 Series I Supercharger... making noise?
Series I Supercharger... making noise? - Page 2 Empty
PostSubject: Re: Series I Supercharger... making noise?   Series I Supercharger... making noise? - Page 2 EmptyThu Apr 19, 2007 8:32 am
It'd not that you can't use motor oil, the question is why would you? The SC specifies a special type that can be picked up at any dealership for under $10 per bottle. I think it takes 1 1/2 bottles to fill. Do this every 25k miles or so, even every 50k miles would be acceptable. If it ain't broken...
For more on engine cleaning: http://rivperformance.editboard.com/Other-Stuff-c3/Care-Maintenance-f8/Write-Up-Seafoam-to-restore-lost-horsepower-t123.htm
Blowin95
Blowin95
PostSubject: Re: Series I Supercharger... making noise?   Series I Supercharger... making noise? - Page 2 EmptyThu Apr 19, 2007 9:33 pm
supercharged_riv07 wrote:
so any 5W-30 synthetic oil will work on the stock supercharger?
For your supercharger application, yes. They reformulated the oil to non-syn after the M-90 (Series 2, 240 horse SC) came out.
http://myspace.com/rumblinriv
NO 4 EVR
NO 4 EVR
PostSubject: Re: Series I Supercharger... making noise?   Series I Supercharger... making noise? - Page 2 EmptyThu Apr 19, 2007 10:16 pm
I didnt know that. I am sure that is part of the debate between using motor oil in the s/c. Makes sence as I know that the m90 genIII needs special oil
2 bottles to be exact and if you need to buy a third and use some of that to top it off at the bottom o the treads.
supercharged_riv07
PostSubject: Re: Series I Supercharger... making noise?   Series I Supercharger... making noise? - Page 2 EmptyFri Apr 20, 2007 8:09 am
well the car is running better now, we changed plugs, wires, fuel filter, and it still ran like crap, then we took out the air filter and its running alot better. still chugs a bit, so i dont know what else it could be?
PostSubject: Re: Series I Supercharger... making noise?   Series I Supercharger... making noise? - Page 2 EmptyFri Apr 20, 2007 8:34 am
Clean the MAF sensor maybe? Takes about 15 mins. Use electronic parts cleaner spray. Be careful handling the MAF, it looks like a cheap plastic part, but it's far from it!
supercharged_riv07
PostSubject: Re: Series I Supercharger... making noise?   Series I Supercharger... making noise? - Page 2 EmptyFri Apr 20, 2007 6:55 pm
how will i know if the MAF sensor needs to be replaced? there is no check engine light. in my camaro, the MAF is shot and a check engine light is on. when in gear and i hold the brake to the floor, and give it alot of gas, it chugs badly.
PostSubject: Re: Series I Supercharger... making noise?   Series I Supercharger... making noise? - Page 2 EmptyFri Apr 20, 2007 11:44 pm
You don't need to change it. You just need to clean it. Make sure you have electronic parts cleaner spray. Otherwise it can leave an oily residue. BTW, did you change you PCV valve when you did your tune up?
supercharged_riv07
PostSubject: Re: Series I Supercharger... making noise?   Series I Supercharger... making noise? - Page 2 EmptyFri Apr 20, 2007 11:45 pm
nope, i should do that right?
supercharged_riv07
PostSubject: Re: Series I Supercharger... making noise?   Series I Supercharger... making noise? - Page 2 EmptyFri Apr 20, 2007 11:48 pm
and where is that exactly? im sorry im asking stupid questions, rivieras are just new to me.
PostSubject: Re: Series I Supercharger... making noise?   Series I Supercharger... making noise? - Page 2 EmptyFri Apr 20, 2007 11:49 pm
Yep, it's in the top of the supercharger.
supercharged_riv07
PostSubject: Re: Series I Supercharger... making noise?   Series I Supercharger... making noise? - Page 2 EmptyFri Apr 20, 2007 11:54 pm
is there anything else that could cause the car to chug really bad when you hammer it?
PostSubject: Re: Series I Supercharger... making noise?   Series I Supercharger... making noise? - Page 2 EmptyFri Apr 20, 2007 11:57 pm
About the only thing left is the coil packs I guess. But they don't go bad very often. Your using the higher octane gas aren't you?
supercharged_riv07
PostSubject: Re: Series I Supercharger... making noise?   Series I Supercharger... making noise? - Page 2 EmptyFri Apr 20, 2007 11:59 pm
well i just bought it last weekend, so most likely it has unleaded regular right now, but im going to use only premium now that i own it, that could be another reason.
