 Write-Up: Series I Code 1640 - Finding a Fault
Go to page : Previous  1, 2
adri
Write-Up: Series I Code 1640 - Finding a Fault - Page 2 Empty
PostSubject: Re: Write-Up: Series I Code 1640 - Finding a Fault   Write-Up: Series I Code 1640 - Finding a Fault - Page 2 EmptyMon Oct 31, 2011 8:21 am
very nice write up. next time if you could some how use arrows or something to pinpoint areas and such, but nice!
moldymac
PostSubject: Re: Write-Up: Series I Code 1640 - Finding a Fault   Write-Up: Series I Code 1640 - Finding a Fault - Page 2 EmptyWed Aug 08, 2012 9:56 am
This helped a lot, thanks for posting! My 95 had a bad boost solenoid. I found the solenoid itself is the same from the series II engine (96+), the only difference is the metal bracket that mounts the solenoid to the boost valve. You can mount the 96+ one on there as it is but the vac line is a different length and it comes close to the EGR pipe. I uncrimped the metal brackets and swapped solenoids, worked perfectly. It sure is good to have a parts engine to figure these things out. Maybe really useful if the series II one one is still available.
» Can Am P-Codes
» Glossary of RAF mission code names
» Pre-Season Ticket Code
