 FAQ: Wet Carpet - Interior Leak Problems
Merit : 137
PostSubject: Re: FAQ: Wet Carpet - Interior Leak Problems   Sun Aug 23, 2009 9:16 pm
The drain is on the engine side of the lower passenger side firewall. You may not be able to see it looking down thru engine compartment with hood open. If you don't see it that way then turn the steering wheel left all the way to lock and slide under on passenger side behind front wheel. Look up/feel firewall. You'll find it.
Merit : 62
PostSubject: Oh no! A leak!   Thu Sep 03, 2009 3:31 pm
Oh man...when it rains, the car becomes a mini-pool on the driver's side. However, lucky for me I think I know exactly where the car is leaking from.
You know how the roof is a 'panel' of its own? Well I sealed up those seams on both sides very carefully and neatly, and behold. The car still leaks. So the next time it rained I paid attention to where I first saw it start. I notice a spot of water the size of a quarter about 2 inches from the ceiling handle. Guess what's right above that? One of the moonroof drain tubes...
The trail of water continues down the A-pillar and onto the floor.
Has this happened to anyone before? Any advice before I start tackling the headliner?
Thanks,
-Andrew Z
PostSubject: Re: FAQ: Wet Carpet - Interior Leak Problems   Thu Sep 03, 2009 4:02 pm
the holes in the moonroof should run down to the wheel well right behind the strut/shock. Make sure it isnt clogged up with dirt.
PostSubject: Re: FAQ: Wet Carpet - Interior Leak Problems   Thu Sep 03, 2009 5:49 pm
Do you mean you clogged the channels over the doors? I think those are there to help evacuate water down the C-pillars and rear of the car.
Merit : 62
PostSubject: Re: FAQ: Wet Carpet - Interior Leak Problems   Thu Sep 03, 2009 6:04 pm
Yes that's what I meant because the seals looked a little dried and I thought they might be leaking into the ceiling of the car. Well, I checked the channel openings in the moonroof over and nothing was clogged so I decided to try something. I took off the ceiling pullstrap handle thing and the driver's visor as well as the A pillar cloth cover. What do I see and I gently bend the headliner down? A moonroof drain nozzle without a tube attached.
A little worried I'm missing the tube altogether, I bend the headliner down a bit more and find it lodged in a space right above where the visor screws in. Phew. I moved it, took about 4 seconds to connect it back up, leak tested, and put the car back together.
I'm SOOOOO glad I didn't have to take the headliner down to do this. It was a really bad leak and was making me nervous each time I saw rain on the radar.
Again, phew...
95ParkAveUltra
PostSubject: Re: FAQ: Wet Carpet - Interior Leak Problems   Fri Sep 04, 2009 12:58 am
wow ima have to look into this. the back of my head liner is letting go. it was just alittle when i bought the car. now the complete back half is down. i am using push pins to hold it up for now. i am goin to rewrap it. but i just noticed the other day that it is wet. so i have a leak somewhere. it starts in the back passenger by the rear pillar. could this be a leaky back window. or shud i look in the same place z-type did? i had a feeling it was the moon roof but its not wet near the moon roof at all? its starting to creep up the passengers side by the handles. where should i look first?
PostSubject: Re: FAQ: Wet Carpet - Interior Leak Problems   Sun Sep 06, 2009 8:51 am
-Andrew Z
I'm glad you found the leak.
There is one thing to keep in mind about the roof panels on our Rivs, the black rubber trim piece that is visible in the seam is nothing more than a trim piece, it has nothing to do with the sealing/bonding of the roof panel to the pillars. Since there are no welds or fasteners holding the panel on, it is held on with the bond that seals it; if there was a leak there it would mean that the roof panel could be coming loose from the car, very unlikely since from what I have heard they are bonded on VERY well!
My best guess, as you found, is that if there is a leak in that area it would more than likely be a drain tube disconnected.
PostSubject: Re: FAQ: Wet Carpet - Interior Leak Problems   Sun Sep 06, 2009 8:59 am
99Rivman wrote:
My best guess, as Z-Type found, is that if there is a leak in that area it would more than likely be a drain tube disconnected.
The foam that the fabric is attached to will generally hold the water until it is puddled full enough to run off, that is probably why it doesn't seem to be leaking near the moon roof? The headliner material might be effected by the leak but probably not, it will just separate with age.
PostSubject: Re: FAQ: Wet Carpet - Interior Leak Problems   Mon Sep 07, 2009 8:21 pm
99Rivman wrote:
-Andrew Z
That black rubber trim piece in the seam you mention. When doing a repaint how or would one go about removing/replacing that piece. I was just curious about trim like that...in the future when these cars need the rubber trim replaced if it is going to be possible. study
Bert tavis
moldymac
PostSubject: yet another leak   Thu Mar 04, 2010 1:02 pm
Aside from my trunk leak, I have discovered yet another. I found the back floor to be absolutly soaked the other day when it was raining. I was in the car during the heavy rain and don't actually see where its coming in. Its just the back floor, its dry under the rear seat.
