 Exhaust Sound Clips
Merit : 135
Exhaust Sound Clips - Page 3 Empty
PostSubject: Re: Exhaust Sound Clips   Exhaust Sound Clips - Page 3 EmptySun Mar 28, 2010 2:51 pm
Codith,
Refresh my memory on the complete set-up.?
Do you have a resonator ?
Do you have a CAT.?
What is the latest muffler,
and you eliminated the second pipe with the glass pack, correct.??
How bad is the Droan? And at what RPM do you experience droan.?
I'd have to get back if you want any part numbers but its XSP headers, no cat, 4" glasspack at resonator location, and a walker soundfx muffler replacement for a 4.3L and a tip. System is all 3"
The second pipe with the glasspack was bolted to the cutout flange so it's pretty easy to take on and off. I had to take it off so I could take measurements without stuff in the way.
The drone is replaced with a nice growl so there is really no drone ever. So basically the idle is slightly burbly (not as much as a louder muffler(s) but a good amount for an otherwise quiet muffler), the cruising rpms (which would be the drone range most of the time), it sounds more like a stock gtp with more balls, and then above the drone range, it gets pretty quiet again. At WOT, I guess it sorta hisses. There's not much to hear at the point 'cause the s/c pretty much makes most of the noise which is ideal IMO.
Derek, I still want to do my next exhaust but It's not going to happen until I have another job and get stuff straight again. It's going to cost a little money. I also have a blower sitting here dying to get put on with an I/C. I guess it all depends on what I feel like doing once I have play money again. I'm pretty happy with the way this exhaust sounds now. My beef is mostly how it looks. I've used what I've learned from this exhaust in my plans for the next so it should be a great result.
PostSubject: Re: Exhaust Sound Clips   Exhaust Sound Clips - Page 3 EmptyThu Feb 03, 2011 3:42 pm
Vid should be here no?
Fastbuick95
Fastbuick95
PostSubject: Re: Exhaust Sound Clips   Exhaust Sound Clips - Page 3 EmptyThu Feb 03, 2011 7:32 pm
Mines not a backside, but all the same nonetheless lol.
BlownRiv
PostSubject: Re: Exhaust Sound Clips   Exhaust Sound Clips - Page 3 EmptyMon Feb 21, 2011 6:58 pm
PostSubject: Re: Exhaust Sound Clips   Exhaust Sound Clips - Page 3 EmptyFri Aug 05, 2011 8:36 pm
Sounds great,i think magnaflow is the best too!!! 3gears
brutusk1
PostSubject: Re: Exhaust Sound Clips   Exhaust Sound Clips - Page 3 EmptyFri Aug 05, 2011 9:02 pm
[quote="BlownRiv"]
IBx1 wrote:
Holy muffler clamps batman! That is one hacked exhaust setup. I think you would have been better off with the factory stuff.
It sounds real nice but, yeah, I'd take it to someone to get it fitted more tightly under the car. I think I've gotten good bang for my buck with exhaust shops and they're worth the money in my book (I've learned my lesson).
I like the sound though. Don't think I've heard anything I like better. But I'm happy with the stock sound too.
PostSubject: Re: Exhaust Sound Clips   Exhaust Sound Clips - Page 3 EmptySat Aug 06, 2011 1:26 am
Mine was done at an exhaust shop. Cheap enough, I can't be bothered with "colored engineering" things. wink
PostSubject: Re: Exhaust Sound Clips   Exhaust Sound Clips - Page 3 EmptyFri Sep 23, 2011 12:35 pm
Exhaust Sound Clips - Page 3 Th_MOV03734 No cat,res, just walker!!!
PostSubject: Re: Exhaust Sound Clips   Exhaust Sound Clips - Page 3 EmptyWed Oct 05, 2011 1:14 pm
Here's how my exhaust sounds now. Not sure if I like it that loud, but we will see.
Uploaded with ImageShack.us
Ron's Rocket Riv
Ron's Rocket Riv
PostSubject: Re: Exhaust Sound Clips   Exhaust Sound Clips - Page 3 EmptyMon Dec 12, 2011 10:03 pm
That's it!! bounce
Turtleman... the sound of your Riv after you did this:
Right after the xp cam install with 3"dp, shop fabbed 3" catless, resonatorless exhaust, dynomax superturbo mufflers
OMG! It sounds FIERCE!! That's the sound I hope to one day have on the Riv that I just picked up. That sounds like a small block V-8 burbling away under the hood.
