| Aluminum/Metal Valve Covers | |
+8BatMobile ewolfe0050 albertj 1998 Riv AA deekster_caddy Rickw BMD 12 posters |
BMD Aficionado
| Subject: Aluminum/Metal Valve Covers Thu Feb 25, 2010 7:50 pm | |
| I had heard that there is a metal aftermarket valve cover set with higher torque specs than the originals to solve the oil leaks in that location. Can anyone confirm this? | |
| Subject: Re: Aluminum/Metal Valve Covers Thu Feb 25, 2010 11:19 pm | |
| - BMD wrote:
- I had heard that there is a metal aftermarket valve cover set with higher torque specs than the originals to solve the oil leaks in that location. Can anyone confirm this?
I've not heard of any aluminum or metal impregnated valve cover gaskets. But there are all Aluminum intake manifold gasket replacements that still have the traditional rubber seals that go on the ends of the block / intake. But the important part has been addressed. The seal between the heads and intake. | |
BMD Aficionado
| Subject: Re: Aluminum/Metal Valve Covers Thu Feb 25, 2010 11:54 pm | |
| I meant the valve covers themselves being made of metal, not the gaskets, cause my rear valve cover leak is pretty bad and will have to be taken care of this spring.
| Subject: Re: Aluminum/Metal Valve Covers Thu Feb 25, 2010 11:59 pm | |
| If you have a deformed valve cover, the best bet is to buy a new one...period. They can't be that expensive. If they are then you have to buy used which will be almost free. | |
BMD Aficionado
| Subject: Re: Aluminum/Metal Valve Covers Fri Feb 26, 2010 12:03 am | |
| I am not concerned about the price, just wondering if a metal valve cover would do a better job? | |
| Subject: Re: Aluminum/Metal Valve Covers Fri Feb 26, 2010 12:18 am | |
| By all means a metal or aluminum cover is much better than what you obviously have, which is a not so flat leaking cover. I, like you, prefer to fix the problem the right way and not worry about it again. That is why i replaced a tin oil pan with an Aluminum oil pan to stop chronic leaks i was experiencing and it solved the problem. | |
BMD Aficionado
| Subject: Re: Aluminum/Metal Valve Covers Fri Feb 26, 2010 12:23 am | |
| - Rickw wrote:
- By all means a metal or aluminum cover is much better than what you obviously have, which is a not so flat leaking cover.
I, like you, prefer to fix the problem the right way and not worry about it again. That is why i replaced a tin oil pan with an Aluminum oil pan to stop chronic leaks i was experiencing and it solved the problem. Seems like we're on the sam page Rick. By the way, my valve cover isn't warped, I just figured while I'm there, I'd replace the OEM set with something better. I was just curious as to wether an aftermarket replacement existed. | |
| Subject: Re: Aluminum/Metal Valve Covers Fri Feb 26, 2010 12:35 am | |
| I would like to propose this question to the general member base. Is there a better a valve cover to be had, and if so are they aluminum or metal.? And where can one get a set. I personally would like to send a set out for powdercoating in the near future to match my SC that will be powdercoated. | |
| Subject: Re: Aluminum/Metal Valve Covers Fri Feb 26, 2010 10:17 am | |
| I think the OEM plastic valve covers, although they are made of plastic, they are pretty thick and rather sturdy. I wouldn't be concerned about it warping, just put the VC gaskets in and see how they do. | |
| Subject: Re: Aluminum/Metal Valve Covers Fri Feb 26, 2010 12:44 pm | |
| Right, to try to actually answer your question, I have not seen or heard of any aftermarket valve covers for the 3800. | |
| Subject: Re: Aluminum/Metal Valve Covers Fri Feb 26, 2010 1:17 pm | |
| RegalGS.org had a group buy about 3 years ago for CNC billet aluminum valve covers. I think there were various designs machined into the top. They were $250 each if I remember. Most people only got the front one. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Aluminum/Metal Valve Covers Fri Feb 26, 2010 1:21 pm | |
| I've seen aluminum covers on one of the vendor sites, ZZP or Intense, in the recent past. Need to take a look again.... | |
| Subject: Re: Aluminum/Metal Valve Covers Fri Feb 26, 2010 1:25 pm | |
- RegalGS.org had a group buy about 3 years ago for CNC billet aluminum valve covers. I think there were various designs machined into the top. They were $250 each if I remember. Most people only got the front one.
