 engine swaps for N/A Series II
BIGAL1128
PostSubject: Re: engine swaps for N/A Series II   Mon May 14, 2007 1:08 pm
Al, thank you very much for all the information. This is the kind of stuff that benefits the forum the most! Keep us updated, and best of luck finishing the project.
Thank you for the kind words. I wish there were a forum like this when i swapped a 350 small block chevy into my 70 GTO judge back in the 80's, Would have taken days instead of months.
Merit : 239
PostSubject: Re: engine swaps for N/A Series II   Mon May 14, 2007 1:27 pm
Lol. Probably the closest thing to a discussion board back then was, uh... CB radio?!!
^^^ RIV IS FOR SALE! ^^^
PostSubject: Re: engine swaps for N/A Series II   Mon May 14, 2007 10:26 pm
98riviera98 wrote:
i dont think there is any way to test the pump, but PS pumps are pretty cheap cant you just get a reman and install it before the swap?
so whats different about the manifolds?
good work so far thumbsup
on the NON SUPERCHARGED they are like this (the portholes) 0..0.....0
and the superchargerd (the portholes) 0 0 0
Actually the NON sc has the evenly spaced port holes as well. The Series 1 supercharged has the uneven port spacing.
BIGAL1128
PostSubject: Latest Update   Fri May 18, 2007 11:45 am
Goog Morning,
Well the saga continues. After several hours of trying to make the new fuel fittings, i gave up. I was having no luck with the $500.00 tool that i borrowed, so i decided that the fastest way to do this was to cut the ends off of the SC cars supply line and return line, i left about 3 inches of tubing after the flare and cut them both. Then i bought two 6 inch lengths of high pressure Fuel injection repair hose and 8 mini clamps. i slid the ends that i just cut into the fuel hose and double clamped them, then i slid the hose onto the existing lines on the NON SC car and double clamped them. The remaining third line is a vapor return line and doesn't need to be changed as it is the same on both engines. be sure not to cut the ends of the original fuel lines (NON SC car) or else you will need to flare them so that you get a good seal.
We plan to fire up the car tomorrow so more to come.
BIG-AL
P.S. How do i upload a picture? I will send a picture of the mod that i did if someone shows me how to upload it.
Thanks
Merit : 239
PostSubject: Re: engine swaps for N/A Series II   Fri May 18, 2007 12:05 pm
You can't upload photos directly to our site. Read our FAQ entry on posting images.
Rebekahssm
PostSubject: Re: engine swaps for N/A Series II   Sun May 20, 2007 12:13 pm
lol Actually it was/is a counter, at least around here. The gear heads seem to congregate in each others garages and meet up regularly in diners, coffee and/ or donut shops where they sit for hours chatting about everything, but mostly motors happy
BIGAL1128
PostSubject: Re: engine swaps for N/A Series II   Tue May 22, 2007 8:45 am
Hi,
Well we finally got her fired up. We ran into some minor problems at the end. it seems that even the blocks are different between the two cars. there is a engine to chassis ground wire near the starter that will not bolt up to the SC engine without modification. Drill out the the existing hole in the groung wire about two sizes and then it will bolt up to the block. Also the AC compressor is different. At this point i'am going to try to just change the pressure lines from the SC car. I don't know if they are any good as the AC didn't work in the SC car when i got it. But the good news was all i needed to do was plug in the computer and after about 1 minute the computer relearned itself and it's running good. It has a little skip in it but i think that was my fault. when i put on the new wires i might have messed it up.
Thanks for all the help.
BIG-AL
NO 4 EVR
PostSubject: Re: engine swaps for N/A Series II   Tue May 22, 2007 2:49 pm
Glad to hear that everything seems pretty good. Keep us posted on how she runs in the coming days. And good job!
PostSubject: Re: engine swaps for N/A Series II   Tue May 22, 2007 9:45 pm
Nice job! Hope it keeps up ok.
BIGAL1128
PostSubject: Re: engine swaps for N/A Series II   Wed May 23, 2007 11:41 am
Thanks for kind words fellas.
I changed the coil packs and the skip is gone. This thing runs like a rocket ship. i can't believe the difference between the NON SC and the SC.
BIG-AL is happy now smile
I do need one more thing. Can any of you factory SC guys tell me where do the vacuum lines go for the cruise control? We never marked them and now i have no reference to go back to.
Thanks,
BIG-AL
PostSubject: Re: engine swaps for N/A Series II   Thu May 24, 2007 9:57 pm
Congrats!