Wow! That's just awesome, man!!
rock
Merit : 153
PostSubject: Re: Exhaust Sound Clips   Exhaust Sound Clips - Page 3 EmptyWed Dec 21, 2011 1:27 am
albertj wrote:
You want to hear the back end?
https://www.youtube.com/watch?v=AlhoW4BWgHs
I no longer have this exhaust and have not posted the new one yet.  The new exhaust is darn near silent.
The one in the video:
3" Downpipe with flex into Walker cat, 2-3/4" exit  thru T304 stainless 'cherry bomb' type resonator, split to 2-1/2" at Y, one L bend (instead of the stock S bend)  into custom made mufflers packed with combination of glass and T304 stainless wool, outlet to resonated oval tips.
I kept the 3" downpipe on the new exhaust but the rest is factory 2004 Park Ave Ultra.
The SS and replacement PA exhausts - for comparison:
The current GM exhaust
https://www.youtube.com/watch?v=cPA48B-oYMo
The T304 SS exhaust startup and revs to fuel cutoff (4K RPM)
the engine idling (cars drive by off-camera at startup, sounds like revving but it's not -- watch the tach)
https://www.youtube.com/watch?v=J4wun7rO1JM
Drive-by with the SS exhaust
https://www.youtube.com/watch?v=0ClrUs29qS0
PostSubject: Re: Exhaust Sound Clips   Exhaust Sound Clips - Page 3 EmptyWed Aug 07, 2013 7:47 am
SLP Headers, cat delete, otherwise completely stock exhaust.
PostSubject: Re: Exhaust Sound Clips   Exhaust Sound Clips - Page 3 EmptyWed Aug 07, 2013 9:19 pm
Verry nice did you tune with header and cat delete or are u lean??
PostSubject: Re: Exhaust Sound Clips   Exhaust Sound Clips - Page 3 EmptyWed Aug 07, 2013 9:39 pm
Thx. It's rich, only right after letting off from heavy boost. I have to drive a certain way to get the afterfires. Normally it makes almost no sound at all. My wife says it spits flames at night!
PostSubject: Re: Exhaust Sound Clips   Exhaust Sound Clips - Page 3 EmptyWed Aug 07, 2013 9:53 pm
AA, you're still working with the stock resonator!?
PostSubject: Re: Exhaust Sound Clips   Exhaust Sound Clips - Page 3 EmptyWed Aug 07, 2013 9:57 pm
Stock everything, except cat and headers.
PostSubject: Re: Exhaust Sound Clips   Exhaust Sound Clips - Page 3 EmptyWed Aug 07, 2013 10:32 pm
No offense to anyone, but the only sounds I like from this engine are the idle on stock exhaust and the supercharger whine. Anything else just sounds ugly IMO.
PostSubject: Re: Exhaust Sound Clips   Exhaust Sound Clips - Page 3 EmptyWed Aug 07, 2013 10:46 pm
I agree, Matt. But after hearing it for the first time, I do like the growl it makes at 1:10 when shifting down into 2nd. What I like most about my exhaust is that it's not too loud.
PostSubject: Re: Exhaust Sound Clips   Exhaust Sound Clips - Page 3 EmptyThu Aug 15, 2013 9:46 pm
Alright, here ya go....it's dirty as hell. All you northern-ers understand.....
Best exhaust clip in this thread.
Merit : 135
PostSubject: Re: Exhaust Sound Clips   Exhaust Sound Clips - Page 3 EmptyFri Aug 16, 2013 1:23 am
Hey what cam did you do that vid with?
PostSubject: Re: Exhaust Sound Clips   Exhaust Sound Clips - Page 3 EmptyFri Aug 16, 2013 3:49 am
A Reatta and a 57 Pickup. Both the 3800 with Camaro exhaust. I've got to wonder if the Riv would growl the same way with this set up?
PostSubject: Re: Exhaust Sound Clips   Exhaust Sound Clips - Page 3 EmptyFri Aug 16, 2013 9:36 am
GoPro HERO3
PostSubject: Re: Exhaust Sound Clips   Exhaust Sound Clips - Page 3 EmptySat Aug 24, 2013 1:05 pm
Mine. Disregard the noisy supercharger. I'm going to take care of that soon.
PostSubject: Re: Exhaust Sound Clips   Exhaust Sound Clips - Page 3 EmptySat Aug 24, 2013 2:02 pm
Sounds like a noisy Power Steering Pump to me.
Exhaust Sound Clips
» 2011 FJ Cruiser K&N Drop in Filter and Flowmaster 40 Sound Clips
» exhaust questions
» How to get Hemi Sound Exhaust
» Looking for HMF exhaust
» What kind of exhaust mods are there?