PostSubject: Re: Series I Supercharger... making noise?   Series I Supercharger... making noise? - Page 2 EmptySat Apr 21, 2007 12:28 am
Did you do the Seafoam through the Brake booster vac line?
and the gas??
NO 4 EVR
NO 4 EVR
PostSubject: Re: Series I Supercharger... making noise?   Series I Supercharger... making noise? - Page 2 EmptySat Apr 21, 2007 12:29 am
I will testify that bad coil packs will cause it to run bad, but sooner or later it will throw a code. Same with the MAF. I had both issues, MAF and coil packs, both similar type problems.
Coil pack cause a serious misfire in cylinder #6 and cause vibration, bad vibration.
The MAF caused a serious hesitation like I was out of gas. I would hit the pedal and I wouldnt go anywhere for a second (or less, felt like forever).
Doing a top engine clean woudnt hurt. It is very very easy and kinda fun.
You could also try and clean the throttle body and check it out while you clean it. However I think the how to on the throttle body cleaning is lacking as I know how to clean it but not how to take it off!!! lol
supercharged_riv07
PostSubject: Re: Series I Supercharger... making noise?   Series I Supercharger... making noise? - Page 2 EmptySat Apr 21, 2007 11:20 am
i put the seafoam into the brake booster line and into the gas tank.
NO 4 EVR
NO 4 EVR
PostSubject: Re: Series I Supercharger... making noise?   Series I Supercharger... making noise? - Page 2 EmptySat Apr 21, 2007 7:01 pm
oh nm that then. Throttle body clean could be done. I hear it is easy, just don't know how to take the TB off...
supercharged_riv07
PostSubject: Re: Series I Supercharger... making noise?   Series I Supercharger... making noise? - Page 2 EmptySat Apr 21, 2007 9:13 pm
when i went to change the oil, as i am going up the car ramps giving it gas, it sputtered really bad like it was gonna die out, i did new oil, new air filter, pcv valve, fuel filter, and a seafoam clean, and it still sputters real bad, could it be egr, need premium gas?
Brad95Riv
Brad95Riv
PostSubject: Re: Series I Supercharger... making noise?   Series I Supercharger... making noise? - Page 2 EmptySun Apr 22, 2007 12:14 am
Where in Wisconsin are you? If you're anywhere near Stoughton, I could probably help you out sometime. I have a scanner as well as some known good parts (such as coils) that we could try.
supercharged_riv07
PostSubject: Re: Series I Supercharger... making noise?   Series I Supercharger... making noise? - Page 2 EmptySun Apr 22, 2007 1:18 pm
i live in whitewater, so it aint even that far.
Brad95Riv
Brad95Riv
PostSubject: Re: Series I Supercharger... making noise?   Series I Supercharger... making noise? - Page 2 EmptySun Apr 22, 2007 9:23 pm
Ahh, UW-Whitewater is my alma mater. smile Well, I'd be willing to take a look sometime. My work schedule is never the same from week to week, and in fact I'm not 100% sure what it is like this week yet. I should be available Thursday and Friday.
supercharged_riv07
PostSubject: Re: Series I Supercharger... making noise?   Series I Supercharger... making noise? - Page 2 EmptySun Apr 22, 2007 10:00 pm
well check your schedule and everything and make sure you can do it, maybe this upcoming friday?
Brad95Riv
Brad95Riv
PostSubject: Re: Series I Supercharger... making noise?   Series I Supercharger... making noise? - Page 2 EmptyMon Apr 23, 2007 5:59 pm
Ok, looks like Friday is out. Thursday would probably work best for me this week.
supercharged_riv07
PostSubject: Re: Series I Supercharger... making noise?   Series I Supercharger... making noise? - Page 2 EmptyTue Apr 24, 2007 8:06 am
ok i'll let you know.
tm323
PostSubject: I need a new supercharger   Series I Supercharger... making noise? - Page 2 EmptyFri Apr 11, 2008 7:58 pm
been searching the web for the cheapest prices and came across PSE supercharger remanufactoring company and I just wanted to know if anybody has ever heard of them or new a better or cheaper company. I called and they said it would be around 700 bucks with a refundable core charge which they pay the shipping handling on. I have never bought any thing so expensive over the internet so would like to use a reputable company. Any advice at all wiil be greatly appreciated.
» axle making noise
» Andrew Nicholson Making Noise on NBA Draft Front
» Devoe Joseph MAKING NOISE!!!
» Strange noise from the rear end
» Clicking noise when in reverse?