Now that you have the S/C engine work its time to start modding. wink
Brad95Riv
PostSubject: Re: engine swaps for N/A Series II   Sat May 26, 2007 8:47 am
Thanks,
BIG-AL
Congrats on getting the swap done!
As for those vacuum lines, I may be able to help. If I don't get back to you in the next couple of days, send me an email.
senabunns
PostSubject: engine swaps for N/A Series II   Tue Mar 02, 2010 6:32 pm
hey i have a 95 non supercharged riv with a seized engine. other than the 3800 what engines can i swap mine for with minimal amount of mods.
PostSubject: Re: engine swaps for N/A Series II   Tue Mar 02, 2010 10:02 pm
A 1995 3800 N/A - cheapest and easiest
Merit : 124
PostSubject: Re: engine swaps for N/A Series II   Tue Mar 02, 2010 10:21 pm
Yeah, there's nothing that I would call easy besides putting back in what came out for this car. It's not like a civic. It would involve wiring and experience just to get a supercharged series II in there since the PCM's are not compatable. If you decided to put a superchared series II in and go through it all, You would probably want to get the electronic transmission to go with it to so there's the cost of that to consider also.
Not trying to discourage a swap but there should be no fantasy that it is easy.
senabunns
PostSubject: Re: engine swaps for N/A Series II   Tue Mar 02, 2010 10:31 pm
yea ive done the s/c swap before on a 92 grand prix from a series one to a supercharged series two so i know what i would have to do as far a rewireing the whole pcm, i am more concerend as to what engines would bolt up as far as motor mounts and all that fun stuff.
Merit : 125
PostSubject: Re: engine swaps for N/A Series II   Tue Mar 02, 2010 11:25 pm
might want to go to a junkyard and look at anything with FWD and a Northstar. Preferably a 1st gen Aurora.
PostSubject: Re: engine swaps for N/A Series II   Wed Mar 03, 2010 9:45 am
The '95 Non supercharged has the Series II 3800, they should be very readily available. As to swapping with another motor - if you are doing a complete drivetrain swap and take the PCM and engine harness from the donor car it should be doable, but I would just look for another 3800 Series II motor. It is the easiest way out.
Ryan from Ohio
PostSubject: Re: engine swaps for N/A Series II   Thu Mar 11, 2010 7:28 pm
I put in a 2004 3800
I believe those are series 3.
Had to swap out all the sensors, fuel injectors, TB and so forth.
Also note the oil filter is a modular part, so keep your old engine until the swap is done.
'96reese
PostSubject: series 3 motor swap   Tue Apr 13, 2010 10:09 pm
how hard would it be to do a series3 motor and trans swap????????? found this on craigslist.
[url]http://stlouis.craigslist.org/pts/1680864592.html
moldymac
PostSubject: Re: engine swaps for N/A Series II   Wed Apr 14, 2010 5:36 pm
I don't know about the trans, but I thought that the motor was pretty straight forward. I think you swap the injector rail and the throttle body from your old engine to this one. There might be more to it, not sure though.
Merit : 171
PostSubject: Re: engine swaps for N/A Series II   Wed Apr 14, 2010 6:38 pm
Complete wire harness, PCM, TCM, BCM, cradle mods, and many others to list......Unless your planning a project I wouldn't recommend it.
Now if you just took the bottom end and transferred everything else from your engine to it, it will work....but as far as putting in the complete engine don't bother.
*Example* A 2004 Grand Prix uses an electronic (drive by wire) throttle body and requires different programming and wiring, hence the PCM and harness change. Along with this comes the APP sensors on the accelerator pedal......this is only the beginning of the nightmare......
Merit : 100
PostSubject: Re: engine swaps for N/A Series II   Wed Apr 14, 2010 7:13 pm
If you already had a L67 the swap would not be too hard. you would need a gen V adapter for a L67 TB, and the transmission might be a problem due to the changes in mounting braces. (I believe we share the same rear brace as the Bonneville)
However, you have a N/A motor, pcm, etc and the 4t60e transmission. so like Scott said, its a project!
1996 with 254k miles, L324" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs.
EatDirtFartDust
PostSubject: 95 engine/trans swap/upgrade (to Series I SC)   Sun Aug 15, 2010 8:04 pm
My trans was hanging in third gear, before I could get that fixed, the engine gave out. It was naturally aspirated. I'm looking at a supercharged engine/trans combo. What else besides the wiring harness do I need from the salvage yard?
Thanks in advance,
-Josh
Merit : 171
PostSubject: Re: engine swaps for N/A Series II   Sun Aug 15, 2010 10:22 pm
The PCM for starters.....