And a good used NA engine (short block complete) costs what, $750? Albertj
| Subject: Re: Aluminum/Metal Valve Covers Fri Feb 26, 2010 1:30 pm | |
| You don't see them under my hood. It's just for dress-up; some people pay for that. Nothing wrong with the OEM plastic covers, unless you need some extra clearance for some wild cam/rocker combo. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Aluminum/Metal Valve Covers Fri Feb 26, 2010 1:40 pm | |
| ZZP, out of stock Jan 12 2010.
http://www.zzperformance.com/grand_prix/products1.php?id=798&catid=101 | |
BMD Aficionado
| Subject: Re: Aluminum/Metal Valve Covers Fri Feb 26, 2010 5:40 pm | |
| Thanks for the link Dave, its a little pricey, might have to think twice about it. But it does proves that they do exist. Cheers! | |
| Subject: Re: Aluminum/Metal Valve Covers Fri Feb 26, 2010 6:02 pm | |
| I don't know if they're planning to make any more. Might want to email Zoomer via their email contact link.
To me, they don't look all that great for the money. But I'd probably paint them. Still pretty plain design. | |
ewolfe0050 Aficionado
| Subject: Re: Aluminum/Metal Valve Covers Fri Feb 26, 2010 6:25 pm | |
| PRJ Pef has some really, really nice ones if you are willing to spend the money. They will clear the high-ratio rockers too... | |
BatMobile Amateur
Name : Susan Location : NJ Joined : 2009-08-14 Post Count : 35 Merit : 2
| Subject: Re: Aluminum/Metal Valve Covers Sat Aug 21, 2010 4:11 pm | |
I, like you, prefer to fix the problem the right way and not worry about it again. That is why i replaced a tin oil pan with an Aluminum oil pan to stop chronic leaks i was experiencing and it solved the problem. Rick, where did you get the aluminum pan as we want to get one for our 96 Riv. Thanks! | |
| Subject: Re: Aluminum/Metal Valve Covers Sun Aug 22, 2010 12:37 am | |
| It's been discussed at length in another thread, I believe it's a Bonneville pan. Try searching the board by "bonneville oil pan". | |
DEMonte1997 Aficionado
| Subject: Re: Aluminum/Metal Valve Covers Sun Aug 22, 2010 12:15 pm | |
| I just did the gaskets on mine when installing rockers. No more leaks. You could probably sand them a little and paint them with high temp paint if you were inclined to make them look better. lol | |
Rivillac Enthusiast
Name : Kevin Location : NC Joined : 2011-06-06 Post Count : 102 Merit : 13
| Subject: Aluminum valve covers Sun Dec 18, 2011 8:35 pm | |
| It seems like I read a thread a while back regarding engine cleaning or something similar, with a side story that another car with the Series I 3800 had aluminum valve covers. I remember there were pictures of a car with these valve covers (polished) and the OP made a comment about the valve covers being a little something that only the Series I guys could use.
I tried a search of the site, but I can't remember what the original thread was about. Ring any bells with anyone? Or perhaps someone has knowledge of what car they came off of?
Thanks. | |
| Subject: Re: Aluminum/Metal Valve Covers Sun Dec 18, 2011 9:41 pm | |
Rivillac Enthusiast
| Subject: Re: Aluminum/Metal Valve Covers Sun Dec 18, 2011 10:18 pm | |
Rivillac Enthusiast
| Subject: Re: Aluminum/Metal Valve Covers Tue Dec 20, 2011 10:48 am | |
| I found a set at the local u-pull-it. They came off a 96 Camaro. I had seen the car before when looking for odds and ends but it never clicked because the plenum has "3800 Series II" cast into it. Since I'm new to working on the 3.8, I never thought to look since I have a Series I. When I got to looking closer, that's when I noticed they didn't have the injector indents in them. I got the set for $20 and change out the door.
When I got into cleaning them up, I found what looks to be 8 digit GM numbers inside. There is a seperate number for the casting or the assembly. These are the #s:
24505360 ASY 24505361 CST This is the rear on a FWD engine.
24505358 ASY 24505359 CST This is the front on a FWD engine.
Doing a quick internet search, I don't see these numbers come up, however, so I'm not sure about them.
The covers are opposite than a FWD engine, so if you are looking for a front cover (with the oil fill) only, that would be the right side Camaro valve cover. | |
| Subject: Re: Aluminum/Metal Valve Covers | |
