for the write up!
PostSubject: Re: Write-Up: Filled Rear Motor/Transmission Mount   Mon Dec 15, 2014 1:25 pm
YOOO!!!!
So i was looking at filling my mounts with 60A grade poly urethane but after doing a bit of study
I found that the 3M window weld is right there in spec of the 60A.
http://multimedia.3m.com/mws/media/107695O/3mtm-super-fast-urethane-08609.pdf
Mounts have been ordered and as soon as they arrive, the filling shall begin
PostSubject: Re: Write-Up: Filled Rear Motor/Transmission Mount   Mon Dec 15, 2014 1:40 pm
Be sure to keep it warm while setting up. It's rated to set up at 75ΊF ambient temp, and it will take a longer time anyway since you're filling a large space. In cold temp, it could take a lot longer to set-up.
PostSubject: Re: Write-Up: Filled Rear Motor/Transmission Mount   Mon Dec 15, 2014 1:52 pm
Thanks, AA. saw that. Ima be doing this inside my studio. I will make sure to keep a lamp on it to get the goo flowing and setting right.
Who all has poly-u filled their passenger side engine mount? I have a spare from my previous 56k mile Riv I am considering filling and swapping.
Merit : 179
PostSubject: Re: Write-Up: Filled Rear Motor/Transmission Mount   Mon Dec 15, 2014 2:15 pm
I knew I had pics of mine somewhere....found it! All I did was make end "caps" to stop the filling from falling out. I used 3M Window Weld. It takes damn near 3 months to fully cure though. I kept poking through it with really thin wire until it came out dry....like a cake.
PostSubject: Re: Write-Up: Filled Rear Motor/Transmission Mount   Mon Dec 15, 2014 2:47 pm
Scott, which mount is that? Rear trans?
PostSubject: Re: Write-Up: Filled Rear Motor/Transmission Mount   Mon Dec 15, 2014 2:51 pm
That's the front mount.
PostSubject: Re: Write-Up: Filled Rear Motor/Transmission Mount   Mon Dec 15, 2014 2:55 pm
Front trans?
Merit : 179
PostSubject: Re: Write-Up: Filled Rear Motor/Transmission Mount   Mon Dec 15, 2014 3:06 pm
Yes, that's the front, but the rear mount is set up the same way.
In reality, if you wanted to make the mount "higher" without shimming it, you could build a plate to place the center piece anywhere you wanted. You'd just have to remove all the old rubber, install the plate to hold the center in place, and fill it. You'd only have to reposition it 1/4" up, if that.
The front mount on my car currently has ZERO factory rubber in it. It's all Window Weld. The mount in the pic is one that I made and sold to a member on here a while back. It still has the factory rubber in it, and was much easier to fill.
If you are going to go this route, you'll need the Window Weld Primer as well.
Merit : 128
Yeah that's the front trans mount.
In total that are 4 mounts and incidentally they all have their own side. The front and back both connect the transaxle to the cradle. The passenger mount connects the engine to the frame of the car. The driver side connects the transaxle to the frame of the car. So there's only one mount that actually connects to the engine itsself but consider the transaxle and engine to be one solid part for the sake of mounts. The front and rear mounts I would argue are the only ones that matter a lot in terms of taking torque and shockloads from the drivetrain. The others are more position or orientation mounts so I wouldn't worry about filling those.
Page 6 of 8Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
» homemade rear motor mount
» craftsman lt4000
» Frame Gusset Cracked at Rear Diff mount on the Rhino.
» Rear tow / Hitch plate
» RZR storage