Merit : 102
PostSubject: Re: FAQ: Wet Carpet - Interior Leak Problems   Thu Mar 04, 2010 2:42 pm
At this point I'd be worried about karma... Try changing your name to notmoldy. smile
moldymac
PostSubject: Re: FAQ: Wet Carpet - Interior Leak Problems   Thu Mar 04, 2010 3:02 pm
Heh, yeah. These are the problems you get from buying an abandoned car. It has been sitting for at least 2 years outside, who knows how long it has been leaking.
PostSubject: Re: FAQ: Wet Carpet - Interior Leak Problems   Thu Mar 04, 2010 3:36 pm
raise your back seat - is there water pooling up under there?
PostSubject: Re: FAQ: Wet Carpet - Interior Leak Problems   Thu Mar 04, 2010 3:38 pm
i had a acura legend that was sold to me by a good friend of mine.he bought it brand new in 88 and gave it to his daughter in 95. she went to college in 97 and the car sat in his driveway for 3 years.i bought it in 2000. it leaked like a sive. it had been sitting in the sun uncovered and all the seals shrank i guess. i removed all them ,cleaned them with soap and water,and armor alled the hell out of them. she remained leak free until 04. maybe try it?
moldymac
PostSubject: Re: FAQ: Wet Carpet - Interior Leak Problems   Thu Mar 04, 2010 10:19 pm
I didn't see anything under there from that storm. I did notice after a ride in the rain there was a bit pooled under the passenger side wiring harness by the battery. I think that came in from the massive trunk leak during the drive.
Merit : 106
PostSubject: Re: FAQ: Wet Carpet - Interior Leak Problems   Thu Mar 04, 2010 11:24 pm
Try putting talc powder, as Albert has previously suggested, on and around any place you could possibly suspect a leak to be coming from and hose the car down or wait for another rain storm and inspect all the seals and grommets that you put powder on. It could help you find the "Wet Spot".
I'm told it work's on fat chicks.
PostSubject: Re: FAQ: Wet Carpet - Interior Leak Problems   Thu Mar 04, 2010 11:37 pm
aghh rick? dats just gross
Merit : 106
PostSubject: Re: FAQ: Wet Carpet - Interior Leak Problems   Fri Mar 05, 2010 2:09 am
OH, Tell me your not involved in the rumor.!!!!!
PostSubject: Re: FAQ: Wet Carpet - Interior Leak Problems   Fri Mar 05, 2010 11:54 am
ok,you got me. but i use tactile,not talc.
moldymac
PostSubject: Re: FAQ: Wet Carpet - Interior Leak Problems   Mon Mar 29, 2010 10:15 pm
It rained again today and I noticed something of interest. Water seems to pool up between the plastic sill cover and the rubber weather stripping. I still don't see how its getting there. Looks like it runs down something into that small channel, then gets absorbed by the carpet under the sill cover.
Merit : 106
PostSubject: Re: FAQ: Wet Carpet - Interior Leak Problems   Mon Mar 29, 2010 10:28 pm
Pic's with arrows pointing to the area's you are talking about would help a lot.
I admit, I don't know how to use the software that other people use, that allows them to put arrows and circle's and whatnot onto a picture they have taken then post on here.
It sounds simple enough but I don't have the software or experience.
If you do, that would be tremendously helpful in identifying where you are talking about.
moldymac
PostSubject: Re: FAQ: Wet Carpet - Interior Leak Problems   Mon Mar 29, 2010 10:30 pm
I'll do that. I dont know how to use that software either, I usually draw a crude arrow in paint brush lol.
Merit : 137
PostSubject: Re: FAQ: Wet Carpet - Interior Leak Problems   Mon Mar 29, 2010 11:13 pm
I have no experience with the latter.
Be sure it's talc and not cornstarch. A cheap foot powder will work fine; be sure to read the label to make sure it does not have vegetable powder (corn starch) in the mix. Reason - you think you have interior mosture problems now, they will just get worse with cornstarch - it supports growth.
Merit : 106
PostSubject: Re: FAQ: Wet Carpet - Interior Leak Problems   Mon Mar 29, 2010 11:17 pm
Albert Said: I have no experience with the latter.
Touche
moldymac
PostSubject: Re: FAQ: Wet Carpet - Interior Leak Problems   Mon Mar 29, 2010 11:21 pm
Why do I see this car turning into a powdery mess when I am done smile
» Briggs opposed twin problems
» Actual showroom pics of the 2011 John Deere XUV 825i
» RZR Wheel Hub Problems?
» 3500 still has problems
» GPX 4000 Problems
